Reload this Page >
CARF Skygate Hawk in the house !
Old 12-10-2014, 11:05 PM
  #776
DUCMOZ
Thanks Jeff, since I took the gear apart to paint it, i locktite all the set screws back. But I will double check. I just finished working on the gear and by sanding the edges of the gear cover, I can get about 1.5 degree of toe out which is okay. The only thing happened is that the gear closed fast and cracked the edge of the fuse a little (aahhhh) . Now, I will add a little thin poly ply to the corners and paint it and should be good enough. This plane has taken me a long time and I am ready to be done with it. Thanks again.
Behzad
Old 12-11-2014, 01:43 AM
  #777
Colin Gontier
Colin Gontier's Avatar
Good to see you are getting there Behzad - the clearances for the gear are very tight but it is possible to get it right with plenty of time and patience ! Just adjust little by little until its perfect. Everyones will be slightly different due to the scale leg mouldings and exactly where / how / what angle they are attached to the leg. I did not need to sand any of the skins on the 2 Hawks I have built but it is all a very tight fit. I have ended up with pretty much straight tracking with a very slight toe-in bias.
If anyone needs any pics or measurements other than what I put in the manual please just let me know. Here are some pics of mine - can't wait to get its brother finished and flying, almost done now! The next one will be fully weathered to bring out all the lovely detail.
regards
Colin
ID:	2053999   Click image for larger version
ID:	2054000   Click image for larger version
ID:	2054001   Click image for larger version
Old 12-11-2014, 09:53 AM
  #778
DUCMOZ
Hi Colin, thank you for the note. Your thread made me buy this Hawk and I am glad you are working on the second one. I have to admit that I am more picky than I should be at times and that makes the process longer. But normally don't have to ever touch it again once it is done. the grinding of the corners of the strut covers is minimal and would look fine once caped. (will post pictures later) but it gives good clearance from the wing's skin. another sticky point is the curved spot on the gear (by tire) which sits against the fuse. the gear operates fine but it hits that spot when pulled up. I am playing with shimming the front of the gear mount to just give it enough clearance to not touch. after that, to the gear door and fences and will be final install.
let us have update of your progress.
Behzad
Old 12-15-2014, 08:16 AM
  #779
lavi rider
Default CARF Skygate Hawk in the house !
Made one side of my Hawks intake removable to gain access to the internal refueling fuel lines.
Name:	SkyGate Bae-Hawk 1-3.75 Scale 128.jpg
ID:	2055273   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 043.jpg
ID:	2055274   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 044.jpg
ID:	2055275   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 122.jpg
ID:	2055276   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 123.jpg
ID:	2055277   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 124.jpg
ID:	2055278   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 125.jpg
ID:	2055279   Click image for larger version
Name:	SkyGate Bae-Hawk 1-3.75 Scale 126.jpg
Name:	SkyGate Bae-Hawk 1-3.75 Scale 127.jpg
Old 12-15-2014, 08:32 AM
  #780
lavi rider
Got onto matching the nose gear doors.
Name:	Copy of SkyGate Bae-Hawk 1-3.75 Scale 121.jpg
ID:	2055285   Click image for larger version
Name:	Copy of SkyGate Bae-Hawk 1-3.75 Scale 116.jpg
ID:	2055286   Click image for larger version
Name:	Copy of SkyGate Bae-Hawk 1-3.75 Scale 117.jpg
ID:	2055287   Click image for larger version
Name:	Copy of SkyGate Bae-Hawk 1-3.75 Scale 119.jpg
ID:	2055288   Click image for larger version
Name:	Copy of SkyGate Bae-Hawk 1-3.75 Scale 120.jpg
Old 12-23-2014, 03:00 PM
  #781
DUCMOZ
Hi Guys, for the ones that were talking about the Gear and fitting, after a lot of fiddling around, I decided to grind the corner of the plastic cover on the knuckle and 2MM from the edge of the landing gear where it was hitting the fuse. this would give me 0.5 degree toe out each side and makes everything fit perfect. here are a couple of pictures for reference. One after sanded and one after covered and painted. From the front view, they are hard to see.
Behzad
ID:	2057299   Click image for larger version
Old 12-23-2014, 03:11 PM
  #782
DUCMOZ
Another thing that was hunting me was adding the wing fences as I have seen a few Hawks that were painted in mold (like mine) and their fences looked horrible. so, the way I went about it was to first locate and tack glue the fences in perfect spot with Gel Zap CA which works great. Then, masked about 2mm away from the fences. Removed the fences and sanded the area and about 2mm from the gluing edge of the fences. Spot glued the fences back on and used Aero Poxy to glue them in place. Removed the masking tapes while Aero Poxy is wet and let it dry. Then, re-mask, sand lightly and paint. The result is great and they look like they were there from the first build. The fences are so strong that I can grab one and lift the wing with it. here are some pictures.
ID:	2057306   Click image for larger version
ID:	2057307   Click image for larger version
ID:	2057308   Click image for larger version
ID:	2057309   Click image for larger version
Old 12-23-2014, 11:30 PM
  #783
toti_ducati
toti_ducati's Avatar
Hi Guys, just finished building my CARF Skygate Hawk. I'm running it with a Jetcat 200sx and JR 8711 servos. Everything is well, the only thing that bothers me however is the elevator pushrod mounting. It is only 1 2.5mm bolt holding this huge elevator together. Have any of you modified it to make it sturdier?
