Official E-FIRESTORM thread
#6326
ON, CANADA
RE: Official E-FIRESTORM thread
As Rob says, things are fine when you run 2S, so I doubt if there's anything drivetrain-wise that is causing the ESC to overheat. If there was a bad bearing, or something else binding, then you'd be looking at a motor overheating problem. I just think (even though both those esc's are rated at 3S) running motors over 5000kv on 3S is too much for the ESC's to handle. You may be able to get away with it in the spring or fall, but not in the hot summer heat.
#6327
1 Post
ORIGINAL: Paron34
Also their is a guy on my Jato 3.3 vs Brushless HPI 3S youtube video that refuses to believe we were doing close to 50. He also claims reversing the rears arms is similar to the second coming of Christ when it comes to running your firestorm. ill link it http://www.youtube.com/watch?v=rPep7O7R-Bc
#6328
ORIGINAL: redfisher1974
Wonder who that is!
ORIGINAL: Paron34
I thought the exact same name would be pretty bloody obvious.
and I've done enough speed runs to know what modifications are required to get what speeds!
#6332
NY
ORIGINAL: TheyDontWantMusic
that guy would be me.
Wonder who that is!
ORIGINAL: Paron34
Novak has a nice trade in for esc and motor's I might take that into consideration gonna look at what they have.
#6333
1 Post
ORIGINAL: nitro-rob
Yeah, nice place. Can I assume there is a lot of fishing nearby?
#6335
1 Post
Nope, I came up to work. I have sanded and primed the 40 ft transport trailer that they use for storage and tomorrow I will give it the top coat. But dads taking me salmon fishing tonight.
#6337
VT
looks nice red, you'll have to tell us how it comes out
while were posting fishin pics here's a good lake trout i got a few weeks back i wanna say it was 8lbs or so not really sure, my sis pulled a 13lbs one earlier...
the lug
the lug
#6339
1 Post
ORIGINAL: mercerbeef
Red- LOL it looks like you took it off of someones wall. whys the paper dry? lol
#6342
MT
nice, I haven't had time to build mine yet. not sure if I'm gonna dye the plastic, I can't find orange anywhere
#6343
ORIGINAL: Paron34
Ok gotta be something wrong with my rig possible the differential that I really need the forums help with. Ive been getting thermals when running a MM 5700 and a Novak ballistic 8.5T ''5000khv'' with 15/87 gearing with a Thunder Power 3S 25c ''. Ive tried both systems and consistently getting temps of 150 to 170F on the ESC shutting down the Novak and 120 to 150 on the motors the battery is under 90F. Something has to be wrong with the firestorm to having the same problem with both systems Ohh and I never get close to that with 2S running 23/87 my ESC stays under 130 with both systems on 2S and the motor temps run around 90ish. THe 3S perfect balances and holds voltage and Ive check all the wires and soldering connections. Does anyone any idea's or suggestions??
#6344
VT
guys, i was just out messing with the e storm, throwing a few flips failing at a lot more and for what i threw at it nothing broke, i wasn't goign super huge on the air (didn't have a huge run up for speed, nor the best jump) but there were many a landing that you could see the a arm visibly deflect significantly, 20 mins of good bashing nothing broke, i only came in cuz i poped the rear bone out (and had to pretty myself up for company that should be here...), cuz the arm deflected soo much when i clipped a rock, i thought i had busted something or at least bent a buckle...
truely impressd
btw my setup
storm, CC sw 4600, 2s 25c 5000mha lipo, 19/87 (stock isn't that) gearing and proline badlands out back, i could probally go up a tooth on the pinion but i'm gunna leave it for now cuz i'm off to go play with castles new TQ limiting stuff
the lug
truely impressd
btw my setup
the lug
#6346
VT
yeah it was, till i dropped a pinion and destoryed the spur, totally shreded its uggly, i'll snag a pic in a bit...
also i've been playing with castle's new power settings in castle link, i'm liking it alot, its supre easy to make the car good for a beginner, or have soo much power you' dont' know what to do with it... also the kv detector, super cool, my 4600 is reading 5400kv unloaded with 0 timing, tho when i bumped it up it dropped about 200kv when i went to 5* and then stayed about that +/- 50kv when i went to 15* but this is all at the speedo, not on the motor...
the lug
the lug
#6348
VT
tree or rock?
i've heard, tho havn't tested this out pulling and replace 8 screws (4 per car cuz its mounted to the b4) is far too much work for me ;0 that this is a direct drop in... may help?
http://www3.towerhobbies.com/cgi-bin...&I=LXGFH7&P=ML
they also have a blue one
#6349
ON, CANADA
I wonder if your k rating means that the rating given on the motor is loaded then. Thanks for letting me know about the update to the castle link, the kv determining part is new and pretty cool. They reworked the software a lot with the latest version. The only concern I have is that in order to get the kv rating you have to run the motor wide open for three seconds without contact to the spur gear.
#6350
VT
yeah, i did it a few times today, and the motor ran great the whole time, it never got above 5 sec as far as temps (yes i did just use time as a mesure of temp) and that was as i was removing the punch control, and boosting start power and timing, but as you lowered it temps went down, but it cogged a bit more due to the less umph to get things going, i also had to really bump up reverse power, cuz it jsut had nothing in reverse with a tq limiting value of 4 i think, it wasn't till 6 or 7 that it started to really be able to pull the car out of some not so nice ground, once i bumped the power from like 60% to 100% it was all good...
i'm sure its unloaded the highest value i drew was 5400kv is of my 4600, tho most others were around 5200kv i wanna put it in my B4 go down to the school open her up in test mode and hope i have enuf room for it to get the data... then see what kinda #'s i pull... (and yes the local high school is the closest place with a realatively flat open area)
if you can't tell i'm really loving this, it's gunna be great for like newbs drop the tq, take out the wheelies and the accel but they still get the speed, it's just super nice
the lug
the lug
