Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Will 2 interlink adapters connected together work with 9C on G2 >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 05-14-2003 | 03:10 PM
Default Will 2 interlink adapters connected together work with 9C on G2
I have two G2 interlink tx cables with the square plugs. If I connect the 1/8' plug ends together with a coupler will this allow me to use my 9C with real flight? Thanks for any help.
GM
Old 05-15-2003 | 01:56 PM
It doesn't.
Old 05-15-2003 | 02:05 PM
Why don't you call RealFlight tech support and ask them directly?
I suspect that the problem is in G2 itself, which is not designed to support two planes on the same PC (I mean, without newtorking with another computer).
Old 05-15-2003 | 08:40 PM
Sorry, I didn't explain well.
I am using two cables coupled together only to make a single cable which goes from tha interlink to single radio, my 9C (so that both ends have square plugs). I'm only using one radio to fly one plane, just like with the interlink controller.
I called RealFlight support and they didn't know and wouldn't say. I've checked the pinout readings with my multimeter and they are identical on both square ends with no crossover. Does the gmz4064 adapter change some pins around or is it same-pin to same-pin?
Or does something special have to be done to the 9C (I just got it and haven't had much experience) to get it to transmit through the cable?
Thanks, gm
Old 05-26-2003 | 02:23 PM
You might try using a 9C to 9C trainer cord, it has the square plugs on both ends
Tod
