Reload this Page >
CARF Skygate Hawk in the house !
Old 01-08-2016, 02:35 PM
  #1151
lavi rider
In the process of building the cockpit .. There's lots of pictures on the net .
Started with the seats ... Enjoy
ID:	2140337   Click image for larger version
Old 01-10-2016, 10:28 AM
  #1152
sasha123
Good work.! Chairs, devices of avionics there are some versions. Ме are necessary on the Swiss Hawk. in a network it isn't enough of them
Old 01-11-2016, 03:58 AM
  #1153
lavi rider
BAe Hawks as far as I know use the Martin Baker MK-10B same as the one I'm in the process of making...
Old 01-11-2016, 04:07 AM
  #1154
lavi rider
Old 01-12-2016, 08:48 AM
  #1155
sasha123
Everything is right. Hawk is completed with these chairs. Here the earliest and most modern Martin Baker MK-10B model.
ID:	2141051   Click image for larger version
ID:	2141060   Click image for larger version
Old 01-12-2016, 11:44 AM
  #1156
skymaster68
has anyone installed the smoke pod from Details4scale? I got one but haven't installed yet...
Old 01-12-2016, 12:08 PM
  #1157
jws_aces
My Feedback: (33)
jws_aces's Avatar
No but please post pics..I knew they were working on it but I didn't know it was done.
Old 01-12-2016, 01:05 PM
  #1158
schroedm
schroedm's Avatar
That's some nice work on the seat!!
Old 01-24-2016, 10:15 AM
  #1159
wayne1965
Ordered my smoke pod back mid October still no sign of it ! When I get it ,it will defo finish the model off
Old 06-12-2016, 11:03 PM
  #1160
In the Haze
In the Haze's Avatar
Putting mine together and was wondering what retract air disconnects one could use at the wings. The 4mm tubing is great but I have not seen any 4mm quick connectors,
Old 06-13-2016, 02:52 AM
  #1161
w4ste
Nev...
Ask clinton they used 4mm to 3mm reducers on the small CARF hawk they build.
Shot
Old 06-13-2016, 03:14 AM
  #1162
In the Haze
Just that CARF supply all 4mm tubing, fittings, T pieces, etc. for the retracts, but no disconnects. I'll get some reducers.
Old 06-13-2016, 04:37 AM
  #1163
schroedm
schroedm's Avatar
SMC do some 4mm quick disconnects just like the Robart ones. I use them on all 4mm airlines.
http://www.rcuniverse.com/forum/rc-j...ne-needed.html
Old 06-13-2016, 05:20 AM
  #1164
In the Haze
Yep those Marc used in post #10 would do the job.
Old 06-13-2016, 06:27 AM
  #1165
DUCMOZ
I have used 4mm festo on Futura and my hawk and worked great as well.
Behzad
Old 06-13-2016, 06:28 AM
  #1166
Mike Haddox
I used 4mm festo fittings.
Old 06-19-2016, 09:34 AM
  #1167
jetjocchris
What Tx are you guys using with this jet? I've got a DX9 and wondering if that's enough or should I upgrade to the DX18? I'm hoping to pull the trigger on this plane next month...
Old 06-19-2016, 11:18 AM
  #1168
DUCMOZ
Hi, I used 12x and it was just enough. I might have a new one for sale. I crashed my first one, bought a new one in Swiss Schem, have installed the retract, wing servos and the engine. I am too picky to have someone build it for me so it has been sitting as I don't have time to work on it. Since you are in Washington, there will be no shipping cost so let me know what you think and I might consider selling mine.
Behzad
Old 06-19-2016, 05:00 PM
  #1169
jetjocchris
Just sent you a PM.
Behzad
Old 06-19-2016, 07:08 PM
  #1170
DUCMOZ
Replied
Old 06-20-2016, 01:26 AM
  #1171
David Gladwin
David Gladwin's Avatar
CAUTION !!
I test flew my SkyGate Hawk yesterday and landed after what I thought was a perfect test flight, but what was very nearly a disaster.
It was witnessed by about ten other guys who will confirm it was flown smoothly and without anything "hard and speed was kept quite low as recorded on the Weatronic GPS. . No rudder inputs were made in flight, aeros were loop, cuban eights and barrel rolls, with most of the flight at half throttle on the Olympus.
Pushing the jet back to the pits I noticed that the rudder trim tab was missing, and looking at the fin a huge crack was discovered running along the fin from front to back just at the top odf the mounting tibe. The other side of the fin was buckled. Any rudder inputs would certainly have led to fin loss !!!!
I have considerably strengthened the fin tube mount in the fuselage but the fin was standard (late) Skygate.
I will be fitting a new fin and probably repair and considerably stiffen this one. When flown I will fit a camera aimed at the fin/ rudder to record its behaviour.
Whether the fin flutter was started by flutter of the trim tab, which led to the rudder fluttering and then the fin will never be known.
My local CARF dealer will ask whether the new Hawks have any mods. to the fin for current kits.
More, and picture, later.
David Gladwin.
Old 06-20-2016, 03:11 AM
  #1172
wayne1965
Hi people
well I'm close to finishing my original Skygate but after reading that david I think I'm going to strengthen my fin, a Question I need too ask on the install are most people useing 2x powerbox to make two completely separate systems as the model I'm expecting to be around 22-24 kg or useing a rrs powerbox only and big flaw I can see with that if powerbox malfunctions there's nothing as back up and what powerbox is everybody useing ,need your thoughts on this thankyou in advance
Regards
Old 06-20-2016, 03:31 AM
  #1173
Jetkopter
I am using a powerbox royal in mine with two rx. Zero problems
Old 06-20-2016, 08:21 AM
  #1174
DUCMOZ
Hi David
From what we know, the fin / rudder issue was addressed and fixed by CARF. so, maybe you can purchase a new fin for your plane from Carf. I think I even have one extra somewhere.
Behzad
Old 06-20-2016, 10:26 AM
  #1175
jws_aces
My Feedback: (33)
jws_aces's Avatar
Originally Posted by wayne1965
Hi people
Regards
Wayne,
I have almost 75 flights on my second Skygate Hawk. I had over 170 on my first one. I believe in the KISS method. Keep it simple. I have nothing against powerbox. They have a awesome product. I just like to lower the chances of failures from complex items in the RX to Servo that can fail.
I used the powersafe reciever with life 6.6 volt batteries with no regulator and DS8711 on all moving surfaces with the exception of front gear doors. This is a proven and reliable light weight set up. I do have seperate batteries for everything else like smoke pump, lights, landing gear to keep them out of the power flow of the RX. I just finished my BVM Plug and Play F-16 and it has high voltage servos but I am going to use the same batteries and RX on it.
MY bird weights right at 49lbs dry and around 63lb wet. I carry 60oz of smoke on takeoff.