<iframe src="https://www.flickr.com/photos/114839203@N05/15905888200/in/photostream/player/" width="75" height="75" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Old 12-24-2014, 12:54 AM
  #784
toti_ducati
Hi Guys, just finished building my CARF Skygate Hawk. I'm running it with a Jetcat 200sx and JR 8711 servos. Everything is well, the only thing that bothers me however is the elevator pushrod mounting. It is only 1 2.5 inch bolt holding this huge elevator together. Have any of you modified it to make it sturdier?
Old 12-24-2014, 05:51 AM
  #785
David Gladwin
David Gladwin's Avatar
You are wasting your time with the small fences, the RAF Hawk T1s (like the Red Arrows ) don't have them ! (or a HUD) but they always DO have a centerline tank !
David .
Old 12-24-2014, 07:28 AM
  #786
lavi rider
Hello David,
Would you be kind and share your plans of the centerline tank .
Old 12-24-2014, 08:30 AM
  #787
DUCMOZ
Hi David
I have looked for a center tank and no one makes one. Do you know of any?
Thanks, Behzad
  #788
DUCMOZ
Hi David
Thanks, Behzad
Old 12-24-2014, 08:36 AM
  #789
DUCMOZ
A good screw with that configuration will handle a lot of force. I think other stuff would break before that so there should not be a problem.
Old 12-24-2014, 11:25 AM
  #790
jws_aces
My Feedback: (33)
jws_aces's Avatar
The only center line tank is the Airworld that maybe a bit longer. I was quoted something like 450.00 for one. I have one off of a smaller hawk. I am going to see if looks too small.
As far as the elevator the bolt and mounts are fine. I have checked mine regularly and it has seen close to 7.5Gs and I don't see any issues.
The earlier versions used a long rod from the front. That would have failed long before the bolt. They did have to make sure the rod was bonded together properly.
Old 12-24-2014, 11:33 AM
  #791
jws_aces
My Feedback: (33)
jws_aces's Avatar
Default Look at what Santa brought me today!!
My new rudder with the 50th paint scheme...I LOVE IT...
If some would like to do it themselves I have the Tailor-made paint mask new in the box unopened.
I got the rudder and elevator cover from Carf prepainted.
ID:	2057538   Click image for larger version
ID:	2057539   Click image for larger version
Old 12-24-2014, 12:08 PM
  #792
DUCMOZ
Hi Jeff, thanks for both posts. I love the tail. The tank from Airworld is smaller than what it should be for this Hawk. But, should not be by that much (about 1/3.7 ish scale to 1/4 scale which airworld is). As this is ARF and it is semi scale, it should work fine. I will check it out and post.
Have a a happy holiday to all.
Behzad
Old 12-24-2014, 05:06 PM
  #793
toti_ducati
Duc moz thanks for the reply, do you use spacers to make the linkage in line with the servo horns or just let it angle inwards?
i started with a white builders kit, did you notice the airfences were to be mounted with a bit of toe in?
Details for scale makes a tank
Old 12-24-2014, 06:19 PM
  #794
jws_aces
My Feedback: (33)
jws_aces's Avatar
You line them up with marks on the wings. That will set the proper angle.
They are toed in along with the vortex generators.
Old 12-24-2014, 09:00 PM
  #795
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Has anyone done an opening canopy on this model? can you post instructions on how you did it? I was looking at getting details4scale kit, but that might take longer than I would like to wait so seeing any alternatives would be great.
Old 12-24-2014, 09:26 PM
  #796
DUCMOZ
Hi, there are markings on the wings for the fences. 3 little ones and one wide large one. As for the stab set up, you will be moving the pressure area out if you use spacer and that could weaken the set-up. So it is better to let them be as they are. Please look at post # 412 and picture of my set-up is there.
thanks, Behzad
Old 12-25-2014, 09:31 AM
  #797
fregnier
Hi David,
In the process of assembling a T1 red, looking forward to receiving hints and drawings for the smoke pod !
Best regards
Fred
Old 12-25-2014, 11:34 AM
  #798
c_makhija
Finally flew my Skygate hawk, powered by AMT olympus, powerbox cockpit SRS. I gyro. (it was a very long build)
Test flight was uneventful.
Thanks to Marcs for the (virtual manual) here on RCU. The tips on the small outer gear door and canopy were really helpful.
David gladvin for mailing me the Red Arrows color samples and Ralle from Tailor made decals for all the support during painting.
Chatty.
ID:	2057680   Click image for larger version
ID:	2057681   Click image for larger version
Old 12-25-2014, 01:17 PM
  #799
jws_aces
My Feedback: (33)
jws_aces's Avatar
Chatty.
Congrates!!! Looks like it turned out nice. Your paint work looks really good. I though it was a ARF Red Arrow paint like mine. I am sure you will love the way it flies.
Video if possible.
Old 12-25-2014, 01:38 PM
  #800
c_makhija
Thanks Jeff,
This is the original SG kit, has to be painted externally. lot of work, but worth it.
She does fly sweet.
Chatty.
