Reload this Page >
Avanti XLL from Skymaster
Old 06-26-2014, 11:13 PM
  #226
FenderBean
FenderBean's Avatar
Yeah, Im just not willing to put that much into a sport type jet. I think the 50 pounds will be okay without smoke oil in the tanks, im looking to take advantage of some high alpha slow passes and a few other things while maintaining a good top speed. I have a 14 to build as well soon as well. Any word on your BF300 pipe/vector pipe yet?
Old 06-28-2014, 11:04 PM
  #227
pilot tw
formation fly in Taiwan
ID:	2009701   Click image for larger version
ID:	2009702   Click image for larger version
ID:	2009703   Click image for larger version
Old 06-29-2014, 07:04 AM
  #228
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Jeff T. said they have built the pipe, I asked to verify that they have tested it and made sure it is working properly, certainly don't want to be the geniue pig on something this big and expensive.
Old 06-29-2014, 07:29 AM
  #229
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
Thy have been flying the pipe with VT nozzle.
Should have final results and pricing soon.
Old 06-29-2014, 07:45 AM
  #230
FenderBean
FenderBean's Avatar
Hey Jeff if I run 50lbs of thrust the stock pipe should be fine correct?
Old 06-29-2014, 07:55 AM
  #231
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
No problem. I have over 40 flights on mine with my evojet 220. No issues at all
Old 06-29-2014, 08:15 AM
  #232
FenderBean
FenderBean's Avatar
Thanks for the info, that was what I was planning to use in mine
Old 06-29-2014, 08:18 AM
  #233
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
I honestly rotate at around 40 feet and climb out at a 45 deg angle.
I fly fly at about half throttle with main tank only. Land after 6 min with a little under half tank left
Old 06-29-2014, 09:06 AM
  #234
FenderBean
FenderBean's Avatar
That's good info, I always build my stuff super light using the best weight saving techniques I can think of. I normally come up about 3 lbs less than stock weight, I try not to add all the bling just use my standard setup on every thing I build. Im looking forward to not having to worry about flight time with this jet. Thanks again
Old 06-29-2014, 11:41 AM
  #235
asimatt
My Feedback: (26)
asimatt's Avatar
This will give you an idea about power to weight ratio for hovering. Plane weighs 28 pounds and has a Jet 180
http://youtu.be/zSkg6-Wj6JQ
Old 06-29-2014, 06:02 PM
  #236
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
have they done the tests with a b300f?, A 50Lb turbine and a 72 lbs turbine is a big difference.
Old 06-29-2014, 06:22 PM
  #237
pilot tw
not yet, because we make the new bell mounth for the 30kg thrut tailpipe, and we will send the new tailpipe with VT nozzle to Sebart for test the 30kg thrust before deliver to customers,
Old 06-29-2014, 06:24 PM
  #238
Jason W M
Yes, Seba has been flying the XL with the B300F and thrust vectoring (using a pipe from another manufacturer) with the same success as the Avanti S 2.0m/79" and 180-250 turbines. Here's a quick video of him down low with it and some additional info below (plus he'll be sending us more details and better video soon):
https://www.facebook.com/photo.php?v...type=2&theater
CIAO
AVANTI XL PRODUCTIONSERIE MODEL FLIES...AND VERY GOOD !
MY IS EQUIPPED WITHBF300 AND VEKTOR SYSTEM
IT WEIGHT 19.5 Kg EMPTY
HERE THE VIDEO OF ONE OFTHE FIRST FLIGHTS: http://youtu.be/T4BPo_tK6Jk
(NEW & HIGHERQUALITY VIDEO WILL COME SOON.... )
SINCERELY
SEBA
Old 06-29-2014, 06:44 PM
  #239
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
I see so I will wait until you guys finalize the B300F pipe and details.
Old 07-07-2014, 02:18 AM
  #240
pilot tw
nice color scheme for Avanti XXL, painted by Morne himseft !
Old 07-07-2014, 11:03 PM
  #241
MNModels
MNModels's Avatar
Hi,
Thanks Anton,
Some more pictures. A really outstanding model with outstanding flying characteristics. Very well designed as we have come accustom to be Sebart! What would an Italian design be with out Ferrari.....
Rgds
ID:	2012530   Click image for larger version
Old 07-08-2014, 04:02 AM
  #242
charlyjet
charlyjet's Avatar
Hi Morne check PM
Old 07-08-2014, 05:36 AM
  #243
MNModels
MNModels's Avatar
Carlos,
I can not return your PM. You have enabled to not received PM's....
Rgds
Old 07-21-2014, 05:58 AM
  #244
Helijet
Any customers building or flying this big girl yet?
Dean W.
Old 07-21-2014, 07:33 AM
  #245
FenderBean
FenderBean's Avatar
give me 3 months i will get back to you
Old 07-21-2014, 07:50 AM
  #246
schroedm
schroedm's Avatar
Did I notice from pics that the flaps are hinged with robart hinges? Is everything else live hinged. Rudder looked to be pin hinged in one pic.....
Old 07-21-2014, 08:20 AM
  #247
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
All live hinged with exception of the rudder
Old 07-21-2014, 10:19 AM
  #248
MNModels
MNModels's Avatar
Hi Jeff,
You must have the early version. All Avanti XXL have no live hinges. All hinges are wired. Long piano wire that ca be pulled out to remove flying surfaces....
Rgds
Morne
Old 07-21-2014, 10:28 AM
  #249
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
Yes. I do have the early version. I knew they where moving to all wire hinge as my rudder is that way. But was unclear that this had been done. Thanks for the update Morne.
As for flying. I have about 50 flights on it so far. It's one of the best flying jets Iv ever flown.
Slow flight is superb and the slow knife edge figure 8's are a blast!!!!
I use the main tank only and fly for 6 min with just under half tank left.
This is with an evojet 220.
Old 07-21-2014, 01:51 PM
  #250
schroedm
schroedm's Avatar
Here's some B300F hovering action (you can almost feel you're there!!)
https://www.youtube.com/watch?v=uiXqArGtCtk
