Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 07-19-2013, 04:22 AM
  #3126
CFII1974
CFII1974's Avatar
Default RE: C-ARF Ultra Flash build Thread + Video
The good thing about it being vinyl is you don't have to put it where they say to. I put mine in the white and like the look of it.
ID:	1902068   Click image for larger version
Old 07-19-2013, 10:38 AM
  #3127
spike5150
Hmmm... My yellow scheme I recieved in April the lettering appears to be painted on. Or if it is a vinyl sticker it was not obvious - will have to check later. If so the sticker was factory installed.
Old 07-19-2013, 11:24 AM
  #3128
Dave Wilshere
In April it was still painted...
Dave
Old 07-19-2013, 12:46 PM
  #3129
dubd
dubd's Avatar
I was expecting it to be painted. Made my day that is wasn't.
Old 07-19-2013, 01:07 PM
  #3130
CFII1974
CFII1974's Avatar
I must have been right at the cut off. I got mine mid April.
Old 07-20-2013, 02:07 AM
  #3131
Walo
Did someone measure the capacity of the fuel tanks?
Main fuel tank should have 2,2 Liter, mine has only 2 Liters. But it is a replacement tank.
It's not a Problem, because together with the saddle tanks I have enough fuel. But I realised it when I did some short flights with main tank only.
Regards, Walter
Old 07-20-2013, 03:14 AM
  #3132
SR117
I have fly navy scheme and navy is painted on...I'm very happy with that with that....build was may 2013
Old 07-20-2013, 04:53 AM
  #3133
bobg
I had to add the penny washer to mine to get CG spot on and model flying neutral
ID:	1902306   Click image for larger version
ID:	1902307   Click image for larger version
Old 07-20-2013, 09:22 AM
  #3134
Midas D.
Will be joining the club pretty soon
The long wait has begun........
Old 07-20-2013, 03:15 PM
  #3135
Gixxy
My Feedback: (18)
Hey guys just a quick question. Trying to figure out where I could pick up a steering pin for my front strut. I had a buddy order my landing gear package for me about 4-5mo ago and just finally getting around to getting this build going and come to find out I was missing a pin. Also needed to pick up the 4mm set screws for my behotecs c36's since they didn't have those installed but easily found locally. Everything was new in package. No biggey but I'm hoping to find a steering pin quickly Who would be my best point of contact ? Anyone have a spare laying around ?
Oh and the current build/assembly is a UF in the swiss scheme with a K-140G for power. Saw quite a few of these birds and even flew formation with a couple up in Kentucky this past week and now I'm stoked to get this thing going Love the thread, lots of useful information !
ID:	1902471   Click image for larger version
ID:	1902472   Click image for larger version
Old 07-21-2013, 11:59 AM
  #3136
Gixxy
My Feedback: (18)
To be specific I need the this part . Emailed a few places but no response as of yet.
Old 07-21-2013, 01:28 PM
  #3137
sailing1
My Feedback: (134)
I would think the company you ordered the gear from should supply this to you. But if that doesn't work you might try dropping an email to Peter at Altrecare. He carries the full line of Behotec gear.
Old 07-21-2013, 02:10 PM
  #3138
sc0tt
My Feedback: (61)
sc0tt's Avatar
The steering arms are CARF part # 630516
http://www.carf-models.com/public_ca...art&proId=1594
Not sure what the official Behotec part # is ???
Old 07-21-2013, 02:12 PM
  #3139
Dave Wilshere
Someone has mistakenly packed a trunion pivot pin and not a steering pin. If its a CARF gear set first point would be Andy K. But its a Behotec part.
Dave
Old 07-22-2013, 07:39 AM
  #3140
Ragz
Ragz's Avatar
I am building my second ultra flash after having sold the first one 2 years ago. Can someone tell me the lengths of the flap linkages? I can do it by trial and error but rather have the ball park lengths.  I decided to use hitec 645MG servos for the flaps in the inner most hole, I reckon this is enough for the flaps????
Thanks in advance.
Old 07-22-2013, 08:23 AM
  #3141
Dave Wilshere
ORIGINAL: Ragz
Thanks in advance.
Whats wrong with my ball park figure in the UF update?
Spend some time setting the Flap pushrod length before fully screwing the cover plate down.
The threaded rod should be approximately 50mm long and a good starting point for the push rod centres would be 75mm. This is centre of ball link to clevis pin.
Actually 72mm is about perfect.
Hitec...MMm Check for up travel current draw as if they are normal Ht servos it will vary!
Dave
Old 07-22-2013, 08:30 AM
  #3142
Ragz
Ragz's Avatar
Hi Dave.
What's wrong is that I didn't read your update. My bad. Thank you.
Anurag
Old 07-22-2013, 08:47 AM
  #3143
Dave Wilshere
No problem...hopefully most stuff is there, or email me any questions. I'm just building two Ultra Flash models for friends, so information is fresh :-)
Dave
Old 07-22-2013, 09:26 AM
  #3144
dubd
dubd's Avatar
ORIGINAL: Dave Wilshere
Dave
Agreed! Those 645s burn up like bacon on a frying pan.
Old 07-22-2013, 10:32 AM
  #3145
Gixxy
My Feedback: (18)
Hey guys, Andy Kane got me taken care of with the steering pin. Thanks for the replies and help pointing me in the right direction ! Always appreciated
Old 07-22-2013, 10:56 AM
  #3146
Dave Wilshere
Cool, love it when a plan comes together
Old 07-22-2013, 09:58 PM
  #3147
Ragz
Ragz's Avatar
Hmm.. will change the 645MG servos with digitals.  Toying with the idea of using a 180rx that I have, versus buying a B100F specifically for this plane... seems like a bit of a waste at the moment.
Old 07-22-2013, 10:10 PM
  #3148
dubd
dubd's Avatar
ORIGINAL: Ragz
I'm in the same boat... the 180 will sure be fun though.
Old 07-22-2013, 10:17 PM
  #3149
Ragz
Ragz's Avatar
absolutely funnnnn.  only concern is the fuel capacity as I dont intend to use the saddle tanks..
Old 07-22-2013, 10:27 PM
  #3150
dubd
dubd's Avatar
I'm only using the main and wing tank. I'd set my timer at 5:30 and go from there. I also have a 120SX I could throw in it, but I might opt for the 180 just to try something different as this is my third Flash (second Ultra).
