Reload this Page >
Ripmax Xcalibur Sports jet
Old 12-08-2013, 12:35 PM
  #276
Jetflyer3000
Banned
Good price for the model (with free delivery here) £495
http://www.kingslynnmodelshop.co.uk/...duct_info.html
With stock gear here £ 427
Old 12-08-2013, 12:40 PM
  #277
Dave Wilshere
Originally Posted by Gambler71
Thanks Dave, much appreciated. I would like to use a set of Behotec C36 retracts (air up/spring down), as I've developed an unhealthy dislike to air/air retracts. I'm just looking at options for Oleos, wheels and brakes. Would the 105mm oleos for the Nano on your site fit?
The retracts are brilliant, proving to be as reliable as Behotec's. We fitted a set of Behotec C-36/2 in one of the prototypes, but the mounting has been changed to suit Ripmax's gear. You will have to pack quite a bit. No the Nano legs won't fit and are not up to the job anyway with 4mm pins. You could have Airtech Germany legs machined to fit, but the gear will cost a lot more and honestly, I'd stick with the stock gear, it works perfectly and holds air for ages.
Dave
Old 12-08-2013, 01:07 PM
  #278
Worzey
A few pictures of the Xcalibur I have just assembled.
As yet unflown, the model is powered by a Wren 100 and uses Hitec HV metal geared digi's all round.
With a 3300mA 2S ECU lipo and 2 x 1800mA 2S Rx lipo's, the model needs 300g's of church roof in the nose.
Looking forward to test flying it before handing it back to the owner.
Chaps, pictures below are big, so click on top pictures for quicker viewing......Don't know how to delete big images??
Name:	2013-12-07 12.33.14.jpg
ID:	1945910   Click image for larger version
Name:	2013-12-07 14.52.46.jpg
ID:	1945912   Click image for larger version
Name:	2013-12-07 14.50.58.jpg
ID:	1945913   Click image for larger version
Name:	Xcalibur - small 1.jpg
ID:	1945914   Click image for larger version
Name:	Xcalibur - small 2.jpg
ID:	1945915   Click image for larger version
Name:	Xcalibur - small 3.jpg
ID:	1945916   Click image for larger version
Name:	Xcalibur - small.jpg
Old 12-08-2013, 01:15 PM
  #279
Dave Wilshere
You can almost certainly remove some of the weight once flown. We have been shifting the weight back on both Paul's and the Ripmax demo model. I think Paul has now removed 60 grams. I found Ripmax's model was in front of the manual balance when I first got it, I shifted it back to match, but more flying has shown it can go back a little more.
D
Old 12-08-2013, 01:36 PM
  #280
Worzey
Dave
Would you say that rather than adding 300g's as required to achieve balance as per instructions, I could comfortably ad less.....Say 200g's?
Is the recommended C of G as conservative as, say a BV's Bobcat recommended c of g?
Maybe you would advise set up as per instructions and "adjust to taste"?
Old 12-08-2013, 02:12 PM
  #281
Paul0088
I have taken 80grams from mine so far, take off runs are shorter now, could go more, have to see next time out.. started with CG at 170mm, not sure how far it is now will measure next time..
Old 12-08-2013, 03:16 PM
  #282
Dave Wilshere
Originally Posted by Worzey
Dave
How accurate was you balance check? I'd say add enough to get it 1/4" behind the manual position and then experiment. Everyone likes something different on how neutral an aircraft handles.
Dave
Old 12-09-2013, 08:25 AM
  #283
Dave Wilshere
I believe that the Oleos for this aircraft are "socket" type. Can someone tell me what the diameter of the sockets and their depth are please?
Dave
(1/2") 12.6mm x 18mm deep
Old 12-09-2013, 10:22 AM
  #284
tp777fo
My Feedback: (28)
tp777fo's Avatar
Any update on when the US kits will start showing up?
Old 12-10-2013, 11:41 PM
  #285
mikedenilin
My Feedback: (67)
We got one in Jose's hand now. He is putting it together.
The first batch for US was destined to finish at the factory at the end of this month and will take a ride on whatever container my other business have right after. Mike
Old 12-14-2013, 09:39 AM
  #286
Worzey
Just got back from doing the maiden and two further flights with the Xcalibur.
I set the c of g 10mm behind that shown in the manual and found the model well behaved with the recommended control throw set up. Next time out, I will reduce the aileron expo from 20% to 10% (personal preference) and move the c of g back a further 5-10mm, as I found I needed approx 1/4 of down stick to maintain inverted (again, personal preference). However, the manual recommended set up makes for a VERY well behaved model.
The Wren 100 gave very good take off and vertical performance. First flight with good use of throttle, left me with the fuel level approx.10mm below the fuel bung, having landed after 6 minutes. The following two flights left me with approx. 15mm in the bottom of the tank, using high throttle settings for about half of the flight, then landing after 7 minutes.
