Reload this Page >
JR 28x information
JR 28x information
Old 03-19-2015, 03:22 PM
  #126
Dave Wilshere
Originally Posted by Ace913
Have fun Dave! It's an awesome Radio! We may have to evolve through a few software updates before all the functions are complete and solid but that's to be expected with such a complex product. I'm very impressed with the build quality.
Jeff
Its a vertical learning 'curve'! I'm trying to get my head around it before my customers start with the questions :-)
Dave
Old 03-19-2015, 06:29 PM
  #127
Ace913
My Feedback: (104)
Actually, you should be able to do so. On the switch screen, all switches activate correctly, it's just that it doesn't pull up anything but the first set of rates. I've done this for years with my 14MZ and most recently with my 18MZ. You can also do it with the DX18 and to some degree the 12X. Programming radios and knowing the different high end radios (JR, Futaba, Spectrum and Jeti) is another element of the hobby I enjoy. I've been an Electrical engineer specializing in embedded software design and development for over 25 years which also helps quite a bit in figuring these systems out. It's not uncommon for new radios to have not only bugs but "unfinished" features.
Having said that, I like where JR is going with the interface in this radio. It's very simple and the Dual Rate thing is the only issue I've found so far. I turned this in to the folks at JR America to see if they can figure it out or talk to the engineers in Japan about it.
Regarding your post, in the DR screen (as in many of the functions) the Flight mode essentially no different than programming a second switch on a function. In essence the "Flight Mode" is simply a logical "AND" with whatever switch you assign the function. So, if you look at the logic table I posted the other night, you can see that the combination of the two switches gets you all 9 positions active and displayed appropriately, they just don't link to anything beyond the first 3 DRs.
Doug, I'm sending the model to you. If anybody else wants to play with this and see if they can figure it out, I can post a test model that has the rate switches setup as described. I also provided this model to JR America.
I never rule out the possibility I'm "full of it" and in this particular instance, I'd like to be.. . But, this is JR and if it's not correct at this moment, you can bet it'll be right very soon.
Old 03-20-2015, 08:50 AM
  #128
Edbaker
My Feedback: (44)
New thread started- 28x software update wish list
http://www.rcuniverse.com/forum/rc-r...wish-list.html
Old 03-20-2015, 10:57 AM
  #129
Paul0088
Just finished my set up of the Xcalibur , ready for the JMA AGM
Old 03-20-2015, 06:17 PM
  #130
warbird_1
My Feedback: (61)
warbird_1's Avatar
anyone have a detailed info on the gear system? i have a u.p.3 valve for my corsair . i've never been a big fan of them as they get twitchy as the pressure gets low. i would rather run two robart air valves , one for the gear and the other for the gear doors "which i have setup to run on air". i didn't see a delay system which would allow the doors time to open before lowering the gear. and vice versa . WB_1
Old 03-22-2015, 07:44 AM
  #131
COL J
Has anyne figured out how to activate voice prompts for the timers. The little beeps are useles on the flight line. And one shouldn't have to be looking at thr screen for this.
Old 03-22-2015, 09:35 AM
  #132
Ace913
My Feedback: (104)
Somebody correct me if I'm wrong but at this time, voice alerts are only available for Flight Modes and Telemetry Data. Given the flexibility of the function for telemetry voice prompts, I would say that they have the flexibility under the hood to add additional voice prompt availability and flexibility in future software releases - only speculation. I would bet that they released this initial version of software with core functionality and that they will evolve and enhance it significantly. There is another thread started out there for a software wishlist.
Here's the link: http://www.rcuniverse.com/forum/show...8&goto=newpost
Old 03-22-2015, 09:48 AM
  #133
muzzgail
muzzgail's Avatar
I think your right Ace913. With an interface to the internet built into the radio and a customisable android system built in, I think updates will be available, just like they are for your apple phone etc. You will probably go to the JRPROPO site (default home page) and the radio will tell you there is an update available.... It's very possible. The android phones do this now, but didn't always. Time may see this happen I believe.
Upon connecting the radio to your WIFI Hub in your home, you might see something like "New Version OS available Version 1.1 UPDATE OK / CANCEL
Old 03-22-2015, 11:05 AM
  #134
COL J
Thanks guys. I suspect they wanted all of the important functions set and tested on the first batch. Firmware updates I'm wil come as more people dive in and I also JRPROPO is working on as we speak. Nature of the beast.
Old 03-22-2015, 03:06 PM
  #135
Ace913
My Feedback: (104)
Sorry, bad link for the software wishlist. The link is posted above by EdBaker.
Okay, I've got my first flights using the 28x today. Aside from not being able to setup the DRs the way I want to, the radio performed flawlessly. I had 3 program mixes as well as 3 rate settings and throttle cut. The radio is super responsive and smooth. You can actually feel the high resolution. Very pleased!
Jeff
Old 03-23-2015, 01:34 PM
  #136
COL J
Jeff,
When you click on the 'browser' button and your wifi is on it goes directly to the JRPROPO site. If you click on the 'download' button it responds with now downloads availabe. This will make updating firmware, etc. a snap. John
Old 03-23-2015, 03:56 PM
  #137
warbird_1
My Feedback: (61)
warbird_1's Avatar
getting back to the voice stuff..... you mean only voice there is is FM and tel stuff ? Al helped me get the battery voice working. what about gear up and down . i'm bummed. this thing should wash my car for 2,700.00 bucks lol
Old 03-23-2015, 05:58 PM
  #138
Doug Cronkhite
My Feedback: (34)
I pushed the RF link to the limit this weekend flying F3B. In one duration flight, I had my 118" sailplane so high I couldn't see it anymore. Full flaps, and nose down for 20 seconds brought it down to 1500 feet. The 28X and 712BX receiver never missed a beat. Super happy with this radio.
Old 03-23-2015, 06:45 PM
  #139
drac1
drac1's Avatar
I just received an email saying mine has arrived and I will collect it tomorrow.
It sure sounds like a great radio and looking forward to playing with it.
Old 03-23-2015, 08:32 PM
  #140
jetpilot
My Feedback: (48)
jetpilot's Avatar
Will some of you guys post a video tutorial of how to setup dual rates? im stuck!
Also the gyro menu has me confused.
Scott
Old 03-23-2015, 09:03 PM
  #141
drac1
drac1's Avatar
How does the Tx balance just hanging off a neck strap?
Old 03-24-2015, 01:56 AM
  #142
Paul0088
Old 03-24-2015, 02:24 AM
  #143
Paul0088
Scott
http://youtu.be/sPapj19l_Yo
Old 03-24-2015, 03:28 AM
  #144
Dave Wilshere
Originally Posted by Paul0088
Nice bit of Spitfire wing ;-)
Old 03-24-2015, 03:36 AM
  #145
Paul0088
Yea
Old 03-24-2015, 04:43 AM
  #146
drac1
drac1's Avatar
Thanks. Looks about right.
Old 03-24-2015, 08:40 AM
  #147
jetpilot
My Feedback: (48)
jetpilot's Avatar
Paul0088!! Thank you very much!!! Your awesome!!
Scott
Old 03-24-2015, 10:43 AM
  #148
Paul0088
Scott
No problem, can't help with gyro yet not looked at that so far.
Old 03-24-2015, 02:14 PM
  #149
drac1
drac1's Avatar
My 28X costs $2800 AUD, which with the current exchange rate, converts to around $2200 USD.
Old 03-24-2015, 02:41 PM
  #150
jcterrettaz
jcterrettaz's Avatar
What store ?
this is a very good price
