Reload this Page >
DerJet F-35A
DerJet F-35A
Old 03-15-2016, 02:24 PM
  #101
sailing1
My Feedback: (134)
Sorry to hear about Humpty. For the benefit of those of us who are on the fence about this model is there a story to the Humpty imitation?
Old 03-23-2016, 04:54 PM
  #102
Len
Len's Avatar
Yup landed too slow in a gusting headwind that dropped off at exactly the worst time. Rebuilding...but departing for Canada in a week as the IRS only allows me 182 days per year in the USA. My testing will resume in the fall again with a new left gear former and some other mods as well as a new set of nose gear rails. I believe Dave will have better results with his over the summer months and I can use his data as he's got mine from the 4 winter flights. I never got into the flaperons and stabs being deployed for landing test phase and that may have dealt me the bad hand on this one. It would land fast but very sweetly without bad habits...too slow and well we all know what happens when we do that. The "fast" landing would slow to a stop with regular braking in about 300 feet. There is a bright future for this aircraft, but my having only one day a week on the asphalt runway to test fly a newly designed bird was not the best judgement on my part... I should have shipped one to Canada too...just might after I get my taxes done!
Aloha,
Len
Old 07-13-2016, 02:14 AM
  #103
joel.vlashof
Default F-35B Joel Vlashof
Hi guys, i am working to on the F35 model. I like the B version a bit more than the A version so i try to build The B version with the scale F135 propulsion system. Ror now i am working on the model but i found i hard to build the scale retract system, the dragbrace is difficult. here are some pictures. My B model is scale 1:8.5.
https://www.youtube.com/watch?v=EC2PJ8mYorw
Does anyone has any ideas. i think 3d printed parts are to weak.
Kind regards,
Joel
F35model.nl
ID:	2172789   Click image for larger version
ID:	2172790   Click image for larger version
ID:	2172791   Click image for larger version
ID:	2172792   Click image for larger version
ID:	2172793   Click image for larger version
ID:	2172794   Click image for larger version
Old 07-13-2016, 08:59 AM
  #104
ticketec
Any more reports of how the F-35 flies?
thanks
dave
Old 07-13-2016, 09:47 AM
  #105
joel.vlashof
https://youtu.be/EC2PJ8mYorw
hi dave, here is a link
Old 07-13-2016, 11:24 AM
  #106
sailing1
My Feedback: (134)
Very impressive!
Old 07-18-2016, 08:16 AM
  #107
General Jake
General Jake's Avatar
Is the DER F-35 available in the US?
Old 07-18-2016, 12:26 PM
  #108
tp777fo
My Feedback: (28)
tp777fo's Avatar
Eric Clapp is a dealer
Old 03-09-2017, 10:43 PM
  #109
Len
Len's Avatar
Hi Guys,
Its been almost a year (7 months of it I spent in Canada) and with Obama here for December and some seriously unusual and poor weather this winter not to mention MCBH operations, I had not the chance to get flight #5 in until Feb 26th. It was a great flight, with BOTH main gear retracting! However; now the nose gear would not do so and it turns out that was an oversight on my part as it had a bent piston rod cross pin inside the trunnion from that bad landing on flight #4, and that added to the air flow force was enough to prevent the nose gear from retracting. However; after 3 laps trying to get them all up, I put the gear down and closed the forward main doors. The plane does get sweet to fly once those doors are closed, the same as the JL F-35 in Canada. Having slowed too much on the 4th flight for landing I was obviously running gun shy and landed waaay too fast and started the lateral oscillation that resulted in broken nose gear rails AGAIN. This time I have added 1/32" ply as upper and lower doublers and hopefully that will absorb more abuse without breaking...it may destroy the formers instead though. The plane is almost back together now and may fly again this Sunday or next weekend. Then I have to go back to Canada as the IRS will start charging me tax after the 182nd day.
