Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 rx & tx battery maintenance >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 11-14-2005 | 12:53 PM
My Feedback: (21)
Default rx & tx battery maintenance
Im using the battery charger that came with my JR 9303 to charge my Tx & Rx batteries.
Im in Chicago and the weather has been for sh##.I foresee long periods of the batteries laying around,charged.I want to be able to re-cycle them(y'know,discharge,recharge)
WHo sells a good battery charger,recycler?
Joe
Old 11-14-2005 | 01:56 PM
BarracudaHockey's Avatar
Default RE: rx & tx battery maintenance
I use the Accucyle Elite, either that or the Triton are excellent. I believe the Accucycle can do two at once vice one for the Triton but I'm not certain. Its got settings for nicad/nimh/li-po and li-ion as well.
Old 11-14-2005 | 06:20 PM
My Feedback: (21)
Thanks Andy-I figgered you'd have some info.I shoulda just ased you.Ever think of starting your own info-site?
Joe
Old 11-15-2005 | 04:43 AM
Charlie's Avatar
I use the [link=http://www.hobby-warehouse.com/cicynibama.html]Cirrus Cycle Pro[/link], it works good but the only down fall is you can't charge lithiums, it only chargers/cycles Nicad and NiMh.
Old 11-28-2005 | 03:21 PM
For Tx you might consider switching to NiMH. They don't need cycling and don't have memory effect (reducing capacity when battery not fully cycled)
For NiCad packs, if you drain them before storage they should keep fine
Old 11-28-2005 | 10:04 PM
NIMH's self-discharge much faster than NICD though. They need to be peaked, even if left over night, which can kind of suck. I've had NIMH's lose 20% of their charge just from sitting over night
I think NICD would be a better way to go for a receiver battery. Besides, the only way you'd develop memory on a modern NICD cell is if you managed to discharge it to the exact same point over and over and then charge it again. Memory really isn't an issue with modern NICD cells anymore. It's an old tale that seems to persist even though it's no longer a threat.
Also, ALL cells should be cycled once in a while. Constant charging and discharging will imbalance individual cells. Fully discharging and slowly re-charging the cells will re-balance the pack. For the best performance and life from your batteries, you should cycle them every once in awhile, nicd and nimh both.
