Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 semetrical VS flat bottom ? >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 01-30-2008 | 10:58 PM
sportrider_fz6's Avatar
Default semetrical VS flat bottom ?
whats the difference between semetrical blades and flat bottom blades? I've figured out the flat bottom blades seem more stabile(at lease I think so) but what else are the differences when in flight. there on a Blade CP pro if that makes a difference.
Old 01-31-2008 | 12:24 AM
Default RE: semetrical VS flat bottom ?
Flat bottom blades are generally more stable. Symmetrical blades allow you to go inverted and utilize the negative pitch feature of the Pro.
The flat bottom blades create a low pressure above the airfoil. This allows the 'wing' to generate lift, and go up. Using these blades while in negative pitch wouldn't work because the heli would just want to go down(if you were inverted). Symmetrical blades will create lift in both positive and negative pitches. This airfoil is what all the aerobatic aircraft(Extra 300) and I believe fighter planes use- that way they can climb while inverted.
Hope this helps!
Old 01-31-2008 | 12:43 AM
thanks good to know!!! for now I'll be running the flat bottoms until I get basic flight control down and hovering. when I'm ready to try aerobatics I'll switch.
Old 01-31-2008 | 01:48 AM
Thats what I did- do you have the plasti flat bottoms?
Old 01-31-2008 | 12:32 PM
I'm going to see if my LHS has them, the wooden blades are way to fragile.~ strike that~ I just called, and they don't carry them looks like it's time to search the forum for someone who does. any suggestions? I'm going to run down and buy a couple sets of wood ones but unless some how it comes quickly to me I'm sure I'll burn through a few sets of blades quickly before I get it down!!! also what are good aftermarket landing gear choices the stock gear seems pretty fragile also.
Old 01-31-2008 | 02:31 PM
The plasti blades have some good things about them, and some bad.
Good: I got into probably half a dozen crashes while I was learning with the Pro and the plasti blades. These things are virtually indestructible. The blades stayed intact, but other parts of the heli took a hit.
Bad: The main shaft would bend, and the feathering shaft would most certainly bend. Sometimes the blades would strike the boom, and go right through both the boom and the wires for the rudder motor. It all depends on what you want. Woodies you can usually just slap on a new pair, and then you are up again. The plasti ones though will require you to replace several things.
Your choice though. Sorry, no recommendations on the landing gear- they are real crap. I switched helis before I made too big of a commitment.
Later!
