Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 07-26-2016, 04:37 AM
  #5301
Johnny9390
My Feedback: (34)
Dave where can I get those new felt clunks with the larger holes?? Which website?
Old 07-26-2016, 05:28 AM
  #5302
Dave Wilshere
We can't sell to the US market, don't know of anyone who will.
Anyone coming to JP in September? We will have stock there.
Dave
Old 07-26-2016, 06:21 AM
  #5303
737Driver
737Driver's Avatar
Hey Johnny, I've got a handful of them I bought from a RC company that sells in huge bulk amounts of various RC products both domestic and international, (not naming who, can't promote!) Any who, PM me with your address and I'll pop one in the mail. Take a look at it when you get it, if you want it great! If not, no worries either, I have a bunch of them.
I'm ALMOST finished with my bird. Got the canopy all glued up, sprayed on the inside with the Tamiya smoke, turned out pretty good. I'll post pics later today.
Tom
Old 07-26-2016, 10:52 AM
  #5304
737Driver
737Driver's Avatar
Ok, thought I would post some pics for ya'll. Canopy turned out pretty darn nice for my 1st time. Used the standard canopy glue, the 560 glue, on all the points were the transparency actually touches the frame. Once that dried I went from the inside and used a two-part epoxy, PC7, to seal the transparency up against the frame. Once all that dried I went back over the outside where the transparency is against the frame and used a toothpick to scrape away excess dried glue. Then I kind of buffed it out with a soft cloth and rubbing alcohol to get the smear marks off. A little Plexus plastic polish, good to go! The inside of the transparency it was sprayed with the Tamiya smoke paint, not really happy with that but it's good enough. My friend Eric did a really nice touch up job where I cut the wrong hole for the rudder servo arm out the vertical stabilizer. All that's left is nose gear door and equipment mount I'm done!!!!
Old 07-26-2016, 10:55 AM
  #5305
737Driver
737Driver's Avatar
Inside of canopy assy.
Old 07-26-2016, 10:56 AM
  #5306
737Driver
737Driver's Avatar
Vertical stabilizer hole repaired
Old 08-09-2016, 05:43 AM
  #5307
Johnny9390
My Feedback: (34)
How many of you running your flash without a bypass? If not using a bypass does it need at least the upper bypass for turbine to sit on or can it just sit there without anything mounted on the rails? With a little aluminum heat shield or BVM heat shield painted under turbine?
Old 08-09-2016, 10:44 AM
  #5308
tellmic
Johnny,
Since you are located in Florida it is better to run with the bypass. The advantage of using the bypass is better engine cooling and less noise aswell. Another advantage recognized by others is less drag when throttled back in a high speed pass.
I'm using 160 to 180N with bypass installed.
Michel
Old 08-10-2016, 03:10 AM
  #5309
philjac94
philjac94's Avatar
No Bypass and no heat shielding in mine only NACA ducts....no heat issues, no excessive noise issues and engine runs perfectly fine without the full BP duct. Rear fuse heat issues normally occur in a Flash more so with full bypass installed than without.
Old 08-10-2016, 05:00 AM
  #5310
sailing1
My Feedback: (134)
Mine has way over 300 flights on it with both a 19 lb Rabbit and 31 lb Cheetah and no bypass. It gets pretty hot in Oklahoma (heat index today is supposed to be 111) and I have never had any type of heat issue. I do have the NACA ducts.
Old 08-14-2016, 09:27 PM
  #5311
Johnny9390
My Feedback: (34)
Thanks no bypass for me then. Kiss method
Old 08-15-2016, 04:29 AM
  #5312
scoeroo
My Feedback: (9)
scoeroo's Avatar
The by-pass can also be a safety device in the case of a minor wet start by encasing any flame present , thus protecting any exposed close proximity wires
I prefer the by-pass for this reason
Old 08-20-2016, 04:38 PM
  #5313
737Driver
737Driver's Avatar
Well folks, tomorrow at 0900 at Kingdon Airpark, is the maiden voyage of the Ultra Flash! I've double checked, triple check ALL systems, I believe she's ready. CG is set, gear works great, all throws on all control surfaces are set per the book on low/medium/high rates and expo set. I did program aileron differential, mixed rudder/aileron for coordinated turns, and I'm going to TRY crow, I know I know, it doesn't need it! I just got used to it with the Classic. I'll try approaches with crow, and with out crow. I'm excited/nervous/anxious, but confident. Any last minute advice would be appreciated!
Old 08-20-2016, 05:53 PM
  #5314
Steve N.
Good luck (and management) on your maiden Tom. I'm sure that all will go just fine, and you'll have many more excellent flights in the future.
Steve
Old 08-20-2016, 06:31 PM
  #5315
sailing1
My Feedback: (134)
Good luck with the maiden. I have both Classic and Ultra and use Crow on both. Just remember the Ultra will not bleed speed as fast on landing as the Classic, but it will still bite you if you get it too slow. Just enjoy the ride and fly it all the way to the ground. You will love the plane!
Old 08-20-2016, 10:21 PM
  #5316
Johnny9390
My Feedback: (34)
Maidened my flash yesterday and all went great. Except second flight about 3 mins in had a flame out. Landed and noticed hopper was empty and main tanks full. Mine is setup to draw from wing tank to main to hopper. Wings were empty, main full and hopper empty. Used the newer felt clunks with larger holes. Gonna try and figure out what is going on. Other than that she flew great for a hybrid Flash. Has Classic wings without tanks made to look like UF and has UF stabs. Flies great and super fast!
https://www.facebook.com/johnny.oliv...53791696310924
Old 08-20-2016, 10:22 PM
  #5317
Johnny9390
My Feedback: (34)
Old 08-20-2016, 10:23 PM
  #5318
Johnny9390
My Feedback: (34)
  #5319
Johnny9390
My Feedback: (34)
Old 08-20-2016, 10:24 PM
  #5320
Johnny9390
My Feedback: (34)
Old 08-20-2016, 10:26 PM
  #5321
Johnny9390
My Feedback: (34)
Old 08-20-2016, 10:27 PM
  #5322
Johnny9390
My Feedback: (34)
No Bypass on mine.
Old 08-21-2016, 01:50 AM
  #5323
i3dm
My Feedback: (51)
Thats a nice flash you have there Johnny!
Old 08-21-2016, 02:04 AM
  #5324
philjac94
philjac94's Avatar
Cannot see from your photo, but what are you using for your fill valve, a lot of guys were using festo self sealing quick connects which are prone to drawing in air iwhen not connected. In any case, here is the first place I would look.
Old 08-21-2016, 04:29 AM
  #5325
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Hi Guys.
Getting close to pulling the trigger on a new UF. I have been reading this thread and the thought of gear problems....hanging in the well does not appeal to me. I am a firm believer that a good flight starts in the shop so its important to have proper clearances and such. With that said there seems to a lot of variation between retracts and struts being used. I don't want to re-engineer the wing to get gear to fit. Is there anything truly drop in for this plane? It seems that the Behotec C36/2 may be the way to go but I don't see these offered on the CARF website. Attached is a picture of their current offering. Those wheels look hideous! I don't know who manufactures this retract package. They look to be stamped CARF. Your comments are appreciated!
