Reload this Page >
CARF Skygate Hawk in the house !
Old 11-24-2014, 10:42 AM
  #726
jws_aces
My Feedback: (33)
jws_aces's Avatar
yea it was a B***H...I couldn't imagine installing them on the inside.
Old 11-24-2014, 10:46 AM
  #727
jws_aces
My Feedback: (33)
jws_aces's Avatar
LOOK at what I just ordered It want make it in time for Christmas but I hope to have it in time for FL jets.
Name:	New rudder.jpg
Old 11-24-2014, 03:47 PM
  #728
DUCMOZ
Is that the tail only ? that would be cool.
Behzad
Old 11-24-2014, 06:53 PM
  #729
jws_aces
My Feedback: (33)
jws_aces's Avatar
I had purchase the mask from Tailormade to paint it with but then I see this online as part of the kit so I contacted Andy and he ordered it for me.
Fin, rudder and elevator cover.
I love it. Here is a youtube of one already out there flying.
http://youtu.be/-lO3w7VLTz4?list=FLn21FiSaialjufKUSiiliEw
Old 12-06-2014, 11:20 PM
  #730
DUCMOZ
Hi Guys, in order for my gear to cler that door and fit right, I am ending up with a few degree of tow out on each side. Is that what you have experienced? I have the gear covers on as well but if I try to put some toe in, then the tire does not allow the gear door on the fuse side to close. I would appreciate some feedback or pictures from front.
Behzad
Old 12-06-2014, 11:50 PM
  #731
lavi rider
Hi ,
you need to fine tune the position of your retracts/struts "sit" in the wing .. Some shims/sanding is required to get them in the right position .
You will have to file away some material in the wing root to clear part of the strut ... It shows in the manual and also here on this thread too.
Old 12-07-2014, 12:12 AM
  #732
Blancr
Originally Posted by lavi rider
Hi ,
I also have this problem but am unable to see how it can be made to work with toe in. The Strut cover contacts the wing under surface before I can achieve any toe in and this leaves the main door 2 mm open so I can't see what there is to sand. If I shim the mount then the small door will not close. The best I can achieve is about 1 degree toe out with both doors closed.
Some pictures and specific advice would be welcome if possible.
Bob
Old 12-07-2014, 03:50 AM
  #733
lavi rider
I had the same issue , my solution was to grind away the airex in that area up to the wing skin and reinforce the area by applying a piece of 0.5mm poly ply , it was enough to clear the strut .
Old 12-07-2014, 03:54 AM
  #734
Blancr
Thanks Lavi - but wow - is that really the only solution? Anyone else had to do this or are there other solutions?
Bob
Old 12-07-2014, 03:57 AM
  #735
lavi rider
Default CARF Skygate Hawk in the house !
I've decided on deleting the non scale gaps between the gear doors and fuselage.... has anyone done this?
Name:	SkyGate Bae-Hawk 1-3.75 Scale 103.jpg
ID:	2052814   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 099.jpg
ID:	2052815   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 100.jpg
ID:	2052816   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 101.jpg
ID:	2052817   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 102.jpg
Old 12-07-2014, 04:06 AM
  #736
lavi rider
I also reduced the inlet area . The area now is about the same as on my Ultra Lightning...
Name:	SkyGate Bae-Hawk 1-3.75 Scale 105.jpg
ID:	2052819   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 104.jpg
Old 12-07-2014, 07:13 AM
  #737
Mike Haddox
Behzad
I will be setting mine up with toe out. We always set up race cars up with toe out. Why? Because they drove better. Thanks, Mike
Old 12-07-2014, 08:39 AM
  #738
DUCMOZ
Hi All, I have done all the sanding, shimming and adjusting but at the end with the gear covers, I am with exactly 4 degree toe out per side if I want to have a nice fit. After spending so much time doing the covers, It is disappointing. Also, fully understand about toe-out in the cars but this seem a little too much. Will post if I find a good solution.
