Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
#1001
NL, CANADA
RE: Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
Looks nice! So it came with those tiny Tamiya boxes to put at the trunk? Lol, I got to get one!
#1002
NL, CANADA
ORIGINAL: dxbshafiq
Hi guys,
I need to change my Tamiya ESC to a better one, so what do you recommend?
Hi guys,
#1003
Just curious, what don't you like about the TEU-302?!
ORIGINAL: dxbshafiq
Hi guys,
Hi guys,
#1004
NL, CANADA
I was wondering the same as well, the Tamiya ones are ok, unless if you using a low turn motor.
#1005
I'm using a Novak Rooster Crawler ESC. Its working pretty well for me, pretty strong drag brake so it holds decently on inclines, rolls slowly on steeper inclines. Goes nice and slow for crawling. A friend told me if I changed the pinion it would hold even better. The stock motor on my rig barely gets the ESC heated. Even lots of climbing and tough stuff I've felt the ESC and it was just barely warm. It isn't adjustable, as far as the drag brake hold. If you want adjustability of the drag brake, you have to go with a Tekin FXR. People have good things to say about those.
#1006
AB, CANADA
you guys can get the boxs off the page for unimog on tamiyausa. mine came on the outside of the engine box~! heheh so today i got both stabilizers in and it feels like a new truck! atlot less springy hehe. and I've learned how to pop a wheelie with my silver can lol
#1008
OH,
LB,
Been awhile - but I got the Land Cruiser done. Nothing fancy - just used all the stock stuff and a Tazer 12t ESC. Took it out and it was a blast. Oh yah - I added lights as well.
Here are the pics.
Here are the pics.
#1010
LOL, I saw the link at the Unimog page now, ha! My bad!!
Yeah, TamiyaUSA website does not support direct linking, but you can go to the Unimog product page and the link to the PDF file is there... !!
#1011
Gran,
Nice!! Glad to see your CR-01!! Looks great!!
What kind of light kit did you use?! Just curious...
#1012
OH,
LB,
I used the TLU-01 - wanted to keep it all Tamiya - well kind of - the ESC I needed to get it done so forgive the Tazer.
The caster blocks on the axles kinda got me - but I got them figured out. Other than that a pretty straight forward build.
#1013
The caster blocks are great, as it allows more extreme axle angle while still retaining good caster setting.. (unlike a TLT axle, for example..)
Tamiya learns as well, you know...
#1014
OH,
LB,
It actually does steer - I was surprised. I only locked the rear and was able to get over everything I wanted. I just did not want a huge turning radius. I might lock the front as well.
Since I never had a crawler - not really sure what to do. I have just been trying to run everything over to see what will stop it. The only thing I have found is a wall - the rest has been fair game.
#1015
LOL! Wall..
Glad that you are having a good time w/ it! Yeah, for me, I locked both front and rear during the build, as it is an dedicated crawler.. I just figured that if I want regular bashing, I'd bust out my Clod or TXT or something.. this one will be locked from the get go!!
#1016
Hi LB,
So here is my problem, I installed Futaba S9350 in the front & JR DS8511 in the rear and when I link them by Y harness or the FR servo in CH1 & RR servo in CH3 to achieve 4WS the wheels would freeze and won't turn after 10 sec.
I reprogrammed the TEU-302 and I've changed the receiver and the same problem occurs, so I am thinking that may be my ESC is damaged some how.
BTW only two of our CR-01's are having this problem.
ORIGINAL: Lunchboxer
#1017
Do you know if the TEU-302 has built-in BEC to regulate the voltage down? I know TEU-101 does NOT..
If you use digital servo, that might cause problem?
But strange that only 2 of the 4 trucks are having the problem..
When you only use 1 servo, does the problem still exist?!
#1018
Yes, even with ONE servo. And yes I use digital highe torque servo's.
I think too that the TEU-302 deosn't have BEC.
#1020
I,m going to order Novak Rooster Crawler Brushed ESC very soon from Tower Hobbies.
I,ll let you know how it turned on.
That's a hard problem to determine.. maybe get a different ESC and give it a try?!
#1022
I've just finished making my rig to do 4WS & Crab Steering along with 2WS with my Futaba 3pm (2.4 Ghz) without using reversed Y Harness.
Its fun, now I can decide when I want to do 2WS or 4WS or Crab Steering. Thanks to bbeaty & Joat from [link=http://www.rccrawler.com/forum/showthread.php?t=24564]RCCrawler.com[/link]
#1023
Yeah, 3PM lets you do programmable mix.. I did that with my TXT as well! (although I am not sure when I really want to use crab walk.. ha!)
#1025
AB, CANADA
so if im planning to do 4WS with a two channel controller that means i gotta get a Y spillter wire? also the kit only came with one servo horn that fits on the futaba i wonder if my hobby store carries the horns that work for unimog
