 AirPower Five Action Multi-function Valve...? >
Old 10-27-2010 | 02:09 PM
Default AirPower Five Action Multi-function Valve...?
Hi guys..,
i'm trying to set up the EV5U valve in mode 3 position.
First of all the plane is a Hawk.I have the additional valve that's required when using the mode 3 setup.
I'm pointing out this because that's gonna help you to understand why i'm using mode 3 on setup of valve.On this mode the rear doors close after the gear is down for landing but nothing happens after the gear is down.The doors doesn't close again.Why?
I'm trying with the card to make some combinations ,as to reverse valves or gear or the door sequence but nothing....!
What am i doing wrong guys?
Thanks in advance for any replies....
Old 10-27-2010 | 02:45 PM
lov2flyrc's Avatar
My Feedback: (24)
Default RE: AirPower Five Action Multi-function Valve...?
You have to plug the additional valve into the EV5U on door 2 output and program the time delay and direction for the valve through the card.
Old 10-28-2010 | 01:03 AM
Hi Todd,
yes i did that but nothing happen for one more time. Even I plug the additional valve into the EV5U on door 3 output to see if something gonna change but nothing at all.
I don' know what other options i have to do....
Old 10-28-2010 | 02:00 AM
Alex48's Avatar
Does the valve work normally using Mode 2?
Old 10-28-2010 | 03:03 AM
Yes,the valve work normally on mode 2...
Old 10-28-2010 | 05:36 AM
Just a thought, have you plugged the extra valve in the right way round as the jr type plug is very easy to get wrong?
