RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
tail drifting
Old 10-06-2002 | 05:31 AM
Default tail drifting
caliber-airtronics super 6000. getting slight drifting in hover,not [waggin] just drifting. how can i stop this???
Old 10-06-2002 | 07:55 AM
mongo's Avatar
My Feedback: (15)
what gyro/servo/tail blades?
is the linkage smooth and slop free, or does it drag or flex?
is yer motor adjusted properly, out of tune will make the tail move in increments
Old 10-06-2002 | 01:47 PM
guess i forgot to mention that i have a 401w\servo set up.everything is stock caliber.
Old 10-06-2002 | 07:03 PM
mongo's Avatar
My Feedback: (15)
did you do a mechanical adjustement to the rudder pushrod to stop any drifting in normal/rate mode?
you can use a small amount of trim/subtrim to get the last bit out if a 1/2 turn is too much, you do have to re center the gyro with the on/off of hh 3 times quickly after adding any trim. other than that, just always turn on the gyro in hh mode.
Old 10-07-2002 | 03:17 AM
no im a newbie and can really just hover wouldnt attemp to fly [no-hh] it is pretty steady in hover and just kinda wonders of staright and a quik jab at the stick brings it back maybe its me and thats just the norm??
Old 10-07-2002 | 05:02 AM
mongo's Avatar
My Feedback: (15)
don't be afraid to try normal
once ya get the mech adjusted so it is centered at stick nutral, it is hard to tell ya arn't in hh, unless it is really gusty.
also look here for some more experienced help ya can get with
http://p-locate.rc-helipad.com/
2 hours driving each way is money and time well spent. for good hands on help
Old 10-07-2002 | 05:30 AM
My Feedback: (8)
You might want to have T-gear on when you do it if you've never tried to fly a heli that was out of trim. I tiped my raptor over a week ago when I was setting up my 401/9253 with the same problem and I switched from HH to normal mode 3 times fast while hovering 8 feet up<lol, oops that's also the command to RESET the servo center position>.
Found out when I did my tear down I put my tail rotor blade grips on backwards which gave it LOTS of left and a little bit of right, it also made it drift.
Oh yes, make sure you never adjust anything on a heli unless it's a good 100 feet away from you!
Worst case your heli will want to yaw left or right a lot in normal mode. You just have to trm it out, find the mechanical position for a stable hover by using your trim then set it up so that with no trim it will hover in normal mode without any yawing. You get most of the rudder trim set by getting light on the skids, then final adjustments are in the air.
