FB 1/7th F15 scale build
#326
My Feedback: (9)
Ok these are the bearings I ordered from Boca Bearings. Thanks for the links guys .
http://www.bocabearings.com/bearing-...x10x3-MF1062GS
#327
My Feedback: (9)
Here is my motivation This is two short vids my son did when we went flying last weekend. We had a very stiff 90 degree cross wind and the F15 did pretty well until the last flight when the bearings came apart.
On the start up video you can see the pilots moving and the inlets lower during start up like the full scale.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qsBn7pgg46o" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/edFLauBXAR8" frameborder="0" allowfullscreen></iframe>
#328
My Feedback: (18)
Found another poorly made part. The wheel bearings are junk and need to be replaced.
On my 16th flight the right main came apart just before rotation so I had to get off the throttle and let it run off the runway and it ripped both mains and mounts out. Bent the nose strut pin also... So back to repairs. Only have 3 weeks to get her ready for FLjets. Going to be tough.
Not sure where to get replacement bearings from. Ibremoved the other wheel and all the balls just fell out so that one was also about to let loose.
Hi Gun,
Sorry to hear about the bearings, good luck getting the plane airborne again.
sc
#329
My Feedback: (18)
Hello SC
These are 4 new ones. They fixed the part in the middle that was breaking only to have poor welds on the bolt in the bottom break. These have better welds on the lower bolts so they dont break. These should fix the problems but are still not going to be as strong as the original ones that they used to make. They refuse to make them the old way so these are what we get now. I have a set installed and will fly them Sunday. With the plywood gear mod they should work great and take care of this part. Also going to test my 2 air valve system to see if it gets the gear up. If it does not work I will be probably switching to hydraulic.
My buddy Joe that has this plane is having a friend thats a machinist trying to make a 1 part piece. Looking forward to seeing what he comes up with. In the mean time these should work now.
When you get your plane take pics and show me what ones you have and I can tell you if they will hold up. What engine are you gong to use?
I received the model over the weekend, below are pictures of the sockets we discussed, let me know if they're the ones you feel are improved. I also included a pic of the model I took right after unpacking it.
Again, sorry to hear about the bearings. You're performing a great service to us fellow owners by sharing your experience, thank you for doing it! I hope you get it sorted out.
sc
#330
My Feedback: (14)
Kris,
How did you get the bearings out? I've disassembled my wheels to see about changing them and even with an arbor press, they don't seem to want to budge. Now maybe I am being too timid and they are just a press fit .. but honestly mine look more like bronze bushings than bearings .. at least from the outside! Plus mine look like a 12mm OD not 10 mm .. so perhaps there has been a change in the wheels over time?
Dave
Dave
#331
My Feedback: (9)
Kris,
Dave
Dave
SC you have the good ones! They will work fine. Just make sure you install the ply wood brace that I copied from Mick. I was doing landings in a 90 degree cross wind over the weekend and the gear did fine. Before it would have been knocked out for sure.
#332
My Feedback: (18)
Must have been a change then Dave. Mine fell out in pieces. I only have one that I could even measure to get the new ones. They are toast.
sc
#333
My Feedback: (18)
When you have a moment, would you mind sharing with me the overall weight, thrust and burn-rate for the K-300 which is scheduled to debut soon? I've specifically bought only Jetcat turbines and was not able to pull this off the KT site. I'd like to run some numbers on my end.
Thanks in advance.
sc
#334
My Feedback: (9)
Kris,
Thanks in advance.
sc
Thanks in advance.
sc
#338
My Feedback: (9)
Hello SC
Repairs are complete and she is ready to go for Florida jets. Going to fly her the weekend before FLjets so little less then 2 weeks from now. The bearings from Boca fit perfect and the plane rolls great now. Before I thought the brakes dragged a little but now that I have new bearings its clear that the old bearings where causing the drag. Huge difference in how well the plane rolls now.
Also talked to my friend Joe with this plane and he has only done taxi tests so far and he removed his bearings and one of them fell apart in his hand. So he was going to have the same problems I had. If you have this plane please replace those bearings.
Good part is Catherine from FB wanted a link to wear they could by better bearings. Not sure if they are going to get them but they are aware of the problem and trying to correct it. Also she wanted pics of my gear MOD so they can look at adding that to the plane also. Again not sure if they will but they at least listen. I have been extremely happy with Catherine from FB with this whole process. She has supported me every step of the way.
#339
Hey gun, send lots of pictures in order and give very simple descriptions. When I was teaching flights school I had a few Asian students and learned this, it's not an insult but their types language translation is very hard for them just due to the nature of the language. I would spend an hour trying to explain something that would only take a few minutes with a simple picture. I hope the take your advice I have kept this kit on the brain as a replacement for my 1/7 f-15 I sold before flying.
#342
My Feedback: (18)
Hello SC
Glad to hear it's back together Gun, I will replace my bearing for sure, thanks for the help.
sc
#346
My Feedback: (14)
It was a real treat to meet Kris at FLJ and see his F-15E in action .. I saw it fly three or four times on Saturday and it really looks great in the air.
I hope some of the photographers got some good action shots of it, including the nice high-alpha landings!
Congrats on a fine plane flown very well!
Dave
Dave
#348
My Feedback: (9)
<iframe width="560" height="315" src="https://www.youtube.com/embed/1zhl4c0rCv0" frameborder="0" allowfullscreen></iframe>
Some video from Bill Hunt got of the F15. You can see one bomb fall off just after takeoff. The other I dropped and the thing flew a long ways lol. Needs more nose weight.
