Gyro Question???
My Feedback: (30)
Have a question that hopefully someone can help..
Was out flying today for the first time this season and on take off I over corrected any my jet kicked out sideways like it was a subaru rally car..first time I have experienced this, and of course it makes me a little nervous now. I was just lucky we were on a very large runway. I was thinking of adding a gyro but my rudder and nose gear are on their own channel and mixed, and I dont want to add a Y lead.
What would be a good gyro for this application?? I know the ACT Fuzzy is an option but a bit $$$..
Can I just add one in between the nose gear servo and the receiver even though its mixed to another channel ( Rudder )??
Is there one that can go to both in this set up?? I guess it doesnt hurt to have it on the rudder also. I could change the gain on gear down or up.
And yes I have the front gear on a low rate, I would just feel more comfortable with one..Some of the places I am going this year are not as wide as where I was today..Any help out here guys..Thanks..
ORIGINAL: KFX450
ORIGINAL: KFX450
ORIGINAL: KFX450
And in any case whatever your decision is with any gyro you may buy and install do not set it to AVCS (heading hold mode). Should you do this your front gear will never come down during landing (gear down process) because the front wheel servo will definitely be offset.
Tassos
The ACT Fuzzy is extremely expensive, but you really get what you pay for. They do control two servos, like rudder and nose wheel, ailerons, and elevators. You want to see a plane fly on rails.....put an ACT Fuzzy Pro SMM gyro on it.
Chad
Chad
ORIGINAL: KFX450
Hey Tasso
I need something that is coin to run on 6v with no regulator. Any ideas?? Would the jr 270 be a candidate?
Hey Tasso
Attached is a picture of one of my installations.
You'll see I have 2 gyros there. The GY240 for the nose wheel and an ACT FUZZY for the ailerons.
Tassos
Gyros work fine on 6 volts normal in a helicopter its the servo that cannot handle 6 volts
hey Tassos I have a 14mz and plan on running dual receivers on a powerbox like this are you running each receiver on battery or does the power box do that for you? Also with all that carbon in there have you ever had any issues with blackout? I fly helis and you have to be careful about receiver ant placement due to the carbon frame blackout. I have been scared to make a carbon plate to mount everything for this very reason.
What are the tree boxes above the power box with airlines coming from them?
ORIGINAL: FenderBean
yes you're right. It's been so long since I last built a heli I forgot a few things
Powerbox Royal is a great piece of electronics
No issues at all with radio link, never.
I hope it helps
Tassos
THanks! Yeah I like the power box and since you only need the control surface servos ran to the powerbox it would not be an issue to plug the others straight in. Im actually thinking about using a smart fly but have not made up my mind. Thanks for responding nice clean setup!
My Feedback: (30)
ORIGINAL: tassos p
I think yes its possible with this JR although I run my GY240 on 6V, with no issues at all. If there is an issue you can also use a Duralite voltage step-down https://duraliteflightsystems.com/ac...product_id=120 in line with the gyro.
Tassos
ORIGINAL: KFX450
Hey Tasso
Hey Tasso
Tassos
