Reload this Page >
COMP-ARF A-4 BUILD
COMP-ARF A-4 BUILD
Old 04-27-2011, 10:43 AM
  #76
bang68
Default RE: COMP-ARF A-4 BUILD
David !
How is it going :-)
Peter B
Old 10-05-2011, 01:02 PM
  #77
David Searles
My Feedback: (49)
ORIGINAL: bang68
David !
How is it going :-)
Peter B
Hello Peter,
I apologize for taking so long to get back to this!
The AirWorld F-100F kinda pushed it's way ahead of the A-4, so I decided to finish the Hun. The A-4 will be back on the table in the coming weeks. My remaining issue is getting the hydraulic nose steering to function properly and reliably.
I did take Cg and surface throw measurements directly off of Andreas' A-4 at CA Jets earlier this year, which will be great help once I reach that point.
David S
Old 10-05-2011, 02:41 PM
  #78
bevar
My Feedback: (27)
bevar's Avatar
Dave,
Get off of the computer and get back in the shop!
I want to see the A-4 fly!!!
Beave
Old 11-09-2011, 08:58 AM
  #79
wimpy1
hi dave,
does you have any pictures for assembly the airbrakes on the fuselage?
regards
wim
Old 01-18-2012, 12:08 AM
  #80
JustJets
My Feedback: (15)
Have a Big Issue with my Comp ARFA4.
My Fuselage is ser number 7811011006101, and my wing sets are 7812010807102, both tail and main wing.
And of course they do not fit or bolt in place. Was wondering if any one else had a missmacthed kit?
Old 01-18-2012, 06:03 AM
  #81
David Searles
My Feedback: (49)
Not sure what you mean by "do not fit or bolt in place"? Other than the two halves are not completely pushed together, I don't see the problem. Maybe you just need to trim the dowel or adjust the socket a bit?
David S
Old 01-18-2012, 08:20 AM
  #82
bang68
What stops the wing against the dowel holes ?
Peter B
Old 01-18-2012, 08:58 AM
  #83
wojtek
My Feedback: (73)
wojtek's Avatar
the detail on the CARF a-4 looks super ! !I wish CARF had put as much time into the detail in their P-47 .. great plane, however i will need to go over and redo most if not all of the surface details to look as good as this...
~V~
Old 02-14-2012, 07:04 PM
  #84
AndyAndrews
AndyAndrews's Avatar
Here is an update on our build. We (Bill White is my builder) decided that the rudder was not to scale so we have made these modifications. We are also changing the location of the hinges on the elevators to more closely reflect the full scale bird.
ID:	1727163   Click image for larger version
ID:	1727164   Click image for larger version
ID:	1727165   Click image for larger version
Old 02-14-2012, 08:19 PM
  #85
jetpilot
My Feedback: (48)
jetpilot's Avatar
What did you change?
Scott
Old 02-14-2012, 08:36 PM
  #86
jetpilot
My Feedback: (48)
jetpilot's Avatar
pic
Old 02-14-2012, 08:38 PM
  #87
jetpilot
My Feedback: (48)
jetpilot's Avatar
straightened out the fins?
scott
ID:	1727198   Click image for larger version
Old 02-15-2012, 07:18 AM
  #88
AndyAndrews
ORIGINAL: jetpilot
scott
If you look at the full scale verses the model, the model rudder tapers from the front to the back (it's hollow, being thicker at the leading edge toward the front of the aircraft and then tapers back to a point). The full scale bird uses a steel plate (solid plate) with ribs. Its not tapered at all. I'll post some pics for comparison.
Andy
Old 02-15-2012, 05:32 PM
  #89
AndyAndrews
Scott which A4 do you have? Is it the Comp ARF?
Old 02-15-2012, 07:16 PM
  #90
jetpilot
My Feedback: (48)
jetpilot's Avatar
Yes, Comp Arf. I have one almost ready to fly and a kit ive been building on. The steering and leaks is what have kept me from flying so far. The radio is completely setup, i just cant get steering to be reliable enough yet. I think I just decided to change over to electric gear and actuators for doors and speedbrakes. tired of chasing leaks. steering is tricky.
Scott
Old 03-22-2012, 05:50 PM
  #91
fred cesquim
hello fellow builders
i have started mine one week ago!
so far had worked on the wings:
l/g installed
doors working
have replaced the "live hinge" of the main gear door for a proper hinge made of several small du-bro dinges running through a single piano wire(looks great and works perfectly
slats working
flap and spoiler working too
pictures to follow
i would like to know other builders progress!
all the best
Fred
Old 03-26-2012, 01:15 PM
  #92
cmjets
cmjets's Avatar
Hello:
I am looking info of hidraulic gears, can you show us the hidraulic system of your A4 ??? please.
Many thanks in advance.
Carlos MƔrquez.
___________________________________
http://www.cmjets.blogspot.com.es/
Old 05-25-2012, 11:11 AM
  #93
fred cesquim
someone can tell me what is the black round thing on the white portion of the rudder? any better picture?
Old 05-25-2012, 03:28 PM
  #94
skyhawknut
I'd need to see a pic to know what your talking about.
Old 05-28-2012, 03:22 AM
  #95
fred cesquim
hello Skyhawknut, hereĀ“s the picture: http://images.rcuniverse.com/forum/u...26/To43261.jpg itĀ“s the balck round spot on the white portion, between hinges
thanks!
Old 05-28-2012, 03:27 AM
  #96
fred cesquim
i have done the fin mod as well, plenty work but great looks!
Old 05-28-2012, 03:29 AM
  #97
fred cesquim
finished piece - also changed hinge covers
ID:	1766624   Click image for larger version
Old 05-28-2012, 03:31 AM
  #98
fred cesquim
main gear door hinges and air rams done as well
ID:	1766626   Click image for larger version
ID:	1766627   Click image for larger version
Old 09-03-2012, 04:55 AM
  #99
fred cesquim
have done more progress, here we have airbrakes almost done and main tanks fixed
ID:	1797864   Click image for larger version
ID:	1797865   Click image for larger version
Old 09-03-2012, 05:01 AM
  #100
fred cesquim
nose gear rails holes came wrong from C-arf. i have glued dowels on the wrong holes, added a 3,5 mm pc board on the top for reinforcement made new matching holes.
gear door assembled and ram installed.
small back door came cut undersized, we had to cut more form the fuse (approx 1" to the back) to allow the gear ram exit without fuselage interference.
ID:	1797867   Click image for larger version
ID:	1797868   Click image for larger version
