Fly Eagle Jet F-14 Crash (video)
#426
1 Post
RE: Fly Eagle Jet F-14 Crash (video)
Had a look at the 'other' FEJ F-14 build here on the forum and I have to comment......
The 'new' elevator' system which whilst I cannot actually see how its assembled looks like its going to be a no-no. I am happy however to be corrected if my assumptions are wrong.
Assuming the pin which moves the elevator is fixed to the servo arm through one of the holes in it, the resulting twisting forces are going to be insane. It will load the areas where the pin is bolted to the servo arm, the point where the servo arm is fitted to the servo output splines, the servo output bearings - it goes on......
Then we have the 'linkage' to the elevator, a slot in which the pin slides. If this is slightly out of alignment it will generate binding, and binding is NOT good! Finally if the hole is not a perfect fit on the pin at all deflections it will result in slop and inevitably bye-bye jet []
If it were my jet I would want evidence that this system has been designed using proper calculations and totally field tested to failure before even considering its suitability to move an elevator correctly.
My view.
marcs
My view.
marcs
#427
Another interesting snippet from the 'other' thread, dated before dubd posted his video.
Firstly, what happened to the first one?
Secondly (and I am in no way connecting this with my previous question), I wonder why FEJ added wood to the honeycomb area in the tail? Is this a QC issue or an intentional change?
ORIGINAL: Wap4life
Hey Guys,
Thought i would share pics of my new f-14 from FEJ. There are a few changes from my first one (RIP). The biggest change is the elevator is direct drive. The other changes are the wood pieces over the honeycomb area ex. in the tail part where you screw in the servo.
Hey Guys,
#428
Dubd I'm really sorry for your loss but I'm glad there was video to prove your point. Heck even with this obvious video.. people still say dumb sh**[:@]
https://www.youtube.com/watch?v=Unwq7IpNLIQ
#429
ORIGINAL: Jackjet
[/quote]
dont you have anything constructive to say at all ?
DONT FEED THE TROLLS !
[/quote]
yum, yum, yum. Can i have another cookie, yum yum yum
#430
My Feedback: (24)
ORIGINAL: Wap4life
http://<b><font size=''2'' color=''#...nke</font></b> - you would have more credibility if you didn't bash everything fej. you like to read other post and quote but often leave out information. i stated it has been to long and i can't remember the weight.
Fyi- both my mig and f-14 got the inspection to fly unlike most big jets flying at these events. also bob - have over 150 flights in the last 2 years easy just for records. you are welcome to call me or pm me if you an issue with my flying or jets. if you like to inspect my jet fly down to houston. if you got the $$$$ i will let you fly.
I didn't bash anyone, and in fact, I pointed out that you were the only person who has gotten their F-14 inspected as a large model. You stated in the other thread that you thought that your F-14 was 66 lbs wet. Is that close enough to 55 lbs that you think that these aircraft are not "Large Models" according to the AMA? Apparently you didn't because you got yours inspected - kudos to you for actually following the rules. Of course, everyone who is flying these with 140's and 170's has them turned down to 25 lbs each to comply with the 50 lbs maximum thrust rule (unless its certified as a "Large Model") right?
As far as "bashing" everything FEJ, all I have ever done is describe my experiences with FEJ (many years before this incident) and the fact that I did not believe that anything has really changed. There are now 15+ pages in this thread indicating that I had a valid point, don't you think?
Bob
#431
I was informed that Ken isn't the owner of FEJ... did they sell? 9 days later and still no word from the "boss" at Fly Eagle. Ridiculous!
#432
Bob you are correct, u need to speak on your experience with any jet or jet company. I will also speak on my ton of experience with my jets
The style of flying is debatable. I hear that some people fly fast and aggressive and thats ok. Personally, i don't fly that style. A few loops and cuban 8 and split s are fine with me.
ianober- not sure why you so upset. Someone stated that no f-14 had more than a 140 for turbine and i stated my f-14 had k170.
I paid about 7 for both of my jets.
#433
ORIGINAL: Wap4life
#435
Dubd u told me u paid 6200 and i was negotiating. Sorry trying to get the best price. The first one cost me $6800. As i told you before i wanted a particular color.
Sicklick- if you read the all the entire thread it's there. I lost control pilot error. I know it's hard to believe but every now and then a plane crash because of the pilot and or the builder did something wrong. It's not always the Jet companies fault.
#436
My Feedback: (10)
ORIGINAL: dubd
The factory also gives discounts to the people that create build threads and publically praise them. Your average consumer has to sift through a lot of smoke and mirrors to get unbiased information. It's worse than buying a used car!
It will be easier to prove why your stab fluttered than who is a shill. Trust me.
#437
Still no response from FEJ about their reasons for blaming the crash on the electronics or batteries, yet their reps are viewing this thread right now.