This model has a very good speed range.....Full throttle for two circuits saw the Xcalibur going slightly quicker than my Supersport powered Elan and full flap/crow with the engine at idle got the plane to hover in a 17mph headwind. In fact, carefull use of throttle and elevator, with full flap and 8mm of crow got the plane moving backwards very slightly!!
An ideal first jet with a great speed range and good grass/short field capabilities (uses 1/2 of our 100m grass field). Quick to put together (I did 4 days and 8 evenings of assembly time) and an easy to follow manual. I think there are going to be a lot of these showing up at small clubs over the next 18 months!
Ian
Old 12-14-2013, 10:00 AM
  #287
Dave Wilshere
Ian
Goodo, balance is personal preference, I like a little down load inverted as I find it smooths things out. Ailerons are not twitchy, so reducing the expo to suit is normal.
Dave
Old 12-14-2013, 02:07 PM
  #288
PVS41960
If anyone wants a complete Excaliber (from the first batch arriving soon) at the introductory price (1200.00), give Kwang Ko (authorized US dealer - Virginia) a call 703-664-2016. I ordered the military scheme, 12-12-13 & I believe he has 2 more kits to part with. I'm not sure what schemes they are.
Paul
Old 12-14-2013, 02:26 PM
  #289
PVS41960
Originally Posted by Dave Wilshere
Now got wings bags for the Xcalibur. Nice lined sets to protect from hanger rash.
Dave do you have a US price on the wing bags
Old 12-15-2013, 02:38 AM
  #290
Worzey
A short video of maiden.....including far from perfect first landing!!
http://www.youtube.com/watch?v=O2bb6yK2NHQ
Old 12-15-2013, 02:49 AM
  #291
Dave Wilshere
We don't ship to the USA, but you might be able to order here www.aerotrimwingbags.co.uk
Old 12-15-2013, 07:23 AM
  #292
Nev01
Hi Ian,
Well done on your maiden. I would like to one day own an Xcalibur, (I've wrote to Santa ) it looks ideal for my first jet. I have watched your video and all I can say is, I would be more than happy to land it as well as that first time out considering what my nerves would be like.
Nev.
Old 12-15-2013, 07:42 AM
  #293
Jetflyer3000
Banned
Will the next batch be ready for Christmas I wonder ?
Old 12-15-2013, 07:43 AM
  #294
Worzey
Nev
It's a great model and well suited and priced to a newcomer to RC jets. It's also well suited to the average club field.
I fly many different jets from our field and was surprised how much the Xcalibur floats on, which is why my first landing in the video was aborted. The second approach was still a little too fast, so I pushed it onto the ground instead of going round again, as I was unsure of fuel left. As it turns out, I could have easily done a number of aborted landings as I had nearly 1/2 a tankfull left!
Ian
Old 12-15-2013, 08:06 AM
  #295
Nev01
Ian,
I'm in the market for new transmitter, what do you use or advise me to look for with the Xcalibur in mind? I have no loyalty to any particular brand as I will be keeping my old transmitter for use with older planes/Rx's. I know I have asked this question of others but it all helps me with my decision making.
Cheers, Nev.
Old 12-15-2013, 08:47 AM
  #296
PVS41960
Thanks Dave
Old 12-15-2013, 12:33 PM
  #297
Worzey
Nev
You could easily set up the Xcalibur with a 7 channel set, using separate aileron channels and a mix with down elevator for wheel brakes (using the gear servo to over travel and operate the brake valve). I set up my old BVM Composite Bobcat in this way with a Spektrum DX7.
However, a 9 channel set makes set up easier giving the option to put the nose steering on a separate channel and the wheel brakes also on a separate channel.
I use my trusty old JR DSX-9 which I find easy to set up, but I guess all makes/models are easy to use once you are familiar with the menu structure.
I do feel that putting the ailerons on 2 separate channels is usefull, as a "crow" mix with flap works very well with this plane.
Ian
Old 12-15-2013, 12:56 PM
  #298
Dave Wilshere
Ripmax's demo model that started this thread has a 7 channel Rx and two valves for the gear/brakes. I'm not a fan of Y leads on main controls, but this model has a lot of flying now and its been faultless.
Nev you can buy some of the new DMSS radios with an extra free 8 channel Rx. If you don't need the extra Rx you can even move on the spare and get some of your money back!
I'm looking forward to adding some CROW to my example, the Xcalibur is very clean (hence it flies so well on low power) So any added drag is a benefit. But with the flap near 90 degrees I have no problems landing it on our short grass strip, Paul's is the same, no CROW.
Old 12-16-2013, 02:08 AM
  #299
jimmers123
Hi Nev 01 R3 can you post pic of mod of elevator plug to boom plug
From Jimmers
Old 12-16-2013, 09:31 AM
  #300
Jonboy2
My Feedback: (62)
Hey Paul,
Do you have any other number to contact Kwang Ko? I have been trying to call for several days and it is always busy. I would like to see if he still has any unspoken for kits available. Thanks Jon
