Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 12-14-2014, 08:45 AM
  #4576
raron455
My Feedback: (38)
raron455's Avatar
Midas, what measurement did you put your CG at, did you mount the turbine at the forward part of the rails?
Old 12-14-2014, 10:17 AM
  #4577
cbooth1979
My Feedback: (22)
Midas, Looks awesome! I thought you were going with K100g, did you change your mind? How are you doing your cg...upside down, upright?
Old 12-14-2014, 11:06 AM
  #4578
Midas D.
- Not sure how tail heavy exactly, played with 50gr, and that was not enough, have to play some more.
- Put CG exactly as per manual on Carf website for UF (not CF as in the booklet), and the engine is as far forward as it can all the way up to the rails
- I'm going for the K100 in the Magenta one witch is in progress, Berto from RemoteJets started on the wings for me (post #4571) so then i got one with K140 and one with K100 for when things go **** up.... Did CG upright.
Old 12-14-2014, 11:51 AM
  #4579
Dave Wilshere
You can go back.My "safe" position for first time UF drivers is conservative. Having been there, I'd go 232mm straight off.
Dave
Old 12-16-2014, 12:00 AM
  #4580
DominicM
DominicM's Avatar
Just acquired my first UltraFlash. Going through the first few pages of this thread and couldn't find the setup for some of the throws/rates/expo. Would be grateful if someone could point me in the right direction. So far have got this from one of Dave's early posts...
FLAPS: Take off 25-28mm. Landing 95-100mm both figures measured at the root, trailing edge of each flap. The Ultra Flash requires down elevator with flap. Take off 0.8mm and Landing 4mm measured at the elevator trailing edge tip. Exact figures will be affected by balance position.
CG: Gear up 220-225mm back from the wing/fuselage joint.
Old 12-16-2014, 12:04 AM
  #4581
Dave Wilshere
Dom
All comes down to what you want from the airframe, do you like sharp, soft, responsive, F3a!
For you go back to 230-235mm on balance.
Some like less flap and CROW, the UF has plenty of control power, so set up accordingly.
Dave
Old 12-16-2014, 12:26 AM
  #4582
DominicM
DominicM's Avatar
OK. Thanks Dave. I'll go with what I do on all my jets and go with 3 rates and 30% expo on everything and work it out on the maiden. Selected rate tends to depend on my caffeine level on the day. See you at CJ61.
Old 12-16-2014, 02:33 AM
  #4583
paulhat
Hi Dom,
You will love the Ultra Flash. It just makes you want to fuel up and get back in the air.
Here is proof from this morning. New Jersey modeler is so shiny
Old 12-16-2014, 04:58 AM
  #4584
Dave Wilshere
If CJ is the maiden we can talk through movements and I can even spot for you. Elevator I usually have more expo on down than up by 5% and I'd punch for 35% (40%) but like I say if its there I can eyeball the correct figures.
Dave
Old 12-18-2014, 11:12 AM
  #4585
Midas D.
Next
Old 12-18-2014, 02:27 PM
  #4586
raron455
My Feedback: (38)
raron455's Avatar
Midas, are you building a new one there?
Old 12-18-2014, 10:37 PM
  #4587
Midas D.
Jep, building a new one/ second one as back up
Old 12-18-2014, 11:06 PM
  #4588
andretorres89
andretorres89's Avatar
[QUOTE=paulhat;11938941]Hi Dom,
[quote]
It sure feels that way! Did 7 flights on mine this past Sunday. My gas can was empty haha. Now I have a grand total of 24 flights on it.
Loving it!
Old 12-21-2014, 03:15 AM
  #4589
Midas D.
Here we go again
Going to try to break the speed record building wise
ID:	2056596   Click image for larger version
ID:	2056597   Click image for larger version
Old 12-21-2014, 03:29 AM
  #4590
Dave Wilshere
Originally Posted by Midas D.
Here we go again
You are just making work! The tail cone tab will need cutting down (especially when you open the back of the fuselage opening towards the top like it needs!
Old 12-21-2014, 04:22 AM
  #4591
Midas D.
Huh?? Got an pic.of that, confused here??
Old 12-21-2014, 05:29 AM
  #4592
Dave Wilshere
Mmm don't have camera card here showing the work, but here is a picture showing the start of the line I would dremel to. The top (bottom on this shot) lip needs reducing to around 5mm so that the out cool pipe sits in line with the tailcone and everything lines up. The matching face on that needs the hole opening too.
ID:	2056608   Click image for larger version
Old 12-21-2014, 07:35 PM
  #4593
NICKELUP
My Feedback: (82)
Originally Posted by paulhat
Hi Dom,
How do you like your new jersey modeler? I was planing to order one until I found out he doesn't carry the shorter tank anymore he has switched it to the longer one. Do you think it's to tall?
Old 12-21-2014, 11:27 PM
  #4594
paulhat
I think the tank height is fine. Would I prefer the previous size tank...Yeah probably. But I think I will get used to this one quick enough.
I have had it in the back of my ute a few times and it hasnt fallen over.
The variable speed pump is great for easing pressure on the UF main tank (which seems to always have a leak somewhere). Also comes with a charger which is pretty handy.
Old 12-22-2014, 04:25 AM
  #4595
Midas D.
Dave,
Check, know what you mean now!
But saying this, is this not something for Carf to look in to and do some changes so they make it fit?
Also the gear base alignment in the wing, this is also alway's off.... Post #4571
Old 12-22-2014, 08:08 AM
  #4596
NICKELUP
My Feedback: (82)
Thank you paul. I prefer the shorter one too.
  #4597
NICKELUP
My Feedback: (82)
I am using the stock behotec gears with the one big air tank that comes with it, and I can't get the tank in the nose.
do I need to grind some of the wood away?
Old 12-22-2014, 10:51 AM
  #4598
Midas D.
Jep, grind some of the wood away on the top side, otherwise you will never get it in the nose.
Old 12-22-2014, 01:27 PM
  #4599
SR117
Paul where did u get the tank from in AUS
Old 12-22-2014, 02:30 PM
  #4600
paulhat
Hi SR117,
I ordered it through Phil Celima at Jet Products Australia http://jetproductsaustralia.com/about_us
Service was really good. The tank was actually shipped direct from America and was here in less than 2 weeks.
Paul.
