Reload this Page >
DerJet F-35A
DerJet F-35A
Old 06-20-2017, 07:43 PM
  #126
sysiek
My Feedback: (176)
sysiek's Avatar
Hi Barry the FEJ F-35 cg is 10 cm from front leading edge so is very forward compared to the JL F-22 ,good luck with the maiden flight.And my have flaperons and tayletons setup works OK for me.
Old 06-20-2017, 08:11 PM
  #127
marquisvns
marquisvns's Avatar
Thanks Sebastian, but I think FEJ 35 is slightly larger right? Do you have a picture of your CG in relation to your airframe?
Old 06-21-2017, 03:42 AM
  #128
FalconWings
My Feedback: (57)
FalconWings's Avatar
Yeah, FEJ is a 40# bird. CG is definitely something you DON'T want to screw up. Call DER Jets and get the exact numbers (have them put it in paper LOL). I purchased Xicoy CG machine to get it exactly where it needed to be. Too far aft you will lose it quickly after takeoff, too far fwd it will not lift off the ground.
David
Old 06-21-2017, 04:36 AM
  #129
Dave Wilshere
I've emailed Barry.
Old 06-21-2017, 04:41 AM
  #130
Len
Len's Avatar
Hi Barry, The Factory suggests 35 mm ahead of the front of the main hatch. However; the plane is so difficult to rotate that it may become necessary to move the CG aft, though I'd not go farther than 30mm ahead of the hatch. Dave has now got more experience with this bird than I, so maybe he will weigh in too. CG is not an issue with this plane that I have noticed though but again if you have set the 'on wheel' stance as the factory built it you will need serious speed to rotate and it will then 'pop' off the ground. Dave had suggested to me that raising the nose retract 3/4" would be a solution to the rotation and it really helped to shorten the takeoff roll. Oddly enough the added nose height didn't really alter the look of the plane!
Good Luck!
Len
Old 06-21-2017, 09:07 AM
  #131
Doug Cronkhite
My Feedback: (34)
Have you tried holding full up elevator during the takeoff roll?
Old 06-21-2017, 11:34 AM
  #132
Len
Len's Avatar
Hi Doug, Yes I had tried the 'full pull' as well as holding that and backing off the throttle briefly before the final abort position like the F-18 models used to require, just in case the thrust was forcing the nose down on the shock, all with no joy I'm afraid. The main gear are just too far aft of the CG to rotate without sufficient speed, using the factory AOA. Dave's solution worked fine with the 3/4" added to the nose retract, and it really isn't obvious to look at the plane. I know 3/4" sounds drastic to all scale modelers but it looks fine. Anyway now the F-35A rotates in about 200 to 250 feet depending on the humidity.
Old 06-21-2017, 10:42 PM
  #133
Dave Wilshere
Old 06-22-2017, 02:04 AM
  #134
Dansy
My Feedback: (53)
Dansy's Avatar
When looking at video's its hard to judge the weather and effect on the model, is the wing rocking normal for the F35? Gyro?
Old 06-22-2017, 04:46 AM
  #135
Dave Wilshere
Part cross wind and part design.
When the gear doors are open the lifting section fuselage design is not very efficient, so the angle of attack changes and its less stable in roll. Its why I do a full circuit before clearing the gear each flight.
You can see the difference as soon as its cleaned up, the gyro setting is the same.
At this time the gain is set low on an iGyro 3e, flight testing has shown me the aileron gain can go up, so I have adjusted the internal Gyro gain reducing the pitch and yaw.
When I next get to a tarmac flying site I can test the figures
Dave
Old 06-22-2017, 04:51 AM
  #136
Dansy
My Feedback: (53)
Dansy's Avatar
Thank you.
Old 06-22-2017, 05:01 AM
  #137
Doug Cronkhite
My Feedback: (34)
Can any of these gyros handle independent axis gain adjustment in flight? I would increase yaw gain with the gear down.. I'm guessing the wing wag is actually yaw instability caused by those massive nose gear doors far ahead of the CoP. It looks very tame once it's all cleaned up.
I would LOVE to get my hands on one when I get home from this desert hell..
Old 06-22-2017, 07:08 AM
  #138
Dave Wilshere
The IGyro SRS does. Yes you could increase the gain when its dirty on a simple mix. I have also been experimenting between heading hold and rate mode on the F-35 and like the Mini Xcalibur the heading hold actually suits the airframe more.
Old 06-22-2017, 09:33 AM
  #139
Doug Cronkhite
My Feedback: (34)
Really? I remember having very unhappy results when I tried heading hold on an airplane many years ago.. Maybe things are better now.
Old 06-22-2017, 12:21 PM
  #140
Dave Wilshere
Many years ago is way different to now. The iGyro is stick priority, so trimmed its in heading hold, move the stick and its rate mode. It won't work on neutrally balanced airframes in pitch, leaving the elevator alone can get you into trouble as the gyro takes control,but nose heavy set ups (like this one) it works well.
I always set models equipped with the iGyro 3e gain on a slider or knob, where centre is off, one way is rate mode and the other heading hold. Initial settings match figures until you get to fine tuning.
Dave
Old 06-22-2017, 01:53 PM
  #141
marquisvns
marquisvns's Avatar
Thanks everyone for all the info, and Dave's manual as well as info from DerJet in Taiwan! From what I gathered, I'd be comfortable to start off at 2.5cm forward of the leading edge of engine hatch.
Regards,
Barry
Old 06-22-2017, 02:09 PM
  #142
Dave Wilshere
Put some fuel in the tanks before you balance it. The tanks are big, I land with over a 1/3 of the tanks left most flights.
Old 06-22-2017, 03:11 PM
  #143
marquisvns
marquisvns's Avatar
OK, thanks Dave!
Barry
Old 06-23-2017, 01:02 AM
  #144
Doug Cronkhite
My Feedback: (34)
Barry.. can you send me pricing on the F-35?
Old 06-23-2017, 11:43 PM
  #145
marquisvns
marquisvns's Avatar
Hi Doug, please send me an email with your shipping address.
Barry
Old 09-19-2017, 08:27 AM
  #146
Quandry
From JP...
cheers,
Geoff.
Old 09-19-2017, 09:14 AM
  #147
Dave Wilshere
Geoff
Nice shots. Great heat haze!
Dave
Old 09-19-2017, 09:19 AM
  #148
JP-1
Geoff,
Very nice photographs indeed.
Alistair
Old 09-19-2017, 09:31 AM
  #149
Len
Len's Avatar
Hi Dave, I’m looking forward to getting back to Hawaii in December, as the F-35A is ready to fly again. I just didn’t have the chance before I left in March. I think we have it all sorted now Dave!
Len
Old 09-19-2017, 12:08 PM
  #150
Quandry
Thanks guys, the F35 is an easy subject because it looks great from every angle. Made me want one!
