Reload this Page >
Xtreme Arf Vixen Sport Jet , Coming soon!
Old 03-21-2016, 07:00 PM
  #276
rchobbymodels
rchobbymodels's Avatar
Originally Posted by rchobbymodels
Tomorrow I will have more pics
Here they are
Name:	IMG_20160312_095427 (Copy).jpg
ID:	2153663   Click image for larger version
Name:	IMG_20160312_095527 (Copy).jpg
ID:	2153664   Click image for larger version
Name:	IMG_20160312_100010 (Copy).jpg
ID:	2153665   Click image for larger version
Name:	IMG_20160312_100028 (Copy).jpg
ID:	2153666   Click image for larger version
Name:	IMG_20160312_100057 (Copy).jpg
ID:	2153667   Click image for larger version
Name:	IMG_20160312_100108 (Copy).jpg
ID:	2153668   Click image for larger version
Name:	IMG_20160312_100213 (Copy).jpg
ID:	2153669   Click image for larger version
Name:	IMG_20160312_100410 (Copy).jpg
Name:	IMG_20160312_144458 (Copy).jpg
ID:	2153671   Click image for larger version
Name:	IMG_20160312_144518 (Copy).jpg
ID:	2153672   Click image for larger version
Name:	IMG_20160312_144825 (Copy).jpg
ID:	2153673   Click image for larger version
Name:	IMG_20160312_144904 (Copy).jpg
ID:	2153674   Click image for larger version
Name:	IMG_20160312_144915 (Copy).jpg
ID:	2153675   Click image for larger version
Name:	IMG_20160312_144927 (Copy).jpg
ID:	2153676   Click image for larger version
Name:	IMG_20160312_144937 (Copy).jpg
ID:	2153677   Click image for larger version
Name:	IMG_20160312_145202 (Copy).jpg
Name:	IMG_20160312_145307 (Copy).jpg
Old 03-27-2016, 05:50 AM
  #277
Jetmodeler
Finally got some quality time in the workshop on the Vixen, coming together well, plan for test flight by end of April. The quality of accessories provided has been excellent, used all linkages and servo mounts provided with very good fits, except the elevator servos, with some minor mods I was able to fit JR 8911HV servos inside that thin stab, 8411's would have been the proper fit but I have loaded this bird up with all the big servos. Got the new Rhino SE this week and went in with no issues, but install with the full ductwork is a process, but it all fits well so far. Side note, powered up the new GSU with the Jet Central Rhino, very nice, not that you get more information as much as the screen is very vivid, and much more information is displayed on each page, great for monitoring the turbine performance. Attached a couple of pictures of the turbine going in. Note the additional Sullivan tanks are for the smoke system.
Name:	Tailpipe alignment.jpg
ID:	2154404   Click image for larger version
Name:	Tailpipe attachment.jpg
ID:	2154405   Click image for larger version
Name:	Tail attacment top screws.jpg
ID:	2154406   Click image for larger version
Name:	Turbine lower cover install.jpg
ID:	2154407   Click image for larger version
Name:	Turbine cover installed.jpg
ID:	2154408   Click image for larger version
Name:	Smoke tanks.jpg
Old 03-27-2016, 06:42 AM
  #278
myersflyers
My Feedback: (33)
Jetmodeler,
Thanks for the photos and updates. Keep them coming. Appreciate the servo size references. Hope to getting building mine next month. I realize you're building as time permits, but are you keeping track of your build time?
Keith
Old 03-27-2016, 07:07 AM
  #279
Bob_B
Bob_B's Avatar
Looking good Jim!
Old 03-27-2016, 06:24 PM
  #280
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Originally Posted by myersflyers
Jetmodeler,
Keith
The servos used in the prototype are listed in post #121 of this thread and were based on torque values at 6V.
[h=2]Hi-Tec Servo list[/h]
  • Ailerons: (2) HS-7985MG
  • Elevator: (2) HS-7955TG
  • Flaps: (2) HS-7955TG
  • Air Brake: (1) HS-7955TG
  • Rudder: (1) HS-7955TG
  • Nose Steering: (1) HS-645MG or HS-5645MG
  • Nose Gear Door: (1) HS-645MG or HS-5645MG
  • Mechanical Retract Valve: (1) HS-225 (MG) or Electronic Pneumatic Dual Action Valve
  • Mechanical Brake Valve: (1) HS-225 (MG) or Electronic Pneumatic Single Action Valve
Jr Servo List
  • Ailerons: (2) DS8411
  • Elevator: (2) DS8611A or DS8711
  • Flaps (2) DS8611A or DS8711
  • Air Brake (1) DS8611A or DS8711
  • Rudder: (1) DS8611A or DS8711
  • Nose Steering: (1) 4721
  • Nose Gear Door (1) 4721
  • Mechanical Retract Valve: (1) 351 or Electronic Pneumatic Dual Action Valve
  • Mechanical Brake Valve: (1) 351 or Electronic Pneumatic Single Action Valve
Old 03-30-2016, 03:36 PM
  #281
rchobbymodels
In a few days I will have more pictures for the last batch to show
Old 05-21-2016, 07:57 AM
  #282
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Hey Jim
Its time for you to post some flight video of your Vixen
Billy, Doug, and Mark
Come on guys post some photos of your build
Old 05-21-2016, 03:58 PM
  #283
rchobbymodels
Originally Posted by RCISFUN
Hey Jim
Rich
This is the first video that I've got, should be the maiden and looks like Billy is the cameraman
https://www.youtube.com/watch?v=sOGGoKn-nzQ&feature=youtu.be
Old 05-21-2016, 04:57 PM
  #284
Jetmodeler
Well the Vixen is finally flying, like I said it was a slow build. She flies on rails, very nice airplane, soft stall, good knife edge, and just a sweetheart. I
Some comments on the build, very straight forward like most ARF's. I did change the flap horn, raised it to the top of the flap as the servo travel was minimal with the hole so close to the hinge, these are hidden linkages so just need to use all available height within the thickness of the wing at the flap leading edge.
