King Motors Baja Review with pictures
#4280
My Feedback: (9)
PA
RE: King Motors Baja Review with pictures
OH man i like it!!! let us know how it runs and handles..after break in..that rear shock tower looks a mile thick! NICE!!....wonder if I can sneek one more past the wife??...
#4281
ORIGINAL: 93octane
#4284
My Feedback: (9)
PA
I put the whole ss diff in mine.. but not sure about just the gears..unless you mean the main diff gear..internal gears look the same but not sure if they will work..somebody will chime in on this Im sure..
#4286
FL
magnum500 -
I happen to live below the frost line here in florida. The guys I work will tell me the last time it snowed here was 14 years ago. Got 2" and basically shut down everything for a day. LOL I went out and got my Christmas tree after work today in a t shirt and shorts. I will NEVER move back to NY!!! hahahaha BTW if anyone is interested, I got my new bearings in yesterday. Im gonna get the weight of all the stock ones to see how much lighter the ceramics are, then let ya's know.
#4287
GA
thanks for the info i was just trying to be cheap and it is hard to replace the hole thing when only one thing is wrong just one gear out of the six is broken if the case was gone then i could justify spending the 60 buck on one but,that is the jew in me.
#4289
ON, CANADA
johnnysplits
man i went out today without my gloves on . lol i think tampa needs some snow . it will bring back old memories .
i thought the ceramics did not hold up to the abuse the steel can take . keep us posted ... i like the idea ....of tampa and the bearings
#4290
FL
ORIGINAL: magnum500
johnnysplits
johnnysplits
#4291
CA
I think the problem is with the outdrives fitting with the HPI gears. I think the internal shaft of the KM outdrive is a smaller diamenter. Anyway, for something in the $50.00 range, you can get a new in bag SS HPI Baja aluminum cased diff, and all you have to do is assemble it. It also comes with the big gear around the diff that mates with the other transmission gears and new outdrives. Seems like the right thing to do. I did and it went very easy and everything fit.
Dennis
Dennis
#4292
I have had a KM Clone know for 4 months....and it is great. The only problem I had with it so far was the e-clips popping off on the wheels. Looks like the friction from the wheel turning might be causing it. A friend has a HPI Baja and he said that has happens to him also....We are now looking at a better fix for this issue!
#4293
GA
Streamlinerc I did the convertion on mine were you cut of the e clip and replace it will a m5 bolt and a washer but you have to tap the hole i dont know the page it is on but if you go thru my profile it is there or go to baja planet .com and it is there good luck
#4294
Hey well great that will help! I also sent the post you made to a friend of mine that is going to work on his. I will give that a shot as soon as I can......No more chasing tires down....lol
#4295
ON, CANADA
did anyone take their diff apart to check or add any grease ?how about adding loctite to any screws , nuts and bolts. i have not yet received my 5t yet but was thinking of doing a once over before the fun starts . also should the clutch springs be changed ?
#4296
FL
Well I wieghed just two different size bearings today and oddly enough, the stockers and the Acersweigh the same. (12x24x6) 10g. (17x30x7) 17g. Now the boca bearings are lighter...but just a little: (12x24x6) 9.27g. (17x30x7) 14.37g. Now does that warrant the $250 price tag? I was about to return the acers, but Ithink a good endurance test is in order here.
magnum500 - yeah, Iwould definitely clean all the grease off of the gears and replace with a high quality, high temp synthetic grease as well as dumping what looks like engine oil out of the diff and refill it with a thick diff lube. BigGrump also suggested changing out the stock tranny case for the HPI one to avoid fitment issues with aftermarket top plates. Mines on the way from ebay right now.
#4297
NM
500,I just took my tranny apart to day.here is what I noticed,missing bearing 6901,very little grease. everything else looks normal.I would change out the grease and use the metal trans case.
quickwedge
quickwedge
#4298
FL
oh yeah I forgot about that other bearing...alloy trans case, yes might as well grab a titanium layshaft too!!! I need to find a bag of money somewhere LOL
#4299
ORIGINAL: Johnnysplits
Bbuzzard, can't wait to see some vid of that Dune Runner. It looks well built.
Since nobody else is posting videos........
From today. The vid qualitysucks cause it was in a dark area.
[youtube]http://www.youtube.com/watch?v=b7ueyzNRxCU[/youtube]
