Reload this Page >
SM 1/7 Scale F-14 Build
Old 01-25-2019, 06:45 PM
  #151
FenderBean
FenderBean's Avatar
Hey Maury sorry for the delay had to have emergency surgery today, but as far as I know there shouldn’t be an old/new version that changes this. There has to be wood there for the carbon tubes hold the rudders. Can you take a picture of yours or is the top picture yours?
Old 01-25-2019, 06:50 PM
  #152
FenderBean
FenderBean's Avatar
Oops okay so it’s yours on top, the wood on mine in that area i think is balsa with glass over it. This spreads the load to between each side of the rudders. Kinda like external pylons, it’s much stronger to have block that goes from bottom to top instead of what I see sometwith a play plate just on the bottom skin. If that’s makes sense, when I get mobile again I will get you some more pictures of the area to help verify I’m not saying something wrong.
Old 01-25-2019, 09:34 PM
  #153
mauryr
Yours also seems to have a carbon skin reinforcement on both sides in that area, sort of a third spar in the middle made with the wood and the carbon skin
Old 09-19-2019, 05:04 AM
  #154
drorso
Default My next project - SM F-14
After watching it closely in JOK about 2 months ago, and asking FenderBean and David lots of questions, the kit has been ordered in Jet Power. It should be delivered within 3-4 months, i'll open a new thread.
Planned setup includes 2 x JetMunts Merlin 166, Powerbox Royal, 2 x Futaba R7008SB, Futaba 18SZ. the order included full wing, painted as VF-103 Jolly Rogers.
Thanks again FenderBean and David :-)
With Anton after closing the deal
Old 09-19-2019, 07:36 AM
  #155
FenderBean
FenderBean's Avatar
Congrats, I didn’t get to fly mine very much. First flight was a retrim after moving stuff inside and the tire wouldn’t hold pressure after that. I recommend ordering some extra tires, they’re very soft tires and don’t last long.
Old 09-23-2019, 06:31 AM
  #156
WimB
WimB's Avatar
Congrats on your order!! I have the same version!
Old 09-24-2019, 12:21 AM
  #157
drorso
Thanks. Can you post some internal pictures of your setup, or send in private? [email protected]
Old 10-28-2019, 12:14 AM
  #158
drorso
Default Opening Canopy
Asking for advise: i asked SM to make the canopy with the hinges, but without the air system (cylinders for opening and locking). My original thought was that less one air system is better, and i can install a servo instead.
Any suggestions? should i stick with the original design?
Old 10-28-2019, 07:25 AM
  #159
FenderBean
FenderBean's Avatar
Yes, it would be an easy modification. You could even using the linear actuators from actuonix. I used them on my F-18 and work nice.
Old 11-01-2019, 11:59 AM
  #160
bruno borges
Hello,
I need help!!
I'm riding my F-14, and I need to know the best position for me to do his CG.
Tks
Bruno
Old 11-01-2019, 12:05 PM
  #161
bruno borges
This my F-14 Tomcatters
Here are some pictures of the montage.
Old 11-01-2019, 12:53 PM
  #162
FenderBean
FenderBean's Avatar
Best CG is front side of the forward wing cross beam, I loosened one of the screws holding the wing clamp to the carbon fiber cross beam and hung the jet from a thin wire. seems to be a perfect CG
Old 11-14-2019, 07:52 AM
  #163
bruno borges
Default Hook
hi guys would anyone have any pictures of the F-14's hook system. in my kit did not come and I want to see if I can make one.
Old 11-14-2019, 08:04 AM
  #164
FenderBean
FenderBean's Avatar
plenty of pictures of the hook in this thread
Old 11-14-2019, 08:21 AM
  #165
bruno borges
Talking
130/5000
I thought. I need his dimensions. To see if I can make an equal.
If you can put his dimensions, I appreciate it.
Bruno
Old 11-14-2019, 09:13 AM
  #166
FenderBean
FenderBean's Avatar
Sorry not able atm to do this but I’m sure someone can help, you could even send a message to John at Skymaster and he could probably get that information
Old 07-16-2020, 10:57 PM
  #167
drorso
Hi Guys,
With all the Coronavirus impacts and other delays due to bundle order, i finally got my F-14. 9 months.... :-) thanks to John and Anton for the great kit.
However, when i started to open the packages, i couldn't find the canopy locking mechanism. I ordered the kit without the installation of the air cylinder, in order to reduce complexity.
Can someone take close pictures of the locking mechanism?
Thanks!
my wife is happy with me :-)
blackcat (07-20-2020)
Old 07-17-2020, 08:44 AM
  #168
FenderBean
FenderBean's Avatar
If you look through the build you will see a few good pictures, the lock is a flat piece of G10 material with slit cut in it that when the canopy closes it pushes past the hook locking it. Its connected to a regular air cylinder.
post #97 and 113 have some good picks of it, im sure there are more just a few I found.
Cheers
Old 07-17-2020, 08:49 AM
  #169
drorso
Thank you, found it. I'll start the build in a month or so, will look at the thread from start.
Old 07-17-2020, 09:45 AM
  #170
FenderBean
FenderBean's Avatar
good luck its a big project