I like the box just forward of the nose gear well to fit a battery, I have my Rhino ECU battery up there and the balance worked out well, currently have a 4 ounce weight sharing this battery space until I finish the cockpit with pilots and seats which should allow removal of this weight. It was nice to not have to shift anything around to get the center of gravity right.
The fuel tanks are large, I am only using the large saddle tanks, feeding to 20 ounce hopper tank, by the 4th flight I now have the timer set to 9 minutes and landed with about 30% fuel remaining in the saddle tanks, hey Wagoner just how big are those tanks, I'll have to measure them some time.
The Jet Central Rhino, a 200 size motor pushes the Vixen around with authority, plenty of power for this airplane.
Looking forward to taking the Vixen to 1st in Flight next week and putting some more flying time on her, fun airplane.
Jim
Old 05-21-2016, 06:22 PM
  #285
rchobbymodels
Jim
They are 1.06 gallons each so total saddle tanks are 2.12 gallons + hopper
Old 05-23-2016, 05:39 PM
  #286
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Jim I hope you get some good video at first in flight, wish I could go!
Old 06-06-2016, 06:08 AM
  #287
rchobbymodels
New Vixen color scheme:
ID:	2166460   Click image for larger version
ID:	2166461   Click image for larger version
Old 06-06-2016, 10:41 AM
  #288
Jetmodeler
That will stand out in the crowd. Now have 24 flights on my Vixen, liking it more every flight. The new JC Rhino SE is a power house, has enough power to make the Vixen fun, pushes thru slow speed aerobatics nicely, and at speed, whoa, plenty. We got Doug's Vixen test flown now also and he is loving it, smooth, precise, and very capable airplane.
Old 06-06-2016, 11:20 AM
  #289
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Wagner
I like that scheme!
Old 06-06-2016, 03:03 PM
  #290
rchobbymodels
Wagner
I like that scheme!
I am getting old, I forgot to post another one.
I like this one too
ID:	2166517   Click image for larger version
ID:	2166518   Click image for larger version
ID:	2166519   Click image for larger version
ID:	2166520   Click image for larger version
Old 08-01-2016, 05:12 AM
  #291
rchobbymodels
Some pictures of the Vixen at Jets over Kentucky 2016
ID:	2175373   Click image for larger version
ID:	2175374   Click image for larger version
ID:	2175375   Click image for larger version
ID:	2175376   Click image for larger version
ID:	2175377   Click image for larger version
ID:	2175378   Click image for larger version
ID:	2175379   Click image for larger version
ID:	2175381   Click image for larger version
ID:	2175382   Click image for larger version
ID:	2175383   Click image for larger version
Old 08-01-2016, 07:17 AM
  #292
FenderBean
FenderBean's Avatar
I had never seen one up close until KY jets very impressive sport and big, I didn't know it was the size of a shockwave/Ultra bandit. This is perfect for those who like to turn and burn!
Old 08-01-2016, 07:19 AM
  #293
rchobbymodels
Actually she is bigger about 5"
Old 08-01-2016, 07:24 AM
  #294
FenderBean
FenderBean's Avatar
even better
Old 08-01-2016, 07:58 AM
  #295
marc s
marc s's Avatar
Nice line-up guys, great to see a few shoulder to shoulder, she is a great jet (slightly biased!)
marcs
Old 08-01-2016, 01:16 PM
  #296
BILLYDSRC
BILLYDSRC's Avatar
Dddd
Old 08-01-2016, 01:54 PM
  #297
marc s
marc s's Avatar
Glad you like it and sure seems to be a solid ride, fuselage and airframe all seems nice and tight too - big thanks to Wagner and the team at Xtreme for getting this one off the drawing board and putting it together so well (I'm a tad fussy!).
Hope many more enjoy the ride, be good to see more video from any owners out there too - post them here please
marcs
Old 08-01-2016, 06:07 PM
  #298
myersflyers
My Feedback: (33)
Hey Billy,
That truly is SMOKIN!. Are you or Jim going to Route 66 Jets? I will be bringing the Honda Vixen. Been kind of busy since KJ2016, but I will post some pics of the completed build soon including the smoke tanks mods I showed you at KJ.
Rgds,
Keith
Old 08-01-2016, 10:47 PM
  #299
marc s
marc s's Avatar
Keith post them pictures man......
marcs
Old 08-02-2016, 09:53 AM
  #300
myersflyers
My Feedback: (33)
Needed the space where the original smoke tanks went, so I modified the tanks to fit underneath the mains. Cut opening and added G10 with Hysol 9462 than added 1" cloth tape with Hysol E20.
ID:	2175581   Click image for larger version
ID:	2175582   Click image for larger version
ID:	2175583   Click image for larger version
ID:	2175584   Click image for larger version
ID:	2175585   Click image for larger version
ID:	2175586   Click image for larger version
ID:	2175587   Click image for larger version
ID:	2175589   Click image for larger version
