TX for XTR/AFPD
ON, CANADA
I dont know if this has been asked before, but here a few questions I have:
1) Can you load XTR/AFPD on more than one computer, I have 2 at home and 1 at work ?
2) Does the transmitter need to be turned on to work on XTR/AFPD ?
3) If the TX needs to be on will I be able to use D/R and EXPO ?
Thanks for your help.
Rob.
Rob.
Moderator
My Feedback: (58)
To answer your questions:
1) No. Each copy of AFP/D or XTR comes with a usb dongle that contains copy-protection codes. You will need to plug it into the PC that you want to play on
2) Yes. Some Tx that has DSC function may be automatically switched on depending on the adapter design
3) Yes, you can use all the programmable mixes in your Tx but you have to assign the proper channel and calibrate the software
Hope this helps
Hope this helps
ON, CANADA
Can anyone tell me if my Futaba 7CAP TX has this DSC fuction or will I need a charged battery installed?
I'm just trying to figure out which sim to buy, and it seems to me that if I need a charged battery evertime I want to fly I may be better off just to buy G3, even though it looks as if AFPD & Reflex XTR are better programs.
Any thoughts?
Thanx
Rob
Any thoughts?
Thanx
Rob
GA
Not sure about the 7c but my 9c automatically turns on when I plug the adapter in to the back... and yes you need a battery...BUT...
the RF portion of the radio doesn't turn on and thats what uses the most power..... it barely drains the batteries at all using the sim....
and it is nice to practice with your own radio....
ON, CANADA
Exeter,
If anyone else has any suggetions on which to buy I would be more than happy to take them under advisement.
Rob
Rob
VT
AFPD is available in a "Commander" version that includes a controller, similar to G3.
You can also use your TX, if you get an FMS cable separately.
- Eric
- Eric
