Demon Cortex Gyro question >
Old 10-18-2014 | 10:08 PM
  #201
Springbok Flyer's Avatar
Originally Posted by gregg f
Check to see if the tray it's mounted on is level or if the front is slightly higher. I've had one install that had an issue of elev coupling on roll. Turned out my tray was lower in the front than back to the thrust line. Made a wedge to put the gyro level and problem was solved.
Interesting observation....never thought of that.
Jan
Old 10-19-2014 | 05:39 AM
  #202
gooseF22's Avatar
I saw the same phenomenon in my Elan because I got it a little crooked.. I tried it and had to put a couple clicks of rudder trim in.. good point about the pitch vs tray vs thrust line.. you do want to mount it as orthoganal as possible..
It doesn't matter WHERE its mounted though.. it could be on a wing tip or on the rudder, but it does need to approximate the Axis' of the plane
Old 10-20-2014 | 01:11 PM
  #203
ravill's Avatar
I just purchased one from Todd at dreamworks.
I'll be placing it on my F-4 which I unfortunately hurt this last week.
Question:
The airplane has to be trimmed BEFORE applying the gyro?
Old 10-20-2014 | 02:08 PM
  #204
wfield0455's Avatar
My Feedback: (7)
Question:
It doesn't HAVE to be trimmed before installing the gyro but it's not a bad idea to have test flown the model so that you know what dual rate settings you like, etc, before enabling it. When I installed a Cortex in my X-Treme Jets Hawk 100, I went ahead and used the control surface travels from the instruction manual. When it was test flown, It ended up the Ailerons travels were WAY too sensitive to suit me so I ended up reducing all the dual rate setting, especially the high rates and then repeating the Cortex setup process before
ever enabling it in flight. It worked out fine in the end.
Old 10-20-2014 | 03:44 PM
  #205
ravill's Avatar
Great!
My F-4 has flown plenty, I just dorked it on landing this last weekend, and have to do some repairs, so while I'm in there, why not throw in a gyro?!
Old 10-20-2014 | 04:14 PM
  #206
mr_matt's Avatar
My Feedback: (10)
Hi
Sorry if these are answered, I tried to research the thread.
1.) Are all of the servo power leads going through the little box? Does the power bus in the gyro have a current rating?
2.) If a plane has a conditional mix, like flap to elevator, how does that work? Say you had down elevator mixed to flap extension. I thought the gyro would see the down elevator input as a rate command and the plane would keep slowly drifting downward in pitch?
Thanks very much...
BTW, I just came from Best in the West......I think there were a LOT of these flying......
Old 10-20-2014 | 11:30 PM
  #207
Hello,
What configuration using a Cortex with Jeti ds-16 with a powerbox srs in udi Mode?
Old 10-21-2014 | 07:29 AM
  #208
Originally Posted by mr_matt
Hi
Thanks very much...
1) Power is usually supplied through inputs A and B only and these inputs supply power to all the servos. The information that I have been given is that the cable loom is the first restriction on current capability and I have been given figures of 10A continuous and 12A transient.
2) The response of the gyro (at least in normal mode) is simply to correct a disturbance; it doesn't try to hold a 'rate'. Presumably in your conditional mix example the mix is there to prevent a pitch change; therefore the gyro will do very little (if anything) other than to continue to smooth out the flightpath. Also, I would guess that in most cases the amount of elevator mix in your example would be small enough to be irrelevant (in the same way that the effects of trimming the model can largely be ignored).
Old 10-21-2014 | 08:07 AM
  #209
mr_matt's Avatar
My Feedback: (10)
Sorry I should have been clearer, I was talking about the gyro being in rate mode when this occurs. And as for ignoring trim, I thought it was important to set these things up with no trim in the TX, else the gyro interprets the trim as a rate command? That was the whole gist of my question, wouldnt the elevator mix look just like a rate command to the gyro (when the gyro is in rate mode)?
EDIT: I mean it might not be important. I use a similar gyro and I don't know the answer on that one either hence the question. And on the one I use I cant run 10 amps over that little set of copper traces, so that it is an advantage.
THanks
Old 10-21-2014 | 08:29 AM
  #210
The way that I understand it is that there is no rate 'command'.
By moving your control stick you don't ask the gyro to give you a rate of movement, the signal is (simplistically) passed straight through the gyro to move the control surface. The gyro simply responds to any disturbance of the model and 'alters' this signal to provide a correction to smooth down the flightpath (in normal/rate mode).
Old 10-21-2014 | 11:05 AM
  #211
mr_matt's Avatar
My Feedback: (10)
OK cheers, I thought it had a rate mode. Thanks for the clarification.
Old 10-21-2014 | 11:18 AM
  #212
Normal mode on the Cortex is what other manufacturers call rate mode and yes, it does have it. Normal/rate mode is the 'basic' mode that dampens out disturbances.
Old 10-21-2014 | 11:33 AM
  #213
wfield0455's Avatar
My Feedback: (7)
It certainly seems, based on flying, that it does much more than simply dampen out disturbances. Certainly much more so than heli rate mode gyros of old. For example, I have a plane that was almost impossible to maintain a constant roll rate in a cross wind. Things like rolling harriers were always extremely difficult to perform with this airplane as it always would want to stop rolling depending on what the wind was doing and it would require almost full aileron to get it going again. The same plane, with the Cortex set to normal mode doesn't have this issue at all. Simply give it enough aileron to start it rolling at the desired rate, hold that input and the Cortex appears to take care of the rest. It seems to very effectively maintain a constant rate of change, for each axis based on stick input.
