Reload this Page >
Post a picture of your CAT installation.........
Old 02-06-2014, 11:01 PM
Alpenglider
Alpenglider's Avatar
Hi Mark,
since i have used your Cat the first time three year's ago, i will not use anything else anymore!
I can forgett about flame outs and other issues, i am Cat convinced :-)
Attached a pic of my Viperjet xxxl i am building with two Cat's; one for Kero and one fir Smoke.
Cheers
Thomas
Old 02-06-2014, 11:58 PM
Mäksä
Mäksä's Avatar
Petri
Old 02-07-2014, 01:05 AM
marc s
marc s's Avatar
Wow great selection - and a pulse jet too
Skunkz if you wanted I could always make you one with the label in a different position - next time just email me with details, might take a couple of weeks as a special but doable.
marcs
Old 02-09-2014, 10:30 AM
PowerBoxDanny
My Feedback: (47)
PowerBoxDanny's Avatar
I'll keep that in mind!
Old 02-11-2014, 05:00 PM
Selleri
Selleri's Avatar
I'm afraid the install doesn't do it justice but I love my CATs.
Old 02-12-2014, 03:22 PM
  #31
icepilot
icepilot's Avatar
Here are a couple of pictures of my gen. 2 SM F-16 1:6 with the CAT installed - very nice unit, it's a must for the best planes!!
Name:	CAT Icepilot F-16.jpg
ID:	1967939   Click image for larger version
ID:	1967940   Click image for larger version
Old 02-26-2014, 10:44 AM
  #32
PowerBoxDanny
My Feedback: (47)
Man this is a big Air trap! Like a coke can! Going in my Yellow F18 with the P200. Don't know where it's gonna fit!
ID:	1972689   Click image for larger version
Old 02-26-2014, 11:44 AM
  #33
marc s
marc s's Avatar
Icepilot lovely jet mate - I can only dream!
Skunk the beauty is it can go anywhere - how about the centreline tank
marcs
Old 02-26-2014, 12:01 PM
  #34
Midas D.
Briljant product Marc!!
ID:	1972722   Click image for larger version
Old 02-27-2014, 06:04 AM
  #35
Alsacian
Hi Marc
Just received 2 CAT's 130 for my MIBO A10.
Very nice product.
I have 6mm clear Festo tubing but have a problem to get it on the big fittings
Is there a trick I must know or is this tubing not the good one ?
Thank you for your help
Old 02-27-2014, 06:34 AM
  #36
Midas D.
Warm up the tubing, that will do the trick
Old 02-27-2014, 06:41 PM
  #37
Springbok Flyer
Springbok Flyer's Avatar
....with hot water, not an open flame. Boil some water, then put the end of the tube in it for a minute or so, then push it over the barb. Be careful the tubing will be hot, don't burn yourself - use a piece of cloth when you push it one. Afterwards add safety wire and all will be good.
Cheers,
Jan
Old 02-27-2014, 11:32 PM
  #38
Midas D.
Qustion here,
On my next project with 140 size turbine i would install the 260 CAT for some extra fuel reserve.
But doing so will the CAT lose it's function as an bubble tarp? Because of an to big size for the turbine or is it smart thinking using the 260?
Cheers,
Ed
@ Jan, i always use an cigaret lighter to warm up the hose, just go by it with the lighter very rapidly and for only 1 or 2 sec. and it works fine. And indeed use the wire.
Old 02-28-2014, 01:25 AM
  #39
Alsacian
OK thank you I will try this method today......
Old 02-28-2014, 04:53 AM
  #40
marc s
marc s's Avatar
Ed, No it will still perform as a CAT but does give you extra margin on the fuel front - you should not however plan to use the CAT fuel in general but it is an emergency. The CAT sizes are also designed to supply around 30 seconds of fuel supply at full throttle (dependant on turbine naturally) before they reach a point where the air starts to get drawn into fuel supply.
The bores on the CAT fittings are designed to be large to avoid restrictions and resulting cavitation problems, warming the fuel tube at the end and pre-stretching it a little by pushing the end of a pencil in it while warm will evenly enlarge the end enough to go over the barbs. 8mm OD Tygon fits without warming as a note.
marcs
Old 03-01-2014, 03:05 PM
  #41
Chris Pyrah
Chris Pyrah's Avatar
Not sure where I put the Tubes on this Cat
Old 03-02-2014, 05:29 PM
  #42
rcjets_63
rcjets_63's Avatar
Mark,
Here's the CAT that I got from you last summer at the JWM in Switzerland. It's tucked into a BVM Rafale on the left side just forward of the hatch. Great product you've got there; CATs are standard equipment for me now.
Regards,
Jim
Old 03-02-2014, 11:07 PM
  #43
ticketec
Video the result when you install the tubes, it will be golden!
dave
