Liquid cooled touring car
#76
GA
RE: Liquid cooled touring car
ORIGINAL: R/C fan-addict
how about coolant fluid? [&:]
http://www.racerpartswholesale.com/redline3.htm
Advance Auto, Auto Zone, O'Reilly, Kragen, NAPA, etc should all carry it. I know the first two I listed carry it.
#77
MA
um no... coolant fluid is a much better conductor of heat. Apparently it doesn't work for this application anyway because it is conductive, but it is much better than water for cooling stuff.
#79
PA
hi to bad the brushless motor makers didnt think of this ahead of time should have made the out put shaft a little longer and mount coolant pump on out put shaft ooohh welll that will be next eng. motors dee dee dee
#80
MA
um that's a pretty bad idea... you wouldn't want a coolant pump spinning at 65,000 rpm. Even if you geared it way down it would still be very fast. Also it would put more rolling resistance on your car which would slow you down. Seperate systems work much better.
#81
yeah, not to mention you'll have so much headache fixing pumps unless they somehow dont break all the time at the speeds and heat theyre working at
what would be cool, tho, is in some cars originally meant for dual motors but are being powered by a single brushless motor (like the mini lst, e-zilla, etc), instead of a second motor spinning the spur gear it could be a pump with a giant 'pinion' gear , and all sorts of really expensive bearings and lubricants thats inside it to minimize the drag , but then again its really no point putting so much power thru the plumbing when all you needed to do was shift some hot and cold water around
motors have built in fans because air is easy to shift and fast moving air is good, but not so with liquid...
but, having motors with built in waterblocks, or motors that ship with a waterblock attached instead of a heatsink, now that will rule
maybe if we can get this market big enough we can get some traditional PC watercooling makers to make something for us ? that'll be really expensive tho, but imagine a 'danger den' sticker on your TC body
#82
TX
Open up your eyes and see
http://offshoreelectrics.com/accesso...l_water_jacket
ORIGINAL: carmatic1
heh weve had this in computers for years already... my computer is watercooled and has been so for like 4 years already... that said i would like to see a 'jacket' design of the motor waterblock tho, like it wraps around the motor so it would be a much better fit...
#83
Hi Spook,
I just ordered such a water jacket from them , will try it out. It should work even better than the TCS manifold. I'll let you know how it goes.
[quote]ORIGINAL: spoook
#84
PA
hello all how about one of those ceramic mug heater cooler thingys they run on battery power just mod that to cool your motor and not evey ones motor turn 65,000rpm
#85
MA
ORIGINAL: dude7422
#86
I thinck he means a built - in pump on the motor can and a long output shaft so we can still mount the pinion gear , I don't thinck he wants to say the pump has to rotate with the shaft.
ORIGINAL: dude7422
#87
aahh... well i guess this is one place where you cant get everything for nothing, there are gearboxes that wont fit the front-mounted blocks, while there are also gearboxes that wont fit the boat motor jackets... the worst of them are the gearboxes which fit neither, but honestly i think that most gearboxes can fit a normal motor heatsink , so if we can have a waterblock patterned after a normal heatsink (i.e. not a sleeve that goes all the way round) it would fit most gearboxes.... but i dunnoe, i havent looked at enough RC cars to judge properly
#88
CA
looks really cool,, I jut cant sxee how I would mount the thing in one of my offroad cars without breaking the crud out of the radiator with in an hour or two.
#89
i think thats why the thread is labelled as 'liquid cooled touring car'
but im sure like, you obviously dont put the radiator anywhere stupid like near the bumpers or way up above the chassis, and maybe now the electric trucks will have holes cut into the body just like the nitro trucks so that air can pass to the radiator
#90
The radiator is nothing to worry about , it's the strongest parts of the system. It's one tough brick of aluminum and I would really want to meet the guy that can break it. I bet I can run it over with my real car and it'll come out undamaged.
ORIGINAL: zephar123
#91
PA
hi all this is just for a joke so dont start any thing if you run this in the winter do you add anti freeze lol and if you get a leak in the rad can you add bars stop leak or alumia seal lol
#92
quick question, where do you have the pump plugged in on the RX? the "Bat" port, or a third chanel. i want to do something like this, but that one question is bugging me allot. and which cooling jacket did you buy for a what sized castle motor? please answer me.
#94
ORIGINAL: Link119
The batt port is where. And please dont bring up old posts...
Also.... WELCOME to RCU!!!!!!!!!!!!!!!!!!
#95
Or if your running electric, like what this whole section of the forum is about, you would plug it into the batt port if you dont have a third channel.
#96
i think ur right about the batt port but i wasn't sure so i asked. (duh) and no one has answered my question about the cooling jacket!!