Behzad
Old 12-07-2014, 01:38 PM
  #739
j.c.a.
Here are some pics from Saturday at Aero Fest in Miami,Florida ,.
ID:	2052964   Click image for larger version
ID:	2052965   Click image for larger version
ID:	2052966   Click image for larger version
Old 12-07-2014, 02:38 PM
  #740
jws_aces
My Feedback: (33)
jws_aces's Avatar
Awesome JC... I can wait to see in person. I love the paint job. I hope we get fly together at FL jets in March.
Old 12-07-2014, 03:31 PM
  #741
DUCMOZ
It looks great. I see you are a smart man. Have let go of pesky strut covers��
Old 12-07-2014, 05:06 PM
  #742
j.c.a.
Yes we tried for a while with the strut covers and did not like how flimsy they were and decided not to install them. I have a friend working on some fiberglass covers, those I will try to fit on. After flying both the Tomahawk and the Skygate I really believe the Full bypass is a must. My Skygate has a more solid feel . Sure hope to see you Jeff, Miguel Alvarez might come out with a bypass kit for the Skygate Hawk he is working on a second kit now for Tony Bonnano with the bypass.
J.C. Alvarez
Old 12-07-2014, 05:43 PM
  #743
DUCMOZ
We need someone with 3d printing knowledge to make a set that we can screw together and fits perfectly. Then, there will be no hassle.
Behzad
Old 12-07-2014, 06:40 PM
  #744
jws_aces
My Feedback: (33)
jws_aces's Avatar
J.C. Alvarez
Yes the strut cover a very flimsy. It was a big pain. I am not happy with how they look but they are ok. I got enough expoy so the doors are solid.
Counting the days to FL jets. I hope to have my new rudder. I have upgraded the lights and they look great.
flyloose (04-03-2021)
Old 12-08-2014, 12:41 AM
  #745
topiwala
Hi. As you'll see in my earlier posts, I didn't use the strut covers. I worked with the strut and anchor points for the strut door. What I ended up with is a semi scale strut with a positive mechanically locked in strut door. I didn't take any chances with epoxy holding the door on a flimsy strut with a cover.
Refer to my posts earlier. Some pics also there.
Old 12-08-2014, 02:02 AM
  #746
lavi rider
Did the strut covers , used some plywood to build up a frame the connects the strut covers to the strut in a positive way and glued the halvs to each other with hysol...sanded off some of the strut cover skin and aplied a thin strip of 50 gram glass cloth on the seam...
ID:	2053122   Click image for larger version
ID:	2053123   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 001.jpg
ID:	2053124   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 005.jpg
ID:	2053125   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 006.jpg
ID:	2053126   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 007.jpg
ID:	2053127   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 008.jpg
ID:	2053128   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 009.jpg
Name:	SkyGate Bae-Hawk 1-3.75 Scale 012.jpg
Old 12-08-2014, 02:07 AM
  #747
lavi rider
This is what it looks like now . -0.5 degree tow in
Name:	SkyGate Bae-Hawk 1-3.75 Scale 089.jpg
ID:	2053131   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 094.jpg
ID:	2053132   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 096.jpg
Old 12-08-2014, 02:11 AM
  #748
lavi rider
More progress on the gear doors...
Name:	SkyGate Bae-Hawk 1-3.75 Scale 107.jpg
ID:	2053134   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 108.jpg
ID:	2053135   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 106.jpg
Old 12-08-2014, 03:07 AM
  #749
lavi rider
One more..
Name:	SkyGate Bae-Hawk 1-3.75 Scale 097.jpg
Old 12-08-2014, 06:21 AM
  #750
Blancr
Behzad
For those already flying, be grateful for your observations re ground handling. Given the difficulties of achieving any kind of toe in, I'm wondering just how sensitive the aeroplane is when departing and landing and therefore just how much this matters. Best I can get is 1 degree toe out without digging up the airex.
Thanks for your thoughts
Bob