#438
My Feedback: (23)
ORIGINAL: dubd
I would be amazed if someone from FEJ would respond since its a pretty unanimous decision that there was a structural failure
#439
My Feedback: (78)
ORIGINAL: Airplanes400
I'd like to say many thanks to this guy for his contribution of slowing down the video to capture what actually happened, and allowing the cause of the crash (design & structural flaws) to come to light. The stabs began flapping (fluttering). That resonated to the fuse, thus causing the fuse to twist. Whereby, breaking the aft bulkhead, and allowing more twisting on the fuse combined with further flutter leading to total loss of control.
Also, luckily, there was a video of the flight too.
FEJ can't wiggle out of this one.
Thanks!!
ORIGINAL: JimBrown
I have no idea if this will help or not, but here is the pertinent bits of the original video run through a video stabilizer.
...jim
...jim
Thanks!!
B-1 Bob
when FEJ are outlawed only outlaws will fly FEJ
#440
My Feedback: (57)
ORIGINAL: 1/2 time show
that video showed nothing more that a flutter that could of been prevented. I showed him what I did to my linkage before he ever flew his jet but he had a expert say that he did need to do this small mod. So how come no blame is being passed to this expert. all you guys are jest guessing that the bulkheads faled. in fact the flutter caused every thing that happend
B-1 Bob
Thanks!!
ORIGINAL: JimBrown
...jim
...jim
Thanks!!
B-1 Bob
#441
My Feedback: (22)
B-1 Bob
Thanks!!
ORIGINAL: JimBrown
...jim
...jim
Thanks!!
B-1 Bob
What makes you so damn sure about that? You have no evidence of your statement any more than those thinking the soft bulkhead is what caused the flutter in the first place.
Seems to me outlaws historically were murderers right, will fej aircraft be the modern weapon of choice?
Yes, that was a stupid comment, almost stupid as b1 bobs.
I ask you this, would you have built a bulkhead out of honeycomb with a small piece of plywood for your thud? How about for the big B1 bomber that you gave up on?
It sure is great to have such a credible expert weigh in on this....
#442
What scared me the most was the telling x-rays that showed that the shaft was only supported by honeycomb material as well. If these had become compromised, wouldn't that have also contributed to the excessive play of the stabs on the shafts and inevitable flutter? How many more sets of stabs are out there that are constructed the exact same way? I think the focus should not just be on the fuse formers, and stab linkage supports.
Sorry to see this happen.
Dan
Dan
#443
that video showed nothing more that a flutter that could of been prevented. I showed him what I did to my linkage before he ever flew his jet but he had a expert say that he did need to do this small mod. So how come no blame is being passed to this expert. all you guys are jest guessing that the bulkheads failed. in fact the flutter caused every thing that happend
B-1 Bob
Thanks!!
ORIGINAL: JimBrown
...jim
...jim
Thanks!!
B-1 Bob
I had a lot of respect for you until this last post...
I really wonder what is going on behind the scenes with the consumer reps and FEJ. How about I PayPal you $500 towards your next plane and you say some positive things about me?????
#444
My Feedback: (78)
[quote]ORIGINAL: LGM Graphix
B-1 Bob
Thanks!!
ORIGINAL: JimBrown
...jim
...jim
Thanks!!
B-1 Bob
[/quote
dude you are unreal that evidence do you have? jest a stupid ass guess
#445
Guys one thing to remember is the consumer reps are going to come into this thread to stir the pot hoping that this thread spirals out of control forcing the moderators to shut it down. Please do not let that happen.
#447
My Feedback: (22)
[quote]ORIGINAL: 1/2 time show
You are the unreal one Bob, your GUESS is no more factual than mine was. The difference is you come across as though you know for absolute fact. Again, I ask you, would you build one of your thuds with a honeycomb bulkhead on a major structure?
[/quote
B-1 Bob
Thanks!!
ORIGINAL: JimBrown
...jim
...jim
Thanks!!
B-1 Bob
[/quote
#448
It’s a free country so I am going to put my two cents worth in. B1 Bob did experience flutter on his elevators and had to perform a modification to fix it. This has been stated. As I understand it the jet that crashed did not have this mod. The video showed flutter and flexing of the stabs. I think the possibility exists that flutter could have caused this entire chain of events. Flutter caused the stab to start flexing this caused the rear of the fuselage to start twisting and then we end up with a unfortunate crash. As with most plane crashes there is seldom just one cause usually several things contribute. I hope you guy’s stop cutting each other down over different opinions.
#449
ORIGINAL: ddrake24
The real question is what caused the stabs to flutter or oscillate. FEJ says it was caused by my batteries or electronics. I am waiting for them to say how they came to that conclusion.
#450
My Feedback: (162)
I was talking to a friend about this thread the other day. I don't know for sure what caused it to crash but if I were to build one there are definately several things I would make sure and do. First is reinforce the whole bulkhead especially around where the servo mount is. Next is reinforce the control rod in the stabs whether injecting epoxy into them or reinforcing with some ply. Then whatever the recommended throw is match the servo max throw to that which would most likely be a lot less than 1 to 1 throw for better leverage. I learned a lot about that from pattern, heli and 3d flying. Lastely, if you want to keep the jet for more than 1 flight, never use a xps radio system
