The Official Traxxas Slash short-course race truck
#326
NY
RE: The Official Traxxas Slash short-course race truck
I just looked at the 3pm and it actually requires a 6volt nicad pack.That is 30 dollars plus the charger is 30 dollars.I may have to hold off for a week or two.I thought I could use regular AA batteries like always.Also I read that the Slash will accept other traxxas upgrade parts or aluminum parts but what traxxas vehicle is it.I see the stampede uses different a arms than the bandit.thanks again.
#327
The 3PM FASST uses AA cells in the transmitter just like most do. I use duracell rechargeables in mine. I think the reference to a 6v nicad is for an optional receiver pack, ie if you're running it in a nitro car. BTW, the stock ESC and servo work fine with FASST adn the receiver fits in the traxxas box with room to spare.
#328
PA
ORIGINAL: bnangle
http://www.ofna.com/tires-monster.html#pirate
you can run that radio on AA's
#329
NY
Cool,Thanks guys.I am ordering it after this post.I also posted some of my TXT pics in my gallery if you want to get it out.
#330
ORIGINAL: bnangle
#331
ORIGINAL: dacaur
the arms on the slash are rustler arms.
ORIGINAL: bnangle
They are also the same arms from the Stampede............................
#332
NY
I odered the radio but I am now puzzled by the fact that my back order status says order pending instead of late july.I ordered it on the 11th.I wonder if I didnt make this shipment and will have to wait again.Oh well gives me more time to get another battery.does anyone know if an 8 cell flat pack would fit or would it have to be a hump pack?thanks
#333
PA
ORIGINAL: bnangle
#334
ORIGINAL: bnangle
#335
NY
I have a li-po charger but no li-po battery.I dont know if I am ready to make that jump.After 25 years I am shocked to see batteries now with 5000mah.I am used 1000,1100 and 1200 from 1987.I'll check it out though.
UPDATE.I know why my order says order pending and everyone else says late july.When I ordered my Slash I ordered specifically A6 or the Blue one.If I just put the regular stock number in it would be telling them I want the first available color.I didnt know that and I cant change it so if blue slashes ship late july I will get one if not I'll have to wait.There are some hobby shops in California that have them but I'll be patient.
Also does anyone have any reccomended first hop ups I should get.I already got a traxxas wheelie bar because I noticed the slashes on youtube that are brushless were doing wheelies most of the time.I think alot of enjoyment in this hobby besides driving them is bidding on hop ups on ebay and making a car look awesome.This isnt going to be like my TXT though.I am going to drive this one and find a dirt track.
#336
PA
ORIGINAL: bnangle
#338
ORIGINAL: t9dragon
Doesn't running the extended front arms defeat the scale look of the truck?
so we got extended arms and fitted buggy wheel adapters and buggy rims and tires. The extended arms made it handle great and the extra weight of the aluminum helped settle the truck down and correct the zero offset of the tires.
#339
PA
We just had a parking lot race (oval) with ofna 1/8th scale trued foam buggy tires. We let the suspension arms sag a little bit to lower the center of gravity, adjusted the turn buckles to take out the excessive camber angle on the wheels and I was able to harness the Mamba Max 7700 with a 14 tooth pinion and a 90 tooth spur gear running a Max Amps 5000mah 11.1 batt. This was an unreal high speed, full control blast with 2 200ft staights and 2 45ft sweepers. One lap was 10 to 12 seconds on a stop watch....just fascinating is the only word I can describe this fun run. The fast lane machine aluminum tranny box pulls off a good deal of motor heat, smooths out the drivetrain, reduces most of the inherant spur gear wobble and makes the truck nearly bullet proof to excessive horse power I ran 110 degrees on the battery, 135 on the speed control and 141 on the moter after 18 minutes of asphalt pounding. By the Way, Jaco tires is comming out with a set of foam tires for the stampede/rustler at 4.1 inches in diameter by 1.9 inches wide with a 12mm hex. Should be a direct bolt on. Can you say carve up some turns on asphalt!
http://www3.towerhobbies.com/cgi-bin...?&I=LXVCA9&P=7
#340
QC, CANADA
anyone know which cvd's fit the slash? i'm hearing jato or rustler, and my lhs doesn't keep upgrades in stock.
which existing traxxas upgrades fit? ie. stampede, rustler, jato etc.....
#341
Just got back from a nice big dirt / sand parking lot near the house, we took the Slash out and beat it up a bit. The thing really goes good and takes some huge air jumps nicely! We were doing jumps of off some dirt mounds, with the truck getting 3' of air and it was landing on all fours nice and neat! This truck is'nt bad for the $$
This truck ran for almost 30 minutes with a DTX-4200 mah battery. [8D]
#342
ON, CANADA
Can one of you please do me a big favor
I would like someone to measure the width of the slash body at the wheel arches front and back for me.
I am interested in using the body on a custom build. Thanks Nick
#343
Does anyone know if lipo batteries will work with the stock setup, without frying the motor/esc? If so which lipo's would you recommend...2s, 3s??
#344
2S Lipos will work fine with the stock setup, but you will have to monitor voltage carefully to avoid damaging the battery or add an external LVC (low voltage cutoff) such as the Novak Smart Stop to protect the batteries.
#345
PA
ORIGINAL: nickd
#346
NJ
CrazySavage. Since you are changing this and changing that, why did you get the Slash? Should have bought somehting else, or just the body. You killing the whole purpose of this truck by defeating the scale look. As for LiPo and brushless being legal at most tracks? Have you heard the term Slash Spec class? Thats what the majority of the tracks are running the Slashes as. Spec meaning stock or close to stock.
#347
ORIGINAL: Jerzferno
Even if he isn't, its really his personal choice what he does to his truck.
The slash actually has quite a few things going for it that makes it great other than just a scale look.
Wheelbase.... 13.5 inches - thats a nice long wheelbase, which makes for great handling
Brushless ready transmission, what other truck can you get for $200 that has an all metal tranny and a planetary gear diff?
digital, high torque, "waterproof" steering servo
durable
compatible with rustler upgrades
higher ground clearance than a rustler, but not has top heavy as a stampede, and a wheelbase almost 2" longer than either.
front and rear bumpers - they are tough and make the truck look tough - great looking and functional ,what other truck has that?
comes with high current connectors installed (and "waterproof" to boot)
I'm sure in forgetting some things, but those are the reasons I got the slash... the scale look i can take or leave... dont care one way or the other honstly, but even without it, the slash is a great truck!!! Come winter, im going to get myself a rustler ski kit, and bash my slash though the snow!
#348
ON, CANADA
ORIGINAL: crazysavage
I cant measure at this moment but I can assure you that it fits perfectly on an eighth scale buggy and neweramodels has a corr type body that is ford 150ishof the same size.
I always thought the new era one was larger then the slash.
PA
ORIGINAL: Jerzferno
#350
Little bit of hyperbole, dontcha think? There's nothing wrong with innovation, but then again, there's nothing wrong with keeping a vehicle stock if it works for you or the rules call for it...live and let live. I'll be racing my Slash in stock spec class tomorrow.