I added a 3/4" nose retract riser as per Dave Wilshire's advice, and that nearly completely eliminated the looong takeoff runs. It now ROG's after about 320 feet. To be fair though I have a K-120G in there and that is a heavy engine for this plane. It would be fine on a JetCat P-100 or even the 90 that Dave uses. Not surprisingly, Dave also came up with another fix for the main gear not retracting which proved correct. He added about 10" of extra air line to the main gear lift cylinders and that allows the locking bar cylinders to do their work before the huge lift cylinders add so much force as to prevent the locks from opening.
The ailerons are now flaperons and they are lowered about 7mm for both takeoff and landing. Dave suggested I add about 10mm of up elevator to compensate for the flaperons, but I found that to be vastly too much and will go to 5mm for the next flight. I feel the added elevator was a contributor to the positive AOA gained when the locking bar cylinder and the other locking bar mount let go. Again this was from my landing vastly too fast. Eventually I will "get it" properly. The energy I was carrying and the added AOA from the mains collapsing due to the forces in play caused the positive AOA allowing the F-35A to rise to about 3 feet, stall, and drop onto the nose strut breaking the nose rails again.
I must say the weak nature of the former woods were a contributor as well. The main gear former I replaced in the fall was fine but the other side broke again. This is not a plane that lands all that easily or maybe I'm just intimidated by it. Dave said to fly it onto the ground and he is totally correct, but I was just carrying too much energy. I broke one locking bar cylinder piston rod end right off of the link. The other pulled out of the former again just aside the Hysol 9462 joint I had repaired it with last fall. Anyway Jack at Der Jet wanted me to post my experiences with the plane. My sense is that the wood needs an upgrade to real 5 and 7 ply aircraft grade plywood. That being said, if one is able to land this plane gently as its supposed to be done it would be fine. My first 3 flights were no issue on landing at all. I will get used to it sooner or later. The plane is truly gorgeous even after I have mucked up the underside. One great thing is the main doors never touch! The nose doors suffered a little last weekend but still held. So other than the nose former/rail issue nothing was damaged except a little wing tip on the lateral oscillation of course. All that was easily repaired though.
The original fin/rudder system caused some flutter on the first flight for both Dave and I and the Der Jet Factory consulted with and took Dave's advice and next to instantly re-engineered a new setup for the fin/rudder system that is much more solid and won't flutter. The new fins appeared at my mailing address within a couple of weeks. Der Jet always wants to hide all the control mechanisms for scale fidelity and while that is admirable, the controls need to be adequate for their task before being hidden. The factory acknowledged this and corrected the issue immediately to their credit. I have to say I have never dealt with any jet manufacturer on any continent that is more receptive to their customers and so quick to help in any way possible. For example the spare locking bar cylinder I need now was ordered last weekend and is now at the post office here awaiting pickup tomorrow!!! I cannot say enough good things about Der Jet's support, and believe me I was not the easiest customer for them to handle!!! Also in this light some things were determined that needed changes during my construction and new photos and instructions would appear in my email. Sometimes that was disconcerting, but they were always correct. From what I understand I was the first to fly this plane outside of the factory pilots, and as such I had less than perfect instructions, as no one knew what my setup was going to produce etc. I had a heavier engine but more thrust and several other new to the plane items like the gear sequencer and flight computer etc. All of this put me in uncharted waters to say the least...I must say that between Dave Wilshire and Jack Su I was well taken care of and at times I needed some serious care!!! The end result is a great plane that gets head turning all over the Marine Corps Base on which we fly.
Any questions...I am here to answer whatever I am able...
Aloha,
Len
Old 03-10-2017, 04:03 AM
  #110
Dave Wilshere
Len
Well done for sticking with it. I hope to get out with mine again soon, the winter is almost over and we start to get airfield access again in the next couple of weeks.
Some of my early landings were not the smoothest and my wood work has held up fine, the nose rails are long and unsupported, the packing can be used to spread the load here.
Its undeniable that people love the 'mean' look, its just one of those aircraft that is more complicated than it looks...and was designed to be flown by a computer!
