Fly Eagle Jet F-14 Crash (video)
#1926
Banned
RE: Fly Eagle Jet F-14 Crash (video)
Some of those planes may come in at under 55. Most will not. The F14, no way.
ORIGINAL: Area51.5
I never even thought about this part, so from what is said above anyone flying the large f-14s, 18s, 15, and 16s should be on the LM list?
#1927
AL
So im guessing there should be a lot more jets on the list. I have never really checked weight and just always went with factory specs.
ORIGINAL: quist
If they are over 55lbs full of fuel and smoke oil (if you have smoke), yes they need to be inspected and paperwork sent to the AMA.
ORIGINAL: Area51.5
#1928
ORIGINAL: quist
ORIGINAL: Area51.5
#1930
My Feedback: (29)
TX
ORIGINAL: tamjets
No thanks...selling kit is bunch of headache and babysit bunch cry baby don't know how to do things right.
Been there done that.
Can someone local help? He's OBVIOUSLY out of beer!
#1932
ORIGINAL: smitty1001
OUCH TAM!?!?!
Can someone local help? He's OBVIOUSLY out of beer! [img][/img]
ORIGINAL: tamjets
I had guys even bug me on the weekend for support. I try to help. They don't understand how to do it. Start act like a kid and said things should said. I told him good luck. Now he email me everyday to appoligize for his bad behavior and need help.
I just put him to my less important person lists.
I told myself don't care what anyone thinks. I had done my service. If they want more. Good luck.
#1933
ORIGINAL: smaze17
This is how you felt about your customers who purchased your airframes?
ORIGINAL: tamjets
ORIGINAL: RCJetBazz
No need at all, much has already been discussed, you won't contribute anything that hasn't already been dicussed. If anything I encourage Tam Jets to increase your line of models for the market.
ORIGINAL: tamjets
That is truth...there is many things lead to cause the crash.
If you want me to discuss things can done better that can safe this crash. I can write a long lists of things to do and not to do.
But most of you more intersted to shut FEJ down than listen to those had built 100 jets succes flight.
ORIGINAL: RCJetBazz
I am sure your pivot point location has good merit, but to assume that is the ONLY cause of their failure is ridiculous, let alone thinking that is a contribution to FEJ who doesn't listen to anyone.
To judge your fellow modeler's voicing isn't exactly high class itself.
ORIGINAL: tamjets
Put yourself to they level is not make yourself look any better.
I had mention very early on these thread.
Let them fall on their own.
You don't need to push them over the cliff.
Is not make you any better person in my opinion.
I do give respect to those willing to share and help other modelers that still had this kit looking for help to fix the problem.
But not supporting using RCU to shut them down.
Is just low class.
Is just low class.
#1934
OUCH TAM!?!?!
ORIGINAL: tamjets
#1936
ORIGINAL: ChrisPetersen
No according to AMA LTMA-1 ''guidelines for large model inspection page 6, sec a the Aircraft should be inspected by the owner ''or'' an LMAI.
#1937
Just share the pain with hobby business. It s very normal and been doing over 20 years. Nothing new. Always new one come alone act like spend money and think you owe them life support.
#1939
My Feedback: (198)
ORIGINAL: AndyAndrews
They must be ''self inspected'' correct? From what I have heard there is a lot of ambiguity in the new weight rules which can be interpreted differently by different people.
ORIGINAL: quist
ORIGINAL: Area51.5
On an aircraft between 55 and 77lb wet the model may be inspected by the builder/owner of the model, but it still must be flown in front of a CD, leader member or LMA inspector. They will sign off that you flew the plane, and the plane performed as expected and the pilot performed as expected.
Pilot proficiency is a very important part of the sign off flights.
Any pilot that wants to be involved with large aircraft should become familiar with AMA DOC 520A.
#1940
Banned
And Dantley did none of these?Thus endangering our hobby?
ORIGINAL: quist
Any model over 55lbs wet must be inspected and have the paperwork sent to the AMA. If it is over 35kg 77.? lbs, the model must be inspected by an LMA inspector.
ORIGINAL: quist
ORIGINAL: Area51.5
#1941
My Feedback: (23)
ORIGINAL: tamjets
#1942
NV
Tam,
We all know that you have been making quality pipes for many years, (i own 3 of them)lets say you have a brain storm and come up with a new material to build your pipes. It is cheaper, stronger, lighter and easier to work with. You sell your new and improved pipe and before you know it they are collapsing like a house of cards in a monsoon. Do you replace the pipe, plane, equipment or give your customers the finger and say better luck next time?
#1943
Tam is not the issue here.
You all know Tam makes top quality products weather it be the best pipes or the best Super Hornet. Give the guy a break. We shouldn't b beating up a bloke who is at the top of his game in terms of product quality and customer support.
Levi
Levi
#1944
ORIGINAL: Area51.5
If I was running an event I too would weigh models and not let any over the weight limits fly without the correct paperwork.
John
#1945
Self inspected?!? What's the point ....
Me : "Right, this big old heap of junk is over 55lbs. Best inspect it for safety"
Me : "Hmmm, that's a bit dodgy but will be OK"
Me : "Hmmm, never really liked it like that but it shouldn't fail"
Me : "Oh, forgot about that. Never mind, nobody will see it"
Me : "Cool. Passed. Right, off to fly at that big event infront of hundreds of members of the public...."
Sounds crazy. As John said, in the UK over 44lbs dry and we have to go through the LMA (large model association) scheme with inspections, flight witnesses and paperwork submited and stamped by the CAA (equivalent to your FAA).
#1946
In Germany I believe the organisers at JetPower last year actually weighed large models and checked them against the declared weights before allowing them to fly
Normaly your model will be weighed also before starting German Masters.
If the model is more than 25kg, you get no permission to start.
Also our model flields in Germany have normaly a limit of 25kg.
Christian
#1947
NV
I know Tam is not the issue, and I am not trying to make him the issue. All I am asking is, how would he handle the exact question I askedseeing how he has been in business for over 20yrs, has agreat reputationand he is very opinionated about this whole FEJ thing.
#1948
Nor do I want to make him the issue Ghostrider, but I believe you do have a valid question for Tam. Further, what I can't agree is how he was trying to shut dubd up. I believe as long as FEJ has not corrected the situation and the dubd hasn't violated RCU rule, then it is all up to dubd. IMHO The worst thing you could do is to take away his voice. btw, your business in this hobby for 20 years doesn't mean that you are right.
#1949
Banned
ORIGINAL: GhostRider 1
#1950
YOU guys just care have fun trolling and bashing each other.
The days that you all lost the previlage to play this toys. You goes to facebook cry why we lost it.
You thinks just though about this.
Many doesn't put their voice here had the same concern.
Just few worm can cause a lot trouble for everyone.
