Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 02-09-2017, 04:15 AM
  #5551
VK96
Yep, yellow and sliver. Here's a stock pic, but I'll post some actual ones once it arrives. The only change I made was to the underside...Instead of solid yellow I went with a checkered yellow/ silver pattern.
Old 02-09-2017, 04:46 AM
  #5552
wblombard
I have the identical scheme as per your picture! Lovely plane...wish I can say it fly's well but I dont know yet
Old 02-09-2017, 05:25 PM
  #5553
VK96
I actually owe you a bit of gratitude...I had just placed an order with Linda for a Yellow Checkered version when I stumbled across your earlier post/ pic. Called her back right away and made the change...so thank you!
Old 02-09-2017, 09:13 PM
  #5554
LA jetguy
LA jetguy's Avatar
I really like this scheme... where did you order it from ??
Old 02-10-2017, 02:14 AM
  #5555
Dave Wilshere
http://www.dreamworksrc.com/catalog/Carf-Models
Its a custom scheme, so speak with them!
Old 02-10-2017, 08:51 AM
  #5556
VK96
Linda at Dreamworks got me squared away. Because it was a custom scheme it wasn't going to be ready in time make their next container. That would've meant a late spring/early summer delivery. Opted for DHL shipping which should take about week once ready.
Old 02-10-2017, 12:11 PM
  #5557
JSF-TC
JSF-TC's Avatar
Have been working on my Ultra Flash, and after pulling the engine (Merlin 140XBL), I noticed that the ducting around the rear of the engine has discolored, turning white. It is noticeable both inside and out, and to a lesser extent on the removable (lower) half too.
I am assuming that this is caused by thermal distress.
I have 58 flights on the plane, the first 45 were with a Wren MW54 SuperSport, and the latest 13 have been with a Merlin 140XBL. I didn't notice any discoloration when I upgraded from the Wren.
The discoloration aligns with the rear part of the main body of the engine, and the area around the exhaust nozzle shows no sign of any color change, nor does the carbon bellmouth.
Is this a normal color change with use, or do I need to change something (maybe move the engine in the duct)?
Paul
Old 02-10-2017, 12:24 PM
  #5558
Dave Wilshere
Paul
What tailcone turbine to tailpipe tube gap do you have? That's way forward of the tailpipe with the carbon cone. Can you photo the turbine install?
Old 02-10-2017, 12:46 PM
  #5559
JSF-TC
JSF-TC's Avatar
Dave,
Here's a picture with the engine and upper duct half installed.
Not sure where you are suggesting measuring the turbine nozzle to pipe distance from - aft end of the engine nozzle to the start of the stainless thrust tube?
Paul
Old 02-10-2017, 12:55 PM
  #5560
Dave Wilshere
Paul
Yes, but all looks good. Tailpipe on turbine looks like it runs quite hot, but that may be typical of JM 140's
Anyway, no harm on the duct drying out, its just running a little hotter than i'd say is normal. You could BVM Heat shield it, but I'd say no real harm
Dave
Old 02-10-2017, 06:10 PM
  #5561
DrV
DrV's Avatar
Dave,
Paul
I have the same engine with same setup. My upper duct cover also looks exactly like yours. I just used BVM Heat shield just like Dave suggested. I have had about 100 flights now without any problems. I believe (my guess and opinion) this happens because the Merlin is shorter with shorter tail cone then other engines. The EGT temps run in high 500s to low 600s without any problems. Most of the heat buildup is after shutdown during the cooling cycle and I use a fan to blow out the residual heat.
Old 02-10-2017, 08:45 PM
  #5562
LA jetguy
LA jetguy's Avatar
Its called the "Camin" scheme... I have a option to wait for the container or go with DHL express shipping !!!!! How much was DHL shipping?....
This will be my UF#3.... will be powered by a Merlin M200 like my first one (Black Eagle scheme) and MKS servos....
David
Old 02-11-2017, 07:19 AM
  #5563
VK96
David
Having a hard time finding my invoice for a breakdown of the price. If memory serves it was around $350-400 to NH...meant ~$150-200 more than shipping from FL if coming from DW. Hopefully a little cheaper since you're on the West coast as it comes from Thailand!
Old 02-11-2017, 07:25 AM
  #5564
scoeroo
My Feedback: (9)
scoeroo's Avatar
I have the same colouring as well , been running merlins from day one , a couple of hot starts I think was the reason for my discoloration but nothing to worry over
Yes - the merlin end cone is some what shorter and the radiant heat after flight is another viable reason for discoloration
Old 02-12-2017, 05:54 PM
  #5565
JSF-TC
JSF-TC's Avatar
Thanks for the feedback on the duct discoloration - will keep track of it as I put more flights on it.
Paul
Old 02-18-2017, 02:49 PM
  #5566
VK96
Looked what just arrived! Won't be able to get into the build for about week unfortunately. Got a question for the guys using the Mp-Jet clevises with the M2 Secraft arms...did you use the M3 2mm or 1.6mm pin version?
ID:	2201735   Click image for larger version
ID:	2201736   Click image for larger version
Old 02-18-2017, 06:45 PM
  #5567
F1 Rocket
I use these: http://www.espritmodel.com/clevis-th...-2mm-m3-6.aspx
The photo on the web page is of a Bobcat I built
I drill the hole in the servo arm slightly undersized so the pin is a very tight fit. This minimizes any slop over time. Also, make sure the clevis is aligned with the servo arm and/or control horn. Any misalignment will cause the clevis to open and you will not be able to install the E-clip.
Old 02-18-2017, 08:10 PM
  #5568
VK96
Thanks Danny...exactly what I needed to know!
Old 02-19-2017, 12:48 AM
  #5569
LA jetguy
LA jetguy's Avatar
Congrats.... looks awesome. I ordered the exact same scheme with large checkered bottom. Can you post a picture of the bottom as well...
Old 02-19-2017, 06:51 PM
  #5570
VK96
Here ya go...
ID:	2201900   Click image for larger version
Old 02-19-2017, 08:27 PM
  #5571
ucandoit
My Feedback: (27)
Has any one used the Pro-Link LGC15 Controller and Sequencer for Electric Retracts ? I'm trying to get it set up and wanted to see what setting would work best in my UF Thanks
http://www.dreamworksrc.com/catalog/...ctric-Retracts
Old 02-19-2017, 10:38 PM
  #5572
LA jetguy
LA jetguy's Avatar
Here ya go...
I think mine is more checkered ... how long did it take from the time you ordered till it was shipped ?? What turbine and retracts you will use ?
Old 02-20-2017, 05:01 AM
  #5573
VK96
5 Weeks from order to shipping, arrived 3 days later. Using a K140G2 and Electron gear
Old 02-20-2017, 05:29 AM
  #5574
LA jetguy
LA jetguy's Avatar
Thats great
Im planning M200XBL with Behotec C40's.... like my current black eagle (post 4828 here)
Old 02-25-2017, 06:59 AM
  #5575
VK96
Hoping to get a little work done today. 2 questions (with more to follow I'm sure!). First, I've read that the main gear typically requires "packers" between the retracts and the rails. I'm using the Electrons (retracts and struts), and am curious how to determine if it's necessary? Are you trying to make sure the wheel is flush with the fuse when retracted?
Second, when mounting the turbine (k140G2) how much space should be left between the exhaust cone and the beginning of the bell-mouth (specifically the former it's mounted flush with)?
