King Motors Baja Review with pictures
#2976
NY
RE: King Motors Baja Review with pictures
tgwolfwood1981definitely list the bearings you replaced please.
#2977
AL
this is directly from my ddm order receipt
qty item description
2 dd262 oil seal set (need two because km motors use two of the small oil seals.)
1 dd259 team fast eddy replacement rc/cy engine bearing set (there are a couple of different options for this, i just chose these due to budget restraints. the fast eddy ceramic bearings look really nice)
1 dd252 zenoah/cy rc/ lh crankcase gasket
1 ca425 cy/rc pin bearing
1 ca424 cy/rc pin washer set
1 ca423 cy snap ring set
1 ca321 zenoah rc cylinder gasket
total price before shipping was $35.65 worth every penny.
p.s. the km cylinder gasket was .045. the necessary gasket is .020. so a pretty big difference in compression, i would guess. also there is a great series of videos on youtube from fasteddy and dark soul racing on the the rebuilding of these engines.
#2982
ORIGINAL: KeithjV
Great. Thanks for the info. Im sure that will come in handy for a lot of people
Mike
#2984
ORIGINAL: 19red66
If you guys would go back and do some reading all this has been covered and part numbers posted, it would save a lot of double posting.
Mike
Mike
Now, I am not accusing anyone of spamming, but the repetition is at the verge of spamming.
#2986
We know, and you actually posted actual and knowledgeable information that most likely was not even addressed earlier in the thread.
#2987
My Feedback: (20)
ORIGINAL: KeithjV
Great info
now for my soon to be mod! and I don't have to take the motor apart.. lol
http://www.davesmotors.com/s.nl/c.88...t.A/id.4941/.f
#2988
CA
I just drove my CY 29 again tonight, which is the little brother to the engine you picked.... and again, as usual, it simply puts a grin on my face.
I upped the gearing to 18/56 with the reversed standard weight clutch and 8000 rpm spring and it pulls it just fine. HPI says if you use the standard clutch shoes ( not the one with lightening holes) the 8000 spring works like a 7000 engagment point, which I find just right.
The CY 29 is slowely breaking in and has required about four 1/32 adjustments over time. As break-in progresses it starts to seem a little fat and a 1/32 turn cleans it right up. My plug is still a little on the darker side and has not changed to the brown yet, so I know there is probably still one or two leaning adjustments in it yet, but I am sneaking up slowely on a good tune.
Just plain runs clean and very strong. It probably does not wind out as high a rpm as some others, but it is enough to make me think it is hauling a**.
Please let us know when your new monster arrives and how it all sets up
Dennis.
#2990
CA
Dennis, what oil are you using with your CY29?
It is working very well, but I don't see anything about it that makes me think it is any better than anything else. Since I have had it I notice no one ever mentions it. I also noticed it is more popular with snow mobiles.
If I had it to do over, I would have bought the Klotz DDM sells, but I really believe none of it matters as long as there is enough oil in the gas it could even be Walmart oil.
Dennis
#2991
NY
srt i once again agree with dennis,my gp290 is great,does put a grin on your face,powerful.as i said before i richened the high side a little because it ran so good i thought it might be too lean.it probably wasnt,i gotta pull the plug.that motor should be sick,im sure youll enjoy it.three pulls and youre runnin,dont have to mess with it,i wish this was the first car i bought,would have saved alot of money and less agravation.let us know about the new motor when it happens.let me ask,does anyone ever check the temp on a gas motor?
#2994
My Feedback: (20)
ORIGINAL: niko64
My issue is, I have gotten back into planes and need to get some 6s batteries for my CAP232 60 size, but at the same time want this motor..
My Baja has sat for over 4 months! ahhh
#2995
CA
That is great........ worried you that it ran so good.......LOL
I am sneaking up on the best tune, but I know what you mean. Compared to the 23 and the zenoah 26, these big CY's really carry the mail........ at least for my feelings.
Dennis
#2996
PA
OK something weird is happening to me wondering if its happened to anyone else... when i run my baja in the field here at my house i get grass that wraps around my drive shaft on the pull start side of the baja but it don't wrap on the other drive shaft .. when i say wraps i mean it loads up with grass but yet the other shaft don't get any grass on it don't make sense to me.. i was hoping someone else had the same problem and could tell me how to keep that from happening.because when the grass wraps its self around the drive shaft it tares the boot on the shaft..also how bad is it to run the baja without drive shaft boots.if i could get them without having to pay 7 dollars shipping from ddm i would just get them but i think its ridiculous that you have to pay 7 dollars no mater what you order for shipping. i mean it could be a fuel line i order and that can be mailed in a regular envelope and it would still cost 7 dollars to ship I'm not up for paying more to ship the part then what the part cost its self. not to be a cry baby but that's just bull poop lol.. ok thanks again all for any help you may be able to offer me on this issue...
#2997
NY
yeah tcb,two of my cv boots are ripped,same thing almost,i got a wig rapped around mine,gotcha beat.i dont know what do you do,replace the boots or just wait and buy new axles?i agree about the shipping thing,but i guess thats an average cost for all there shipping.so are the upgrated axles any better?
#2998
Get a set of darksoul axle boots,
i have 3 gallons on my stock dogbone axles and there perfectly straight so i just got the upgrade boots.
#2999
NY
so there is an upgrated boot?got home from work,fed and let the dog out,wanted to go for a blast.checked the plug like i said i should.not black,a little grey actually.its not fat.i richened up the low side idle came down,low side was to lean.i richened up the high needle a 1/16,running so good,stripped the spur gear.
