Reload this Page >
Eflight Blanik 4.2m with turbine?
Old 07-23-2014, 07:38 PM
  #151
jet junkie
Mounting Fuel Tank
Old 07-23-2014, 09:59 PM
  #152
chrigui
Originally Posted by cairoman
This turbine mount for sale Chrigui??
Chris
yes for sale from italian manufacturer..
Old 07-24-2014, 07:11 AM
  #153
cairoman
cairoman's Avatar
Hi Chrigui,
Can you publish, this manufacturer's name please?
Chris
Old 07-24-2014, 07:16 AM
  #154
chrigui
http://www.osvymodel.it/index.php?op...=46&Itemid=527
Old 07-24-2014, 08:00 AM
  #155
cairoman
cairoman's Avatar
sent him a request for a quote.
Chris
Old 07-24-2014, 09:03 PM
  #156
jet junkie
Adjustable movable until spot found Rudder servo mount!
then exopy'd in place ! had to place fuel tank lower as to be able to get to the wing bolts easily
Old 07-24-2014, 09:22 PM
  #157
trippergreenfeet
Chris
Be sure to sit down first before reading the quote!
Old 07-24-2014, 11:26 PM
  #158
Dave Wilshere
Worked late on mine last night. 24oz smoke tank and 60 oz fuel tank. JR X Bus system being used.
Dw
ID:	2017244   Click image for larger version
Old 07-24-2014, 11:56 PM
  #159
jet junkie
G-Day Dave! looking good buddy!
Quick question...How are you planning on getting all 4 wing bolts in and out with the tank in the way? (keep removing the tank?)
I went to an extreme design to be able to get all 4 wing bolts in without having to move the tank ..but did move the Rudder servo so i could drop the tank all the way down so I could get my hand under the spar tube to get to the rear wing bolt...minor adjustment as I have all the cad/cam at home so few mouse clicks and it was done...Smoke you say....Hmmmm I used a pillow bladder made from a drink in the uk for one before..Me thinks me better do it again! can easily shove that under the main tank no worries, also ive placed my fluids in the middle of the CG so no trim required as it flows out, Im going with the Turbine guys discovered 50mm sweet spot..so we see how that turns out in actuall flying air
here is the rudder working....If I flap it fast enough i could get it to self launch!
hehehehe
http://youtu.be/mArjPcJ4Gbw
Old 07-25-2014, 02:03 AM
  #160
Dave Wilshere
Only using the front pair, I have painted the wing spar with finishing resin to get a good fit. Stevie is flying one already with this install and its been fine. As we are flying formation I have a very similar layout to him. He even designed the turbine mount once we decided how it would be done. Its 5mm Carbon ply Carbon
Will post more pixs later, I'm picking at it between work today
Dave
Old 07-25-2014, 03:58 AM
  #161
chrigui
Hi Dave...
the CG is 20mm like instruction indications or 50mm / 55mm?
the fuel tank is 1,5 lt?
Christian
Old 07-25-2014, 12:27 PM
  #162
Dave Wilshere
Christian
I went 30mm-tanks with a little fuel/smoke (they are both behind the balance) so fully fuelled it maybe 45mm. For sure 20mm is nose heavy!
1.8ltr (or US 60oz anyway) 24oz main smoke and 12oz smoke hopper in the nose. 2oz MAP hopper tank for turbine. Smoke pump and fuel pump in nose, 3 x 5000 2s Li-Po packs It looks like 400g lead only!
Dave
Old 07-25-2014, 01:30 PM
  #163
Dave Wilshere
Workshop is trashed again, but just about ready. Pegs gluing, airbrake covers gluing. Radio set up, turbine run.
Old 07-26-2014, 03:23 AM
  #164
jet junkie
http://youtu.be/ctIgUpv834c?list=UU44DH8GWvMgg5zGis5FPVTw there ya go can flap it home if I run out of Air!
Old 07-26-2014, 02:23 PM
  #165
Dave Wilshere
Flew the Blanik today, brilliant!
Couple of pics of the sister model for the Formation Masters (no one photographed mine :-(
Dw
ID:	2017548   Click image for larger version
ID:	2017549   Click image for larger version
ID:	2017550   Click image for larger version
Old 07-27-2014, 04:23 AM
  #166
snobird
My Feedback: (36)
snobird's Avatar
Hi Dave, flying mine with front screws only, no issues, recommend air brake, and CG back around 50mm. I'm using a KingTech 60 . And a Cortex....love it !,
Do you know if anyone is doing scale details for the CARF. J-10
Old 07-27-2014, 07:48 AM
  #167
Dave Wilshere
Just back from a long day at the field practicing with the two Blaniks. I have around 10 flights on mine now, love it! We have smoke and airbrakes and flying formation is easier as you can "slam on the brakes" if you are ahead.
I'm using the smoke tank hopper as part of my nose weight and can say I'm flying quite a range depending on fuel and smoke useage. Maybe 40-60mm back and its still nice!
Here is my tip wire skid mod. works well for hands free takeoffs
Dave
Here is our turbine mount. Single 4mm carbon blade, slot fuselage top, for lug, glue to fuse top and wing tube. We then have a cross brace running across the rear and a flat plate to take the tank.
I took my services through the top windows as the fuse is already minimal around there.
Dw
Name:	DSC_0319 (Small).JPG
ID:	2017729   Click image for larger version
Name:	DSC_0322 (Small).JPG
ID:	2017730   Click image for larger version
Name:	DSC_0256 (Small).JPG
ID:	2017731   Click image for larger version
ID:	2017739   Click image for larger version
ID:	2017740   Click image for larger version
Old 07-27-2014, 09:47 PM
  #168
chrigui
Originally Posted by Dave Wilshere
Christian
Dave
many many thank's Dave!
Old 08-14-2014, 03:08 PM
  #169
i3dm
My Feedback: (51)
whats the recommended turbine size for the blanik? p-60 sizE?
Old 08-14-2014, 10:33 PM
  #170
Dave Wilshere
P-60 is good, really depends on your expectations. You get a reasonable size loop from straight and level.
Mine takes off grass in around 30-35m.
Dave
Old 08-15-2014, 10:36 AM
  #171
chrigui
i'm finishing my blanik
(removable wing tips)
Old 08-15-2014, 11:25 AM
  #172
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Anyone if replacement tips can be bought? I did not see it on the Horizon website
Old 08-28-2014, 04:36 AM
  #173
chrigui
Old 08-30-2014, 05:18 AM
  #174
jet junkie
Just upgrading power from the P60 to P100SX as found a new one for a great price so can keep my P60 for the Nano boomerang...
Old 08-30-2014, 07:09 AM
  #175
Dave Wilshere
Fin & Rudder will need some proper heat protection work.