Old 10-21-2014 | 12:47 PM
  #214
mr_matt's Avatar
My Feedback: (10)
OK I am confused, if that is what it does, that is what I was referring to as a "rate" mode. Meaning a deflection angle of the stick does not directly correlate to a deflection angle of a surface, but rather the deflection angle of the stick corresponds to a desired rotation rate around that axis (and the gyro takes care of any wind effect, turning, coupling etc)
So that is what my original question was. If you have a elevator compensation mix in for flaps, the gyro can't distinguish that from a down elevator rate command. Maybe you don't need these kind of compensation mixes in the first place with the rate mode.
Old 10-21-2014 | 01:47 PM
  #215
Bob_B's Avatar
Matt I suggest you contact Joachim at Bavarian Demon for an explanation of the Cortex programming or send F1 Rocket a PM here on RCU.
Old 10-21-2014 | 02:19 PM
  #216
wfield0455's Avatar
My Feedback: (7)
This has confused me as well. While I've noticed that it seems to do a good job of maintaining a constant rate of rotation on the roll axis, I haven't noticed any problems with knife edge mixes, etc. I had rudder -> elevator, knife edge mix (about 5%) setup on the plane before I installed the Cortex, it's still enabled in the transmitter and the plane flies straight in knife edge whether the Cortex is enabled or not. I do however, still need to hold in rudder to maintain knife edge but I believe a bit less than without out it being enabled.
I also have limited experience with the Cortex in a Jet that has elevator compensation when the flaps get deployed and that doesn't seem to bother the Cortex either. Once we got the elevator trimmed for the desired glide slope, it didn't seem to change whether the Cortex was enabled or not. Whatever it's doing, it doesn't SEEM to be too worried about mixes, yet does a great of stabilizing the plane.
Old 10-26-2014 | 06:03 PM
  #217
Max2011's Avatar
Seems to me you could program different gains....different than the "normal"(amber light) onto the HH(red light) if you do not intend on using HH. Still you would need to use the computer to make indiviual changes but you could use the 3-position switch to see the difference in the normal setting and your new gain settings.
Old 10-27-2014 | 06:02 AM
  #218
Bob_B's Avatar
Absolutely! Bank one is Amber and default is rate mode, Bank two is Green and default is heading Hold, Red is OFF.
Depending on your radio you could have as many different gain as you like, you can setup rate and hold settings in each bank for one or all of the Axis' by using the PC software. Jeti radio users are using a pitot sensor to change the gains setting in flight automatically. This unit has great flexibilty!
Old 11-19-2014 | 01:42 PM
  #219
My Feedback: (14)
Originally Posted by mort78
Hi Airforce7,
To setup the gyro, make sure your TX is completely ready to fly the model with the correct travel etc. Turn Dual rates off.....
Then to teach the gyro, you need to do the following....
1. Turn everything off
2. Place jumper into gyro
3. Then turn on your transmitter with neutral sticks and dual rates OFF.
4. Turn on your model.
5. This is where you need to be quick.... the LED will cycle through the various controls. For you, the gyro light sequence will be....
2 x RED blinks (Do nothing)
2 x GREEN blinks (Right Aileron)
1 x GREEN blink (Left Aileron)
2 x GREEN blinks (Aileron Neutral, Elevator Push - Down)
1 x GREEN blink (Aileron Neutral, Elevator Pull - Up)
2 x GREEN blinks (Aileron + Elevator Neutral, Rudder Right)
1 x GREEN blink (Aileron + Elevator Neutral, Rudder Left)
When the system blinks fast continously, Pull the jumper out and power the model down. The above step happens fast, so you need to be aware of which input to give beforehand, otherwise you'll put in a wrong input or miss it altogether, as the gyro doesn't wait for you.
I remember having to do this a couple times before I got it done right. Remember, the gyro 'learns' your end points AND stick position during the above sequence - ie: During the time the jumper is in the gyro.
Regards,
Mort
Mort,
Thank you , thank you, thank you!!! Thanks for putting the teaching/learning process in a way that I could easily grasp it. Wow, it's dang easy, once I read the way you said do it!!
Now to go fly this thing on a windy day to experiment, and learn more, before I put the Cortex in my 60cc Corsair.
Thanks for the help!
Chris https://www.youtube.com/watch?v=GPYVcyl0HRE
Old 11-30-2014 | 04:31 PM
  #220
Max2011's Avatar
O.K. here is one for you guys.
I set my Cortex to use the Bank one amber light as the default...the red light is off of course. On the Bank two...green light.... I programmed it to only use rudder control only. When I go to Bank one(amber) everything is great ....Off at red works....BUT when I switch to Bank two(green) the rudder will creep over to the right side and stay there until I turn off the Bank two by going to red or amber. I wanted to fly some maneuvers in the heading hold using rudder only but the rudder does this little trick.....any idea?
Old 11-30-2014 | 05:13 PM
  #221
Bob_B's Avatar
Check your rudder trim, if you moved your rudder trim from zero you will see the surface move off center like you are describing
Old 11-30-2014 | 05:20 PM
  #222
My Feedback: (21)
I have several heading hold gyros, non cortex ,If you activate them on the ground they all will slowly move the rudder to the stop.
it's normal for gyros in heading hold to do as you say when on the ground .
hope this helps
Old 11-30-2014 | 07:25 PM
  #223
757Driver's Avatar
My Feedback: (90)
Normal if that bank is heading hold.
Old 11-30-2014 | 09:31 PM
  #224
Hi guys,
Is anyone using a Cortex between a Powerbox unit and their servo's?
Jan
Old 12-01-2014 | 06:21 AM
  #225
Max2011's Avatar
Normal for the rudder to "lay-over" on HH?.....well O.K. I will watch it very closely in the air when I switch it on....Thanks guys.....I really enjoy the Cortex.....very easy to setup and it works. Could be as Bob says about rudder trim...I think I did move the trim...I will check.
