Reload this Page >
CARF Skygate Hawk in the house !
Old 08-05-2014, 04:08 AM
  #576
jws_aces
My Feedback: (33)
jws_aces's Avatar
Not sure Top. I read in some earlier post by Scott Marr that it needed a lot blocked off. I just started off with what you see in the picture. I would say about 70% blocked off.
Scott to talked about that they had problems with the main door blowing off when guys used 200 size or bigger turbines. You can see in a video I have of my door pulling open some what at KY jets before I did the mod. I have 8711 400oz servos on those doors. I hope to get a new video since I did the mod.
The more I thought about it last weekend at Hamburg jets event I realized it made a big difference in performance. It did affect the drag a lot. I noticed with full flaps and gear it didn't slow down no where a much as it did before.
I also noted a big increase in speed. I am no kidding when I say it has a better climb than my 1.5 hawk with ram 1000. It's my new favorite of all time.
I hope to make it to Michigan jets this weekend. If I have to wear a gopro on my head to get some video I will.
Old 08-05-2014, 06:45 AM
  #577
topiwala
Thanks jeff
Im well on the way to do some restrictors. My ones will be further inboard and not visible. Ref pics. The pic show a mounting flange ring inside the intake. A restrictor plate will be mounted on it with four 2.5m bolts. This at the plate is removable and replaceable with another. The mounting flange will be glued in permanent. The restrictor plate will be removable.
ID:	2020312   Click image for larger version
Old 08-05-2014, 06:46 AM
  #578
topiwala
If I end up not using the restrictors then atleast the mounting flange ring adds some strength and stiffness to the intake, which is quite floppy really at the moment.
Old 08-05-2014, 07:04 AM
  #579
ataurini
Hallo,
i can see on hick of skygate you have several photo with accessories and particular scale modification
how can I buy them?
can you suggest me a site where to buy?.
thanks a lot
Alex Taurini
Old 08-05-2014, 07:43 AM
  #580
Hinckley Bill
My Feedback: (569)
Originally Posted by ataurini
Hallo,
how can I buy them?
thanks a lot
Alex Taurini
Alex,
I know that Details4Scale has a lot of Skygate Hawk 'scale detail' accessories shown on their website:
http://www.details4scale.com/scalest...gatemodels.htm
Don't know if any are what you're looking for but never hurts to look
Bill
Old 08-05-2014, 08:40 AM
  #581
skymaster68
Thanks for the Video Jeff, it shows great performance with the K210...
Anyone planing to set a K210 or already flying with the 210 on the SG Hawk??
Old 08-05-2014, 09:09 AM
  #582
ataurini
Thanks a lot
but all accessories and modificati on i can see in you Photos are not present on the site you suggested and that i know already
Old 08-05-2014, 09:20 AM
  #583
Hinckley Bill
My Feedback: (569)
Thanks a lot
I understand.....you may have to search this thread and a couple of other Hawk threads to actually find the accessories and modifications that you see....many folks have contributed to improvements since it first came out
Old 08-05-2014, 10:42 AM
  #584
Blancr
Thanks a lot
Alex - you might try looking at the Tomahawk-Design site. They make a Hawk that is a little bigger but they have quite a wide range of scale parts some of which might be ok. If you look on the price list you will see all of the possible parts available
Bob
Old 08-05-2014, 11:34 AM
  #585
jws_aces
My Feedback: (33)
jws_aces's Avatar
That looks great!
That should work .. Yes Scott talked about see some splitting at the back and that is why I have mine up inside.
Old 08-05-2014, 11:39 AM
  #586
jws_aces
My Feedback: (33)
jws_aces's Avatar
You know I bet if I were to put the 180g back in with the restriction in the intakes I bet it would fly really nice. The reason I say that is with the 180 it would take off the same and look the same except ground speed was around 150 mph. I am sure it wouldn't perform as well and it would be a lot better than my first flights on the 180g.
Top I hope you will fly yours with and without the restriction so you could verify what I am see.
Old 08-05-2014, 01:21 PM
  #587
c_makhija
Are you guys using servos for door operation? The original SG kits came with air cylinders for door operation and had no problems even with 200+N turbines.
