Reload this Page >
Xicoy Electronic C.G. Balancer
Old 04-05-2015, 03:33 AM
  #51
Justin_vb
Silly question, the instructions says to measure the distances from the sensors. Is this still correct for offset struts like below and Damo's F-18 as shown above?
Old 04-05-2015, 03:39 AM
  #52
philjac94
philjac94's Avatar
See FB message
Old 04-05-2015, 03:40 AM
  #53
Mark Vandervelden
Mark Vandervelden's Avatar
Hi Justin
It dose not matter how the struts are configured the relevant measurements are from were the load is supported buy the three sensors in relation to the expected CG.
Old 04-05-2015, 03:41 AM
  #54
philjac94
philjac94's Avatar
Originally Posted by Mark Vandervelden
Hi Justin
+1
Old 04-05-2015, 09:10 AM
  #55
FenderBean
FenderBean's Avatar
I think this a great item for jets, since cg always seems to be a guessing game. Is it possible or will they be any defaults for people that can be selected in the unit? For example on something like the ARF kits all SM 1/6 f16 will have the same measurements and all the SM Bae hawks will have the same measurements. So just make a data base with these and make it were you just select the model and the scale and bam your done! Then over time as new models come out or different scales of a model you just release a new software update or even make it were u can manually enter and store it!
Old 04-05-2015, 01:49 PM
  #56
olnico
olnico's Avatar
No, because some models have trailing link struts.
In that case the position of the wheel projected on the fuselage longitudinal axis will change with the weight of the aircraft.
One could say that 1 mm does not really matter, but this is not true in that case since the CG position is given to the mm...
  #57
olnico
olnico's Avatar
Hi Justin
Yes. Positions must be projected on the fuselage longitudinal axis.
Old 04-05-2015, 02:11 PM
  #58
FenderBean
FenderBean's Avatar
So your saying that all SM f-16 models of the same scale would be different? I would think peoples measurements and eyeing up the ruler would have more error?
Old 04-05-2015, 02:29 PM
  #59
Damo260
Damo260's Avatar
You really can't stuff it up using a tape measure and plumb bom to get the cg accurately
Damo
Old 04-16-2015, 07:50 AM
  #60
Gaspar
Gaspar's Avatar
We have just begun to ship the pending orders, older first.
Just a small comment for the customers that have this device on order, there is a new option for this device. It consist in 3 pc of electronic angle sensors (resolution 0,1º) to replace the weight sensors. The use of these angle sensors is to accurately measure and setup the throws of control surfaces. Manual can be downloaded here: http://www.xicoy.com/CGMeter1_00.pdf
For those costumers that have ordered the CGMeter and would like to include these sensors, please contact us to or your dealer to modify your order before shipment.
Gaspar
Old 04-16-2015, 10:42 AM
  #61
olnico
olnico's Avatar
http://www.ultimate-jets.net/product...-angle-sensors
Old 04-18-2015, 09:53 AM
  #62
r 3
r 3's Avatar
Hi Gaspar
Will you be coming to Jet Power in Germany in September and will you have these units with you for purchase.
Bill
Old 04-20-2015, 03:58 AM
  #63
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Originally Posted by HarryC
The simplest way is add up weight of all 3 wheels. Divide weight on nosewheel by total of all 3 wheels. That fraction is the fraction forward from main wheels of the distance mains to nose. For example, weight on nosewheel is 1kg, total weight on all 3 wheels is 10kg, distance main to nosewheel is 1metre, then balance point is 1/10 of distance i.e. 10cm forward from main wheels. Couldn't be simpler.
So what would the formula / process be if you don't assume that both main wheels are the same distance from the nose?
I guess I could derive it from the forces equilibrium, but if there is a shortcut even better.
Old 04-26-2015, 07:39 AM
  #64
osvaldopv
My Feedback: (12)
osvaldopv's Avatar
Can someone explain how do I get the distance between the mains and the CG, this is the step (2) from the instructions. I have an Avanti S and the recomended CG is 250mm. From were to were do I have to take the measure to put in the CG meter?
Osvaldo
Old 04-26-2015, 08:33 AM
  #65
spike5150
Osvaldo
CG is usually referenced from leading edge wing root or some other reference point (not sure about your specific plane). So mark CG from that spot, then measure the distance from the mains to that CG mark and input that to CG meter. And if its not obvious, you need to measure distance from a spot that is perpendicular to an imaginary line between the two mains to the CG location (and the nose wheel, for that matter).
Old 04-26-2015, 02:08 PM
  #66
philjac94
philjac94's Avatar
Easiest way is to use a plumb-bob or weighted pointer on a string and mark leading edge location on the floor and measure from there.
Old 04-26-2015, 04:37 PM
  #67
vquick
My Feedback: (71)
vquick's Avatar
I build this yesterday i will be using a plumb to align the plane cg to the wood and have the measure on the side to the center of the sensor I have a mark in the wood for my 0 point cg
ID:	2092385   Click image for larger version
Old 04-26-2015, 07:27 PM
  #68
spike5150
Very nice vquick. I like it.
Old 04-27-2015, 08:43 AM
  #69
EDFJim
Originally Posted by tp777fo
Got mine. Going to take it to the jet events and have a sign. Will balance for beer.
OK for a beer is a great price to play with this 😀
Old 04-27-2015, 11:46 AM
  #70
FenderBean
FenderBean's Avatar
Originally Posted by EDFJim
OK for a beer is a great price to play with this 
I will have mine at KY jets and if anyone would like to give it a whirl fill free to hit me up, no fee required but like I will never turn down a good old blue moon or shock top!
Got this thing for my F-14 and future builds, the F-14 is hard to do as are any of these larger jets.
Old 04-29-2015, 04:44 AM
  #71
drifter
My Feedback: (53)
drifter's Avatar
Originally Posted by flyinfool1
Is there an upgrade coming that will also check for lateral balance?
Wouldn't the difference in weight on the main wheels indicate if there were a lateral balance problem?
Old 04-29-2015, 07:37 AM
  #72
spike5150
Such a nice unit I thought it needed its own special case. Pelican model 1170.
Old 04-29-2015, 12:22 PM
  #73
Zeeb
My Feedback: (41)
Zeeb's Avatar
That's just the ticket for the balancer stuff. Thanks for the pic and including the case model number as there are not any Pelican dealers around here who seemed to have it, a few pistol cases but they were a lot more money than the 1170 I ordered online....
Old 04-29-2015, 07:15 PM
  #74
mort78
Yeah, thanks Spike. That's such an awesome case for it..... I had to order one for myself
Old 04-30-2015, 03:29 PM
  #75
FenderBean
FenderBean's Avatar
I was super surprised to get my unit today, when I ordered it three days ago it was listed as back ordered!!!! Can't wait to use it on my f-14!
