The Official Traxxas Slash short-course race truck
#1301
RE: The Official Traxxas Slash short-course race truck
ORIGINAL: trxsnewbie16
also does anyone make a 4WD kit for this?
#1304
MO
#1305
if i did turn a slayer roller into a 4wd electric, will it break more than the slash would, or is it a tank like the slash?
#1306
MO
it will be just as strong, probably a lot stronger actually. I would just get the SC8 and convert, they have a whole conversion now. It is not cheap though.
#1307
The Slayer is a Revo with different wheels and body. Watch some of the Revo vids on Youtube and you'll get an idea of what it can stand up to.
#1311
CO
just buy an e-revo, add the slayer tires, rims, body and bumpers and you have your self an E-Slayer. I just did a quick overlook of the exploited views and this is all that is different between the two, to convert it. it would not be a 4wd slash however an E-Slayer
#1312
Finally got around to making some quick vids of my Slash jumping some ramps in the driveway. The gap was 8 feet long and the apex of the takeoff ramp was two and a half feet high. I ran it with the Velineon system and a 7.4 volt LiPo.
http://www.youtube.com/watch?v=LMK-GLhN2z8
#1313
Anybody know what the top speed of a slash with stock gearing (18/86), MM 4600kv combo, and Venom 8.4v 5000Mah battery is?
#1315
ORIGINAL: Slash Basher
#1316
I've done the calc via everyone's favourite RC Speed Calculator and as you can see the the pic below it should get around 45mph on a fresh pack. I check and it will drop to around high 30s once the pack start to drop to normal operating voltage. Also this is done with stock tires.
#1317
It will likely be around 40 mph on a full charge. Those calculators are good for finding unloaded/freewheel maximum speed. But when you factor in internal drag from the transmission/driveline, the weight of the truck, and wind resistance, it brings the motors maximum achievable rpm down quite a bit.
#1319
hey what are some good pin tires that will fit on the slash. and how well will they work on a hard dirt surface?
#1320
You could run a 5700 but you wouldn't have much choice of gearing. Run a VXL motor and you can gear it higher and run 3S lipo and it won't even sweat.
#1321
ORIGINAL: FairTax4me
#1322
I think I want a 5700 because I like the top speed on it and my LHS has only 1 MM in stock and it ends up being a 5700. also the speed calculator says 48mph with a Traxxas Slash with a 7 cell
#1323
Well guys......I'm out.
I traded my slash for a brushless vendetta ST with a bunch of extra stuff.
I was thinking about buying another corr truck, but I would probably get the SC10 when I get the money.
#1324
CA
ORIGINAL: supamagician
#1325
MO
bombard my pm box all ya want. I will be more than happy to answer any questions and give advise. Good luck with the truck .