Chatty.
Old 08-05-2014, 01:45 PM
  #588
jws_aces
My Feedback: (33)
jws_aces's Avatar
Chatty.
On my hawk I went with down and lock electric conversion and also put Jr8711 servos on the doors.
I am not sure about the air set ups.
Old 08-05-2014, 03:18 PM
  #589
Mike Haddox
Chatty.
From my understanding the gear doors have always been a problem with the Skygate Hawk and the Tomahawk design hawks also. Whether using the air cylinders or
servos for operation. The only way to cure the problem is a full bypass but restricting the amount of air entering the fuse helps a lot.
Mike Haddox
Old 08-05-2014, 06:33 PM
  #590
jws_aces
My Feedback: (33)
jws_aces's Avatar
Default Video with the 210g at Hamburg PA
A friend posted this today for me. You can the speed before he cut off the video when it was going to the vertical climb.
https://www.youtube.com/watch?v=v3MWQAwE-m4&feature=youtu.be
Old 08-06-2014, 07:40 AM
  #591
dos007
My Feedback: (24)
Can someone tell me the difference between the original Skygate Hawk versus the CARF Skygate Hawk. Is one lighter than the other? Did CARF make any major changes?
Old 08-07-2014, 08:27 AM
  #592
c_makhija
Hello Dos,
I do own the original SG hawk, the comp arf hawk is a lot more prefab than the original SG, and can be built much faster. When viewed from inside, the SG hawk looks far superior to the comp arf, but I am sure they both fly equally well. If not mistaken both can be built under 20kg.
Chatty.
Old 08-07-2014, 08:43 AM
  #593
jws_aces
My Feedback: (33)
jws_aces's Avatar
I have a complete kit for sale in the classifieds and will have it Michigan jets tomorrow.
Old 08-10-2014, 02:02 PM
  #594
weeksy
good price
Old 08-10-2014, 03:13 PM
  #595
schroedm
schroedm's Avatar
Chatty
my SG Hawk used the supplied air rams on the doors, a 180 turbine, no inflect restrictors and I never had doors opening in flight.....
Old 08-10-2014, 06:17 PM
  #596
jws_aces
My Feedback: (33)
jws_aces's Avatar
Originally Posted by schroedm
Chatty
Do you know what kinda of speed you are getting out your hawk with the 180?
I just got back from another event and we are seeing close to 190mph out mine. I did video it again and the doors are solid. I will post it soon. Also I pretty sure a video of it was taken and will be posted soon.
The biggest gain I am seeing is the performace. I was not sure until now. I put 13 flights on it this weekend at Michigan Jets and I love the performance. I wasn't the only that noticed the performance flying with the restrictions. Now don't get me wrong I may get a second set of intakes to put it back stock because it want slow down no were nearly like it did before the mod.
If you happy with what you have don't put them in. After this weekend I can tell of atleast 3 people that are going to consider adding them to theirs. 1 Fly Eagle and 2 Tomahawks.
I just wanted to pass on a tip that can improve the jet performance not say it had to be done.
I wish you well with yours.
Old 08-11-2014, 12:02 PM
  #597
c_makhija
Chatty
Hi Mark,
Yours is now flying with a 200SX with no problems. Will go with the stock setup, hopefully should be fine. Got a AMT Olympus HP in mine.
Hope to catchup at JP next month.
Cheers
Chatty.
Old 08-11-2014, 12:16 PM
  #598
schroedm
schroedm's Avatar
Hi Mark,
Cheers
Chatty.
Hey Chatty, good to hear! Yup, be good to catch up at JP with you and the guys.
M
Old 08-11-2014, 03:50 PM
  #599
jws_aces
My Feedback: (33)
jws_aces's Avatar
Here is a video posted from Michigan on Sunday morning. Had to cycle the gear once but after I got the it cleaned up you can see it has great performance.
https://www.youtube.com/watch?v=bBGcFz9dyjs I really like the scale look of the gear and the doors but I admit you can't see them going up but they look cool coming out.
Old 08-14-2014, 12:53 PM
  #600
skymaster68
Great video K210 it is!!!
