Reload this Page >
The new Fei Bao Jets “Dolphin S” build thread by RCISFUN
Old 06-19-2016, 03:46 AM
  #151
dmattmul
One question and a commit. Can anyone tell me the main wing tube OD for the Dolphin and Dolphin S? I am in Asia now and want to order extra tubes to help me hold the airframe down in transport. The tube that comes with it I keep in a wing and makes it easier to assemble so I need a extra tube for transport.
Also is anyone using an aluminum sleeve to hold the servo extensions away from the thrust tubes? I found this was needed but do not hear anyone talking about this on the site.
Old 06-19-2016, 04:10 AM
  #152
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Hello dmattmul
Dolphin L is 37" long x 1.25" dia. x 0.040" wall thickness CF Tube.
Dolphin L is 940 mm long x 31.75 mm dia. x 1.01 mm wall thickness CF Tube.
Dolphin S is 33.875" long x 1.095" Dia x 0.040 wall thickness, the CF tube has plugs inserted into both ends to make a area for the screws to thread into, which are located approx 0.6" in from the end.
Dolphin S is 860 mm long x 27.8 mm Dia x 1.01 mm wall thickness
I used electrical-insulating fiberglass sleeving, for example look at the following:
http://www.cabletiesandmore.com/Brai...emperature.php
Old 06-19-2016, 05:21 AM
  #153
dmattmul
Thanks, and agreed something is needed to insure the wiring stays within a temperature boundary. I initially used a high temp sleeve and even that showed signs of heat degradation. (Not rated as well as the web site you referenced) The product I found was similar just made of corrugated aluminum. Still very light weight. Was for automobile application.
Old 06-19-2016, 04:58 PM
  #154
Lerch32
I'm using aluminum tape.
Old 06-19-2016, 07:09 PM
  #155
Custmachr
Originally Posted by RCISFUN
Hello dmattmul
Just for reference the tube in my Dolphin S measures slightly larger at 1.100" and 27.93 mm.
Tim
Old 06-20-2016, 02:37 AM
  #156
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Tim
Mine is probally on the low side of the tolerance, most likely nominal is 1.102" (28 mm)
Old 06-26-2016, 02:42 AM
  #157
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Last Fall I had a slight mishap with my Dolphin S where I scraped up the nose pretty good, enough where I had to do some fiberglass surgery.
The actual repair was the easy part, coming up with a way to to paint it is always difficult, trying to match the yellow and blend it was going to be difficult, so in the end I decided to just paint it red, I borrowed the design from the Big Dolphin.
When I was at the Toledo show this past April I stopped by the Klasskoat epoxy paint booth and I decided to give it a try so I would not have to deal with a clear coat.
This paint works great and it is easy to apply.
Here is the link if you want to check it out.
http://www.klasskote.com/
ID:	2169700   Click image for larger version
ID:	2169701   Click image for larger version
Old 06-26-2016, 05:20 AM
  #158
Lerch32
Mind if I ask what caused the mishap? I'm getting ready to maiden mine in the next week or 2.
Old 06-27-2016, 11:04 AM
  #159
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
The plane fly's great!
Dumb Thumbs on landing!
Totally my fault
Old 06-27-2016, 01:28 PM
  #160
Lerch32
Thanks for replying!
Old 06-27-2016, 01:36 PM
  #161
Lerch32
I'm 98% there! 😊😊😊
ID:	2169957   Click image for larger version
ID:	2169958   Click image for larger version
ID:	2169959   Click image for larger version
Old 06-27-2016, 04:44 PM
  #162
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Looking good
Did you engrave your tray?
Old 06-27-2016, 06:57 PM
  #163
Lerch32
I did.
Old 06-27-2016, 09:23 PM
  #164
Lerch32
Hopefully maiden this weekend.
ID:	2170047   Click image for larger version
ID:	2170048   Click image for larger version
ID:	2170049   Click image for larger version
Old 06-28-2016, 04:55 AM
  #165
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Is FB now providing the "CF look" for all of the internal trays etc.?
It looks like you have the same paint scheme as mine...
Old 06-28-2016, 05:09 AM
  #166
Lerch32
I made all the parts.
Old 06-28-2016, 05:13 AM
  #167
Lerch32
It is the same scheme. I can't help it, I love yellow. Lol
Old 06-28-2016, 05:15 AM
  #168
Lerch32
The parts included from FB in my opinion were useless. I used your templates. Great job by the way, thanks for creating them!
Old 08-09-2016, 03:05 PM
  #169
sewergod
My Feedback: (15)
Has anyone installed bearings in the wheel hub? How about updates to the anti-rotation plate for the electric brake disk? I found that the screws are not quite long enough (only two or three threads) and that there is a space between the back to the anti-rotation plate and the wheel hub, which can cause the brake to drag if one of these three screws come loose. Maiden was completed this past weekend. It flew great!! I noticed these during the post flight gear inspection.
Name:	Dolphin S wheel.jpg
Old 08-09-2016, 05:13 PM
  #170
Custmachr
I found the same thing. I replaced the three screws in each wheel with slightly longer screws. One of mine was also loose causing the plate to be slightly warped which was caused the brake on that side to drag. I have not maiden it yet. Hopefully in a couple of weeks. Glad to hear your's flew great. Did you use use the surface throws listed in the manual?
Tim
Old 08-09-2016, 06:43 PM
  #171
sewergod
My Feedback: (15)
Yea, I used the throws that were outlined in Rich Miller's manual. I've sent FBJ a few questions about the brakes. I'll repost once I have a definitive answer.
Old 08-10-2016, 10:55 AM
  #172
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I lost a main wheel from my large Dolphin, I ordered a new one from Catherine and I was pleasantly surprised to find that they were now equipped with ball bearings.
I'm not sure if this has happened yet with the Dolphin S wheels, I hope so....
Old 08-10-2016, 10:57 AM
  #173
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Were you satisfied with my recommended throws and C.G.?
Old 08-10-2016, 11:29 AM
  #174
sewergod
My Feedback: (15)
Yes, these recommended throws were plenty. I'm thinking about putting some crow in it to help slow it down a little more, as I have a KT-160 installed. Any recommendations?
Old 08-10-2016, 02:54 PM
  #175
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I am running around 3 mm of crow,
Did you perform the flap linkage modification?
This allows much more flap deployment.
