Jeti-duplex-ds-16-2.4-ghz
#2526
#2527
I have the profi box and keep getting Alarm "E" which I believe is for MU-3, MULi6, MAXBEC2D-input the later is what I have installed. Alarm Generation not used. Am concerned about input to MAXBEC2D. Both Life battery packs installed. Transmitter states that batteries are 6.4 and 6.5. Both Green lights are on on the MZAXBEC2D. Why do I get alarm only on Profibox. Haven't been able to find any setting in profi box to see what to change etc. Help appreciated.
#2528
My Feedback: (7)
#2530
My Feedback: (7)
After you brought this up earlier I've been trying to reconstruct exactly what the issue was, what I did about it and why but it was over a year ago and I'm struggling a bit so take this all with a grain of salt.
As I recall, if enabled, the MAXBEC 2D would frequently (always?) trigger one of the Voltage based Morse Code alarms, regardless of voltage or alarm settings. I assumed this was a bug. I forget if it was voltage A or B that was the problem but it doesn't really matter as I simply used the Jetibox to set the Voltage based alarms in the MAXBEC2D to OFF using my Jetibox. This is only the Morse code based alarms. I then used the Alarm system in my DS16 to set appropriate alarms for Input A and Input B and those work perfectly. Since there was no reason to need multiple sources of the alarm and since the DS16 alarm system is much more useful than the Morse Code Alarms, I wasn't concerned about it..
If you set the Voltage Alarms A/B to OFF using the JEtibox, it should stop you from seeing Morse Code Alarm E all the time and still allow you to read Inputs A and B. Hope this makes sense.
#2532
My Feedback: (7)
Ok, I took a closer look this morning and I see how I took care of this. Since I'm using a DS16, I went into Morse Code Alarms, left the file for 'E" blank and also disabled Alarm E. It was over a year since I set this up but based on the fact I disabled Alarm E in the transmitter, I apparently wasn't able to get the MAXBEC to stop sending it no matter what I did with the Jetibox.
I don't own a Profibox but I did take a quick look in the manual and it appears to indicate that alarm E is unused but apparently that isn't correct.
Since I apparently struck out preventing the MAXBEC2D from sending Alarm E and disabled it in the transmitter, I'm not sure what to suggest with the Profibox unless it has a similar capability that I don't know about..
Sorry..
Sorry..
#2533
Hi, I have a DS 16 updated to 4.0,also an R14us rx updated to 3.24. I have an iGyro 3e , but I can't get any control response at all when the Gyro is in the system even if the gain is zero. When I power up the Gyro lights sequence I can then activate the gain and the lights change but there is no control response to the Tx sticks. I have tried all the obvious and even the suggestion from Esprit,to use a proportional control, made no difference. I have iGyro 3e in other models with other Jeti Rx and all work fine,it just seems this combo won't play nice !
Ant ideas would be gratefully taken on board.
Thank you.
Dambuster.
Thank you.
Dambuster.
#2534
Thank you.
Dambuster.
Thank you.
Dambuster.
If you have reversed them, it will behave as you describe.
Mike
#2535
My Feedback: (7)
Thank you.
Dambuster.
Thank you.
Dambuster.
#2536
Hi Guys,
Thank you for your answers, I have absolutely made sure the plugs are correctly orientated, I have now tried a REX 12 rx in the model and it STILL doesn't work,I have tried another 3e that works in another model with this REX 12 and it STILL doesn't work !
The model in question is an Excalibur so there is one elevator servo and two rudder servos, I understand , from Powerbox, that only one rudder servo can be connected and that is what I've done, I am now going to swap from the left rudder to the right to see if that makes any difference and the only other thought I've had is that , maybe, the twin rudder model configured in the Tx simply won't work with the 3e.
Please keep the suggestions coming as I am rapidly going bonkers ! Also should I find out why I will post that too.
Thanks again.
Dambuster.
Thanks again.
Dambuster.
#2538
CB200 not showing telemetry on tx main screen.
Hi guys,
Just a quickie, as above everything in Device Explorer ok but telemetry not showing on main screen, have I done something stupid?
A clue may be that on the Tx screen the tel boxes show as CB200-2, strange.
#2540
#2541
Anyone have any experience using the Jeti Telementry Sensor fuel flow Mflow turbine ex? Will it also tell you if you have a flame out? I have used the one that records the MA and gives you reserve fuel as well as flame out info before. i am wondering if this is a better way to do it.
Stan
Stan
#2542
My Feedback: (7)
Stan
Stan
If you've used the MUI in the past to monitor fuel pump current and estimate fuel usage, as long as you've been able to get fairly reliable results that way, I don't think the Mflow will be a huge improvement, especially when you consider the cost difference.
I'm guessing that there isn't a telemetry adapter such as the Xicoy unit available that supports the turbine you're using ?
#2543
O.K. guys,have to come clean..... there was no problem with the iGyro 3e or Jeti the problem was......ME. As suggested I had the connections,in and out, the wrong sides. Thanks to a good mate all is resolved, and I publicly thank him. He didn't even take the p**s !
Sorry for any consternation and thanks for those trying to guide me.
Note to all ......read the instructions.
Dambuster.
Dambuster.
#2544
Assuming you use a switch to turn your turbine on/off you should be able to create an alarm for 0 fuel flow, enabled by the turbine on off switch in the on position to detect a flame out.
The only problem I have is if I use a Taxi tank the unit starts counting as soon as the turbine starts, so it's not a true amount of usage as the main tank is full when the taxi tank is removed. Is there a way to put the counter on a switch so I can start the count when I remove the taxi tank?
Stan
#2545
Just an small tip for those use the Xicoy telemetry adapter and taxi tank, having the need to reset the fuel counter while the engine run. Just install an small switch between the ecu and the adapter, to momentarily cut the red wire to reset the adapter. Best way is a push switch, normally connected,that disconnects when pressed, but any RC switch that has the signal wire going through will do the trick.
Gaspar
Gaspar
#2546
Gaspar
Gaspar
I would really like to be able to reset the fuel counter from my Jeti Transmitter. I usually remove the taxi tank after the canopy is on and I have done my run up.
During a jet rally I will have to wait with the taxi tank attached sometimes.
Thank you,
Stan
#2547
My Feedback: (162)
i was thinking one of these http://www.dreamworksrc.com/catalog/...-On-Off-Switch would do the trick. Pull the tank, click a transmitter switch off and back on to reset it and be on the way..
#2548
Stan
#2549
My Feedback: (7)
