RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Eclipse 7, R-T mix
Old 04-28-2004 | 01:23 PM
Default Eclipse 7, R-T mix
Hi guys,
any Eclipse 7 clever person around?
I'm running Eclipse 7, QPCM, with a Raptor 50. Everything works allright, except for the Rudder-Throttel Mixing. I have every sorts of ways to get it to work. I can program the data into the transmitter allright, but I don't get any response from the throttel when I apply the rudder. Anyone seen this problem with Hitech before??
Appreciate a solution, I belive it will facilitate hovering.
Lars Fors, Santa Pola , Spain
Old 04-29-2004 | 01:21 AM
suc
Default RE: Eclipse 7, R-T mix
Remember that the function is only working in
"normal" flightmode.
Stig
Old 04-29-2004 | 06:59 AM
Yes, I know. but doesn't work in NOR mode.
LarsFors
Old 04-30-2004 | 02:29 AM
suc
Which value have You programmed into the radio? Which mode are Your radio,
1 or 2? Which sticks are You using for roll / nick and rudder?
Are You sure that You are in NOR flightmode. Have You tried other settings
with the flightmodeswitch?
Stig
Old 05-01-2004 | 06:34 AM
I have tried values from +-10 up to +-100 in the R-T mix menue, no difference.
I'm using left stick l-r for rudder, ch 4, and right stick l-r for roll, ch 1.
I'm positively in NOR mode, you can't set the R-T mix values in other modes.
I have tried all other switch settings I can think of, but nothing gives the R-T mix to function.
What do you mean with radio mode 1 or 2? Is that FM or PCM? I'm using the PCM mode.
Lars
Old 05-02-2004 | 02:36 PM
suc
In mode 1 the rudder is in the right stick and the aileron/ roll in the
left stick. If the radio is in mode 1 the r-t mix will work from the right stick.
You can try.
Stig
Old 05-02-2004 | 03:48 PM
OK, will try when I have recharged the batterys after this mornings hopping around.
Thnx.
LarsFors
Old 05-03-2004 | 12:03 PM
Heureka!! Found it! (Not with the mode 1 suggestion thou, which is not a good idea anyway, if you like to use one stick for roll-nick as in the real thing....)
The channel 7 switch must be in the forward position for the R-T mix function to work.
Nothing mentioned of that in the manual!!
LarsFors
