The Aermacchi MB339 is here agian
#426
RE: The Aermacchi MB339 is here agian
Well after the last post I made Zee has contacted me again and has very professionally changed his attitude and we are working on a solution to his misfortune. Please I would like to keep this as positive as possible and focused on working to help the people that have this kit so if you have any questions please call me or email me and I will answer you as best as I can.
#429
Koodos to all for finding a solution!!! Now can we all get back to the post and finiding answers to our questions...
Keep your wings level and nose pointed up towards the sky!!!
#433
Just wanted to show the progress on the 339s that are being built by my close friend and jet master Larry Z.
Three images...
Custom cockpit (handmade seat) and pilot
Spar sandwiched with CF
Spaghetti of wires before being cleaned up and arranged accordingly
Three images...
#434
Here are a few more images from the build. As you can see the use of Carbon Kevlar cloth reinforcing the wing spar, as well as the use of NACA inlets.
Hope this helps all building the 339...
#436
Larry is probably the best modeler and pilot we have here in El Salvador... trully a master at his craft!!!
Will post more pics when done... Should be starting the turbine before friday at the latest weather permitting!!!
#437
Final stages of completion but would really appreciate if someone could help me out with the following:
What is a good basis weight for the 339 with full UAT?
How have you strapped the fuel tank so that it doesnt rotate inside the fuse and on the formers?
How has the UAT been installed and held in place in the fuse?
If there are any images please post!!!
Luis
Luis
#438
Luis this is how I secured my tank, Just a small 90* aluminum angle Hysol on the tank and screwed with a servo screw to the former. and the UAT is strapped to the wheel well.
#440
My Feedback: (81)
ORIGINAL: Modellbau USA
First of all to answer your question Baldeagle, they wing did not come off clean from what I see it was ripped off the airplane along with the whole center section of the wing. I dont work for the NTSB nor do I say I do but the airplane wing was assembled very wrong. Not becuase of lack of instructions but becuase of lack of common sense. Who ever has bult jet kits before and this is a kit not your off the shelf bind and fly model, knows that things need to be built from experience. If he had questions he should have called me. Nobody here except for Kenric or Luis tona has ever picked up the phone or sent me an email asking for help.
And as for me not helping Zee it's becuase of his demanding and harsh attitude through several emails we sent to each other before I even posted anything. Im sorry to tell you but nobody tells me what to do or demand me to do anything. I am no longer in the military and he is not my commanding officer to order me to do anything. For the people on RCU that have delt with me know I will bend over backwards to help somebody. I had a guy in Central America destroy a Tornado becuase he pulled to many G's on a outside loop while full power with a K80. We discussed it he sent me pictures and we agreed it was a mistake he did not the aircraft. I then gave him a new aircraft with struts wheels and brakes, servo's and then I contacted King Tech and asked Barry if he could help this guy out. Barry as well helped and we both gave him an engine way below factory cost and assumed the difference in cost. The difference is that he did not demand me to do it and tell me it would be bad for my buisness if I dont fix this form him like Zee did.
Everybody is quick to blame to the manufacturer for everyhting when an accident happens and any body who is in aviation can tell you Pilot error is the number one cause for accidents. In this case assembly error. And dont blame the instructions, before this batch of planes Modellbau sold over 300 MB 339's since the kit came out and nobody complained or had problems building it. The problem is that everybody now wants a kit to practically fly by its self out of the box. I have contimplaited several time to stop RC production becuase of the attitutde of some of you guys that are loyal to other manufacturers or other hobby shops that I have caused large sales decreases to becuase of my products and how in expensive I am selling them. It will not change if I have to sell Tornado's for $399 and F86D for $599 I can care less how that effects these people. Some how they will learn that a Turbine does not need to be marked up 300% and gouge the customer to make money.
Jeff
#441
My Feedback: (10)
NV
OK, now that all this ugly mess is behind us (I have been avoiding this thread) lets move forward.
Today I started on my MB339 build. I am making several changes to the basic airframe to get it to a level I am comfortable with. What I would like to know is have we figured out the PROPER way to mount the wing and would anyone have pictures of this mounting system?
TIA...
TIA...
#442
Maiden flight has been done!!! Flight went on without a problem... everything worked perfectly except for a small issue with the brake fitting that was quickly fixed on the field.
I have to say that this jet is an incredible flyer. Handles the wind with ease, and lands a bit hotter than a regular sport trainer jet.
Will post pictures soon.
Thank you Alberto and Henry for an incredible airplane!!!
#444
Unfortunately no video... If weather permits Sunday should be full of excitement!!! Flew the MB339 with 30-40 mph gusts of wind and it handled it quite well.
#445
InboundLZ,
Both Larry and I have mounted the wing using the halfmoon wood block as well as using wooden dowels to prevent rotation on the wing. We then proceeded by using steel bolts to screw the wing in place using blind nuts mounted on a solid piece of plywood. Look at the pictures in the gallery of the forum and I am sure that this issue will be solved. At the same time, the wing former has been reinforced using carbon kevlar sheeting.
Hope this helps.
Luis
Hope this helps.
Luis
