heli rookie
PA
heli rookie
Hi,
I would like to get into heli's and was wondering what is a good inexpensive radio to start with (I also fly planes)I was looking at a 6XHS any comments or suggestions ? Also does anyone know of a good book or web site with alot of info ? I looked at heliproz and was not impressed.
RE: heli rookie
The 6XHS will get you in the air but that's about it. It has no pitch/throttle curves and when your in idle up and inverted you only have 60% of your throttle. If your looking for a fairly cheap radio (and a good radio), I would recommend the Hitec Eclipse or the new JR 6102. These radio's will take you a lot further then the 6XHS.
WI
RE: heli rookie
I agree. The JR 6102 or the Hitec Eclipse. Another that looks like it would be a good choice is the new Futaba 7C.
A good site for info is http://www.littlerotors.com/ which has a wealth of info including reviews and flight instruction from hovering through aerobatics. Check them out.
Regards,
Mike
Regards,
Mike
AB, CANADA
RE: heli rookie
I agree, do not scrimp here...at least go to a radio that has 5-point throttle and pitch curve adjustment capabilities - the new Futaba 7C (love its' programming wheel), Hi-Tech Eclipse 7 or JR 6102.
TN
RE: heli rookie
ORIGINAL: fritch1969
I would like to use the same radio for my planes also, my planes have futaba receivers, will they be compatible ?
chris
NC
RE: heli rookie
Here we got....I have looked on [link=http://www.raptortechnique.com/]Raptor Technique(LOADS OF INFO)[/link] and found so much infro on just about ANYTHING heli oriented.
I suggest that you get a JR 6102 or like a JR 8103 if you can afford it and a Thunder Tiger Raptor 30 V2 Heli.....Heard lotsa great things......
NC
RE: heli rookie
yea, thats the stuff. thanks everyone
PA
RE: heli rookie
Ok, so far I ordered my hawk sport and picked up a futaba 7c tonight, the only things I need are a gyro and an engine, I'm thinking a PG2000 Dual rate Piezo Gyro and a tt39 or os32. What do you guy's think ? the wife told me what she thought ! lol
FL
RE: heli rookie
I am in the same boat as you, as I just purchased my hawk sport, but I just completed the rest of assembly, and just brought it back to the hobby shop to give it a once over and fine tune before first flight. I was told to definitely go with a better gyro, I bought the Futaba GY401, and was told it is an excellent gyro for this heli. (I spent 139.99) Also, I was told to definitely stick with the OS motors, as they are most reliable. I still know nothing about controls, but I know that if you spend a bit more now, it should save you a bunch later. I don't know about any futaba's but I went for the JR 8103, they had one that came with digital servos and was not much more than the controllers that were only 6 channels. Seems like there is a lot more room to grow with it, when ready. As like you, my wife's opinion was the same as yours, just like when she sees me on the simulator! Good luck.