I hope to have a full summer with mine
Dave
Old 03-10-2017, 05:24 AM
  #111
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Wow, this plane is having the same research/teething problems as the full scale. Hopefully it won't have the same cost over runs!
Old 03-29-2017, 03:54 AM
  #112
gunradd
My Feedback: (9)
gunradd's Avatar
Any more news on this bird?
Might be building one for someone and looking for good info on it. I see some had rudder flutter. How was this corrected? Need to make sure the one I build has the correct parts.
Old 03-29-2017, 05:49 AM
  #113
Dave Wilshere
If yours is the later kit with central hinged rudder you should have no issues. I have not flown the new fins yet, but the exterior linkage solved the flutter problem on the live hinge version.
We have a meeting in 2 weeks where I hope to get some more hours on the F-35.
Give me an email address and I'll email draft instructions [email protected]
Any photos you need too.
Dave
Old 03-29-2017, 08:46 AM
  #114
Len
Len's Avatar
The factory at Dave's suggestion went to an internal twin rod pull/pull system and hinge points, from the live hinged single push/pull rod. I too have not tried it yet since my fix of solidifying the top half of the rudders worked fine too. The issue occurs when the live hinge offsets the hinge line to the torque rod amplifying any sloppiness in the linkage. I added a bushing to the bottom of the torque rod too during my repairs curing all its ills. I'm sure Dave will guide you well, but if you ever need a second opinion, PM me at your leisure Kris.
Len
Old 04-03-2017, 09:54 AM
  #115
gunradd
My Feedback: (9)
gunradd's Avatar
Hello Dave. Thanks for doing all the beta testing . My Email is [email protected]
Will be starting the build in a week or 2.
Dave
Old 04-15-2017, 01:14 AM
  #116
Dave Wilshere
Essential RC got another flight on video at a blustery CJ yesterday. Will finish up the manual now
https://www.youtube.com/watch?v=sksjcr32hqo
Old 04-15-2017, 05:25 AM
  #117
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Looked like the issues have been pretty ironed out now. Did that plane have a gyro in it?
Old 04-15-2017, 05:43 AM
  #118
Dave Wilshere
Yes, Powerbox iGyro 3e at 30%. It needs the ailerons turning up slightly, pitch and yaw are perfect.
Dave
Old 04-15-2017, 09:18 AM
  #119
FalconWings
My Feedback: (57)
FalconWings's Avatar
Good flight, congrats!
They fly so much better when wheels are up.
Old 04-15-2017, 09:24 AM
  #120
Dave Wilshere
Yes, when the nose doors are open the huge 'turning vane' has an affect on yaw, then when the front main doors open, it also dumps lift. Its why I fly a circuit gear down, cycle the gear away and visually check. If you get a door stuck or leg hang it gettings messy!
Old 04-15-2017, 12:26 PM
  #121
Len
Len's Avatar
Very Nice Dave! Wish I was back in Hawaii flying mine too! I'm just running a roll axis gyro and it seems fine. Is there something I'm missing on here without pitch and yaw?
Enjoy,
Len
Old 04-15-2017, 12:45 PM
  #122
Dave Wilshere
Len. Its very stable in pitch, but the gyro certainly helps on landing, it keeps it stable in the HA angle it needs to land at. Yaw is good to stabilize things with the gear doors open. So yes an aileron only gyro would sort out the roll damping, but I think you would gain from a 3 axis unit.
Old 04-15-2017, 02:10 PM
  #123
Len
Len's Avatar
I was thinking the same thing and I ordered an iGyro 3e just now.
Thanks Dave!
Old 04-17-2017, 04:19 AM
  #124
FalconWings
My Feedback: (57)
A little inspiration for those about to push the button............
http://www.youtube.com/watch?v=kTrPfbCjKEo
Old 06-20-2017, 07:26 PM
  #125
marquisvns
marquisvns's Avatar
Default CG locations
Getting ready to maiden mine, finally! Any suggestions on CG locations?
Thanks in advance,
Barry
