Reload this Page >
Ripmax Xcalibur Sports jet
Old 07-27-2014, 10:16 AM
  #826
DominicM
DominicM's Avatar
Recent flight of the new scheme at the Cosford Large Model Association Show in UK...I think it looks great but I am a little biased being a Brit...
http://www.youtube.com/watch?v=6D2lIBC6h64
Old 07-27-2014, 11:36 AM
  #827
r 3
r 3's Avatar
Wren 54 out and P100 fitted and ran it up today and all seems ok. So hope the weather is ok when you come up Dave and you can check it over and do a maiden for me. So it has worked out at total weight 8.9KG and had to put a 168g in the nose to get the C/G 70mm.
ID:	2017770   Click image for larger version
Old 07-27-2014, 11:44 AM
  #828
Dave Wilshere
Billy. Goodo, see you on the 9th
Dave
Oh, now I zoom in I can see some issues, can't fly it with the pipe joint you have! Will send a 6-4 joiner or bring one. 8711 nose steering!! Over kill!!!!
Old 07-27-2014, 12:02 PM
  #829
FlyingMT
Have to say after watching Dave fly at Wings n Wheels the Xcalibur performed faultlessly completing an array of aerobatic manoeuvres including a limitless vertical on his Jetcat P100, awesome looking forward to test flying at North Weald, our members have two on the go and I think I'll get the job.
Old 07-27-2014, 12:10 PM
  #830
r 3
r 3's Avatar
I've got one how ever I think I would prefer the way it is unless you have a good reason to change it to a 6-4
Old 07-27-2014, 12:33 PM
  #831
Dave Wilshere
What you have will leak sometime!
Old 07-28-2014, 11:31 AM
  #832
76Mustang76
76Mustang76's Avatar
Dave,
Top advise regarding the use of insulation tape on retracts. What a difference it has made.
Someone asked me the other day. Are you sure that my turbine thrust angle is correct on xcalibur?. I have looked at other jets ie boomerang and ive noticed that the turbine sits horizontal and does not point down like on the xcalibur. Could you explain the reasons.
J
Old 07-28-2014, 02:36 PM
  #833
Aussie1
We had another club flying day last weekend, and for the middle of winter had beatiful weather. Another Excalibur turned up on the day and had it's maiden flight, and as usual, flew perfectly! I believe that another two are being prepared in workshops here in South Australia, so obviously, the word is getting out about how nice these aircraft are! Here's a couple of pics from the day.
ID:	2018100   Click image for larger version
ID:	2018101   Click image for larger version
ID:	2018102   Click image for larger version
ID:	2018103   Click image for larger version
ID:	2018104   Click image for larger version
ID:	2018105   Click image for larger version
ID:	2018106   Click image for larger version
Old 07-28-2014, 03:37 PM
  #834
rslstft
My Feedback: (10)
rslstft's Avatar
Wow, Aussie,
Looks like your winter is just great! Your field looks like a great place to fly also.
Old 07-28-2014, 03:56 PM
  #835
Aussie1
Originally Posted by rslstft
Wow, Aussie,
Thanks Russ, the strip was built years ago for all types of models, but particularly jet models.Every May, we have a large jet meet where pilots from all over the country come here and enjoy three days of jet flying. The club owns the 100 acre field outright, and it's a brilliant place to fly. As far as the winter goes, we have had record rainfall, so this day was a bonus as it was sunny and light winds.
Old 07-28-2014, 11:27 PM
  #836
Dave Wilshere
Originally Posted by 76Mustang76
Dave,
J
J
Used it for years on TL legs, always a benefit!
Most Boomers do have down thrust (most twin boom actually) it to get the high mass (air) flow away from the tailplane. It would make the air going under the tail faster than above and the tail would be pulled down...making it climb. Its why some twin boom models climb under power. The different turbines have different exhaust velocities and this can change the angle needed (higher would need slightly more down angle)
Dave
Old 07-29-2014, 05:38 AM
  #837
ausfester
I noticed my Excalibur trim changed at full noise.
