Reload this Page >
CARF Skygate Hawk in the house !
Old 04-20-2015, 04:38 PM
  #901
j.c.a.
My maiden video for the tomahawk is on you tube jcth082614
Old 04-22-2015, 01:02 AM
  #902
claudius
Hello guys, I am working on the dive brake.
I am wondering what the parts for? they were in a pack together with the divebrake's hardwares.
Old 04-24-2015, 02:18 PM
  #903
DUCMOZ
Hi Jeff
Where do you have your smoke tank installed?
Thanks, Behzad
Old 04-24-2015, 05:02 PM
  #904
jws_aces
My Feedback: (33)
jws_aces's Avatar
I mounted on top of the stock tank.
You can see I am using extra Velcro straps to hold in. It is a 64oz tank.
Old 04-24-2015, 06:54 PM
  #905
DUCMOZ
Thanks Jeff. I will have to look for space for mine. I didn't plan to put it there and it is too late to modify.
Thanks again.
behzad
Old 04-25-2015, 08:39 AM
  #906
jws_aces
My Feedback: (33)
jws_aces's Avatar
Keep in mind that even where mine is and no nose added weight mine is very slightly nose heavy so make sure you keep it behind the nose mount.
Old 04-26-2015, 12:55 AM
  #907
Blancr
Originally Posted by lavi rider
Yeah , I did , but another way of using the parts in the kit is by simply positioning the clear parts on the wing and mark their edges with a pencil on the wing , then cut that area out .
Hi Lavi,
Would it be possible for you to post a picture of your completed wing light cover in position. I'm not keen on just screwing the supplied (poor quality) cover onto the wing tip. I think it needs to be recessed in some and I'm just wondering if this is what you ended up doing?
Thanks for any help
Bob
Old 04-26-2015, 02:31 AM
  #908
lavi rider
Hey Bob ,
No problem send me you email and I'll throw in a bunch of pictures.
The two fiberglass rails in question before are scale parts that go on each side of the dive brake .
Old 04-26-2015, 03:26 AM
  #909
Blancr
Thanks Lavi - that's brilliant. Pm sent
Bob
Old 04-26-2015, 06:28 AM
  #910
lavi rider
Default CARF Skygate Hawk in the house !
Well, here they are after all...
ID:	2092170   Click image for larger version
ID:	2092171   Click image for larger version
ID:	2092172   Click image for larger version
ID:	2092173   Click image for larger version
ID:	2092174   Click image for larger version
ID:	2092175   Click image for larger version
ID:	2092176   Click image for larger version
ID:	2092178   Click image for larger version
ID:	2092179   Click image for larger version
ID:	2092180   Click image for larger version
ID:	2092181   Click image for larger version
ID:	2092182   Click image for larger version
ID:	2092183   Click image for larger version
ID:	2092184   Click image for larger version
ID:	2092186   Click image for larger version
ID:	2092187   Click image for larger version
ID:	2092188   Click image for larger version
ID:	2092189   Click image for larger version
ID:	2092190   Click image for larger version
ID:	2092191   Click image for larger version
ID:	2092192   Click image for larger version
Old 04-27-2015, 08:26 AM
  #911
DUCMOZ
Hi Jeff, Thank you. It is amazing how much room the cockpit takes and how little room is left to work with for the install. I have not installed a Smoke tank yet and getting close to have to balance. Will see where batteries go and take it from there.
Behzad
Old 04-27-2015, 09:06 AM
  #912
jws_aces
My Feedback: (33)
jws_aces's Avatar
I started with flight pack batteries under the pilot beside of the nose gear. I have moved them to behind the main gear doors. I am using Zippy's 4100 MAH 2s life. They weight 287 grams each.
I use a 2100 3s life the turbine and have it located just behind the front pilot on the board that I have all the radio gear on. I would like to move it back but I can find the room. I am using a Skymaster pilot figure and he is heavy. I didn't weight him but I don't want to use 2 pilots becuase I don't need the extra nose weight.
The factory balance numbers are good but i feel like are a bit on the nose heavy side. Mine will not hold the nose up on the wheels very long at all. I know that when it is balances right you can ride a wheelie.
Old 04-27-2015, 09:14 AM
  #913
DUCMOZ
Thanks Jeff. I bought a pilot from I Fly Tallies and is only 6.5Oz including the helmet. I will be also using one. Batteries are Duralite + a lipo + a 4 cell for the lights. I think around the center section will be the right area for them. But, will report.
Behzad
Old 05-23-2015, 05:38 AM
  #914
lavi rider
Wheel bays ....
Old 05-23-2015, 05:42 AM
  #915
lavi rider
More ...
ID:	2097945   Click image for larger version
Old 05-23-2015, 01:02 PM
  #916
lavi rider
Canopy ..
ID:	2098026   Click image for larger version
Old 05-23-2015, 01:04 PM
  #917
lavi rider
More..
ID:	2098029   Click image for larger version
Old 05-23-2015, 01:07 PM
  #918
lavi rider
Locking mechanism
ID:	2098031   Click image for larger version
ID:	2098032   Click image for larger version
Old 05-23-2015, 01:11 PM
  #919
lavi rider
Eyelets...
ID:	2098034   Click image for larger version
Old 05-23-2015, 01:15 PM
  #920
lavi rider
Trigger ..
ID:	2098037   Click image for larger version
ID:	2098038   Click image for larger version
Old 05-23-2015, 01:29 PM
  #921
DUCMOZ
Looks good Lavi.
Behzad
Old 05-23-2015, 01:49 PM
  #922
lavi rider
Thx ,
Old 05-23-2015, 01:52 PM
  #923
lavi rider
Wing to fuselage air connectors..
ID:	2098045   Click image for larger version
Old 05-23-2015, 01:55 PM
  #924
lavi rider
More...
Old 05-23-2015, 06:56 PM
  #925
Hinckley Bill
My Feedback: (569)
Would you mind sharing where you got the wing to fuselage air connectors....they look fantastic!
Thx,
Bill
