 BVM HOT SECTION PAINT....THINNER NEEDED. >
Old 08-31-2011 | 09:08 PM
furloughed ual's Avatar
My Feedback: (31)
Default BVM HOT SECTION PAINT....THINNER NEEDED.
I have some of the hot section paint and need to know what to use to clean up and thin it with if needed. Two calls in to BVM today with no luck. Time is wasting and I need to spray. The info sheets with the paint and online instructions make no mention of this.
What kind of paint is it and what is used to clean the spray eqipment? Lacquer thinner, something different? What?
Thanks.
Old 08-31-2011 | 09:18 PM
InboundLZ's Avatar
My Feedback: (10)
Default RE: BVM HOT SECTION PAINT....THINNER NEEDED.
I would just use lacquer thinner...should clean just about anything....but hey I could be wrong...
Old 08-31-2011 | 09:29 PM
FenderBean's Avatar
its water based, says it on the can, so u can thin it and clean up with water.
I would not thin the paint its suppose to be thick thats why it works
If you talking about the BVM ceramic heat shield paint that is.
Old 08-31-2011 | 10:26 PM
roger.alli's Avatar
Fender is right. It is water based and supposed to be brushed on. It would be far to thick to spray through any normal paint gun. As I understand it the paint has a special heat resistant additive that builds up in several layers to give protection. It is the goes on almost like tooth paste..
Roger
Old 08-31-2011 | 10:41 PM
My Feedback: (171)
i think what furloughed ual is asking about is the paint that bvm sells as the hot section paint meaning the detail paint for the outside of the tail cone called hot section paint , which is most likly a lacquer based paint but just a guess
Old 09-01-2011 | 01:43 AM
roger.alli's Avatar
Ahhh. Of course. My mistake.
Old 09-01-2011 | 04:03 AM
My Feedback: (31)
ORIGINAL: dsr71
Yep, that's the stuff. Not the ceramic heat shield. The problem with "trying" lacquer thinner is that I just got a brand spanking new top of the line $400 spray gun and I ain't about to screw it up with some magical mystery paint that dries in the gun AFTER I find out Lacquer thinner isn't the ticket.
Old 09-01-2011 | 05:37 AM
My Feedback: (8)
Lacquer thinner is the answer. Used this stuf a number of years ago alot. Cleans up real easy.
Old 09-01-2011 | 05:54 AM
My Feedback: (31)
Thanks. I was hoping that was the ticket, but didn't want to screw up a expensive paint gun "experimenting".
Old 09-01-2011 | 07:32 AM
Ryan,
Bring the paint and your fancy paint gun up here, I'll GLADLY hose it up for you Once I get it figured out, I can use it on my Panther[8D]
the sandman
[/quote]
Yep, that's the stuff. Not the ceramic heat shield. The problem with ''trying'' lacquer thinner is that I just got a brand spanking new top of the line $400 spray gun and I ain't about to screw it up with some magical mystery paint that dries in the gun AFTER I find out Lacquer thinner isn't the ticket.
[/quote]
Old 09-01-2011 | 08:41 AM
My Feedback: (31)
ORIGINAL: DStJohn
Ryan,
[/quote]
That prob won't work....I'm sure the paint has a shelf life of less than a decade.
Old 09-01-2011 | 04:42 PM
ORIGINAL: furloughed ual
ORIGINAL: DStJohn
Ryan,
[/quote]
Ok, that does it, I am going to save all my sanding dust and pack it into the inlets of the Lightning[:-] Yeah, I know, you won't have the Lightning in a decade, right?
Old 09-01-2011 | 08:46 PM
InboundLZ's Avatar
My Feedback: (10)
What, just because I am not some fancy smancy JR Rep my advice is no good? I see how it is!
Dan, you just mind your P's and Q's...Ryan is very likely to have the lightening ten years from now!
Old 09-02-2011 | 02:21 PM
Dave,
You didn't see him at work plowing the field with the vertical stab on that Lightning That thing was lower than a snakes belly