Flying inverted, knife edge and with full flap was also difficult so I put a few washers under my custom made engine mounts, (which I suspect made mine worse vs the stock blocks supplied) to reduce the thrust angle. Only running a baby K80
Old 07-29-2014, 08:09 AM
  #838
Dave Wilshere
When trimming the engine angle, first you must set the balance correctly, elevator neutral. Various methods, but rolling or, pulling 45 degrees an 3/4 power, rolling inverted end releasing the elevator control.
Once that is set you can trim for level flight at 50% power and try full power and idle and see what happens.
Failing that and "lazy" people, throttle to elevator mix ;-)
Old 07-30-2014, 05:47 PM
  #839
lawndartz
Well i started building last night. Had Cornel come over and point things out and give me some guidance. Brought me his Hysol gun and showed me some areas of concern that i should stiffen up.
Aileron's.
Making Cables,
Elevator servo mounted.
Installed 2 screws on the back side, just for added protection,
Nice closeup shot of the glue,
Old 08-07-2014, 10:37 PM
  #840
Aussie1
As per my previous post, I am very interested in fitting lights on my jets. So far, I have been very pleased with the result, considering that I have not spent much money, but I came across some more globes that are even more powerful and may be better suited for the purpose. Using a 3S LiPo battery, these little globes are drawing about 115 Milliamps, which is not much.Rated at 110 lumens, they are nearly three times brighter than my earlier globes. The jet will just need to carry around another small 3S battery, and maybe a RC switch, only if you want to be able to switch them on and off remotely. Here are a couple of pics, so feel free to let me know what you think. In the pics are some other globes that I tried, but not as good as the Ecolume globes.
Previous post. http://www.rcuniverse.com/forum/rc-j...l#post11844129
http://www.jaycar.com.au/productView.asp?ID=ZD0557
ID:	2020827   Click image for larger version
ID:	2020828   Click image for larger version
Old 08-08-2014, 02:41 AM
  #841
Jeremy_D
Jeremy_D's Avatar
Great lights Aussie! Im heading to Jaycar tomorrow!
Old 08-08-2014, 03:39 AM
  #842
Paul0088
New batch just arrived at Motors & Rotors
Old 08-08-2014, 01:42 PM
  #843
Boomerang1
Boomerang1's Avatar
Dave,
What was the advice?
John.
Old 08-08-2014, 01:46 PM
  #844
Boomerang1
Boomerang1's Avatar
Can you run them from the ECU battery?
I tap off mine to run retracts & brakes.
Thanks for the go on the lights!
John.
Old 08-08-2014, 02:06 PM
  #845
Aussie1
John.
Guys, thanks for the kind comments on the lights! My first set of lights were rated at 6-8 volts and 40 lumens, and could be run directly from the ecu battery. These new globes are rated at 12 volts and 110 lumens, and they appear to be alot more powerfull. I have about 300 gms of lead in the front of my Excalibur, so will just remove the lead and put a 3S 1600 battery up there for the lights. I have ordered a couple of RC switches so that I can remotely switch them on and off. On a dull day, it certainly makes the jet easier to see and sort of looks like a UFO zooming around the sky!!
http://hobbyking.com/hobbyking/store...idProduct=8833
Old 08-08-2014, 06:58 PM
  #846
emart
I believe someone has posted about insulation tape on the retracts to stiffen the springs . Would you mind showing a picture of this please
Ed
Old 08-09-2014, 12:35 AM
  #847
Ricko1
Ricko1's Avatar
Ed,
Dave posted some photos of his retracts in post #534 on page 22.
Old 08-09-2014, 12:37 AM
  #848
Dave Wilshere
It was in my last RCJi article, I'm in Scotland, but sure there is a picture early on this thread as I did it from the start.
Dave
Old 08-09-2014, 10:15 AM
  #849
tp777fo
My Feedback: (28)
tp777fo's Avatar
Anyone know if any Excaliburs are in stock in the US. Friend needs one quick, crashed a jet today and needs a quick replacement before some events.
Old 08-09-2014, 11:04 AM
  #850
lawndartz
http://www.globaljetclub.com/index.p...roduct_id=2657
