Reload this Page >
Elite Aerosport Rebel Pro Build
Old 11-04-2015, 07:33 PM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
All done....
Dan
ID:	2129101   Click image for larger version
ID:	2129102   Click image for larger version
ID:	2129103   Click image for larger version
Old 11-04-2015, 07:48 PM
rc4flying
My Feedback: (21)
rc4flying's Avatar
Looks good.
Old 11-04-2015, 08:00 PM
cartune
Originally Posted by rcjetsaok
All done....
Dan
Big thanks to Dan and Doug for this build. Looking forward to seeing this in the air Friday!
Old 11-05-2015, 03:45 AM
pbusa1400
pbusa1400's Avatar
Looks good Dan... Your main struts are on the opposite side though. Rims should face out.
Pablo
Old 11-05-2015, 05:36 AM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
Roger that... We actually looked at that issue before we even started the kit.. That's what we thought. But the internet steered us the other way pictures and video's that we we watched all showed them facing in... But you are correct and we did change them to out. The pictures and video's we watched were Rebel's with different gear and were probably earlier kits... Excellent eye my man !!! I was wondering if and who would catch that !! ( Scott did )
Another case and good point : You can't always believe what you see on the internet !! LOL
Dan
Old 11-05-2015, 08:17 AM
  #31
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Has anyone flown this with thrust vectoring using a 300N? Is the air frame able to handle it and have enough inlet area?
Old 11-05-2015, 10:15 AM
  #32
FenderBean
FenderBean's Avatar
Video: https://www.youtube.com/watch?v=cS_4B1bDD2I&feature=youtu.be
Video:
https://www.youtube.com/watch?v=hHTE...ature=youtu.be
Old 11-05-2015, 12:02 PM
  #33
rc4flying
My Feedback: (21)
rc4flying's Avatar
I am in the process of building a Pro with this very combo now. Hope to have it in the air before the end of the year.
Old 11-05-2015, 12:33 PM
  #34
FenderBean
FenderBean's Avatar
Welp game on! Small glitch in the matrix but was fixed before I got the jet out to inspect Still amazed at how smooth this all went, cant explain how nice the low stress has been! It a beautiful jet!!!
I have videos uploading as well, I am hoping to start the build later tonight!
ID:	2129188   Click image for larger version
ID:	2129190   Click image for larger version
ID:	2129193   Click image for larger version
ID:	2129194   Click image for larger version
ID:	2129195   Click image for larger version
ID:	2129196   Click image for larger version
ID:	2129197   Click image for larger version
ID:	2129199   Click image for larger version
ID:	2129200   Click image for larger version
ID:	2129201   Click image for larger version
Old 11-05-2015, 12:37 PM
  #35
FenderBean
FenderBean's Avatar
More
More Videos: https://www.youtube.com/watch?v=fm2w...ature=youtu.be
https://www.youtube.com/watch?v=ES1p...ature=youtu.be
ID:	2129203   Click image for larger version
ID:	2129204   Click image for larger version
ID:	2129205   Click image for larger version
ID:	2129206   Click image for larger version
ID:	2129207   Click image for larger version
ID:	2129208   Click image for larger version
Old 11-05-2015, 12:55 PM
  #36
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Do you think it will work are you doing any modifications to the inlet? I saw what happened to the avanti XXL despite being rated to allow a 300N people had to open up intake holes and vents so the turbine could breath.
Old 11-05-2015, 02:05 PM
  #37
rc4flying
My Feedback: (21)
rc4flying's Avatar
As of right now, there are no plans to change anything. The motor is supposed to ship today, so later next week, I will see how it fits.
As for the inlets, I think that would not be possible because of the design. but with the nose gear being left open because we are not doing a nose gear door, this may help with air to the motor. This is a project for my friend, but we are hoping no major changes are needed.
Old 11-05-2015, 03:26 PM
  #38
rc4flying
My Feedback: (21)
rc4flying's Avatar
FenderBean, Looks like the one I am working on for a friend.
Enjoy your build.
Old 11-05-2015, 05:42 PM
  #39
David Jackson
My Feedback: (15)
Hey Fenderbean,
Looking good! I need to get motivated and get started on mine.
Old 11-05-2015, 06:03 PM
  #40
FenderBean
FenderBean's Avatar
Originally Posted by David Jackson
Hey Fenderbean,
I have been fighting a headache all day and just can't start tonight. I do have a few questions for the anyone who can answer. Is the stock pipe diameter okay for a P200, my other questions refer to the picture below. Any issues using the larger control horn on right vs the stock on the right? Also I finally found some rod ends that use a pin with a C clip to hold it in place, but I got to thinking maybe its not a good idea to use a metal pin with a metal servo arm. Seems like it would wear and get slop over time. I wanted to use these because the longer the control horn the less I will have to cut down endpoints for throws.
ID:	2129253   Click image for larger version
Old 11-06-2015, 07:40 PM
  #41
FenderBean
FenderBean's Avatar
Building is underway, I jumped a head on the instructions and skipped the wings since I didnt feel like cutting stuff tonight. So I put the servos in the stabs and rudder, the stabs are easy and fast, the rudder is tough to get the screws in. I am adding more bling than normal since this jet will be a keeper for a long time, so in bling fashion I added wire loom to my servo wires. I found probably 100+ foot of this stuff about to be thrown away at works, couldnt have that so it made its way home
Be sure and add some thin CA to the servo screw mounts, the blocks on the back side will break loose and your servos screws will strip if not.
Also two videos are uploading on my tube channel, i will work on the video making some I end up blocking the view and have a few crutch phrases lol Cheers!
ID:	2129375   Click image for larger version
ID:	2129376   Click image for larger version
ID:	2129377   Click image for larger version
ID:	2129378   Click image for larger version
ID:	2129379   Click image for larger version
ID:	2129380   Click image for larger version
ID:	2129381   Click image for larger version
ID:	2129383   Click image for larger version
ID:	2129385   Click image for larger version
ID:	2129386   Click image for larger version
Old 11-07-2015, 05:57 AM
  #42
M3Baker
M3Baker's Avatar
Off and running.
Old 11-07-2015, 02:04 PM
  #43
FenderBean
FenderBean's Avatar
Originally Posted by M3Baker
Off and running.
Yes Sir!
Finally got going today, I had to make a run to bestbuy, harbor freight, and get my hair did! I noticed from my videos I was looking a bit rough LOL
Anyway printed out the templates and just a heads-up print them at 100% and not fit to page. If you don't the templates will be smaller than they are suppose to be. I mention a couple tips in the video and a mod im doing as well, the video is uploading. About to start cutting so stay tuned!
Video: https://www.youtube.com/watch?v=RnIw...ature=youtu.be
ID:	2129456   Click image for larger version
ID:	2129457   Click image for larger version
ID:	2129458   Click image for larger version
ID:	2129459   Click image for larger version
ID:	2129460   Click image for larger version
ID:	2129461   Click image for larger version
ID:	2129462   Click image for larger version
ID:	2129464   Click image for larger version
Old 11-07-2015, 04:49 PM
  #44
FenderBean
FenderBean's Avatar
I cut all the openings in the wings and mounted the aileron servos, They have the emcotec style boxes for the servos but depending on your servo u may need to trim, I had to cut about 3 mm on the bottom side of mine for the futabas to fit. I glued the two support squares in with 5 min epoxy, play attention to which u put where! The small block is on the wire side of the servo. Then it was a simple drill and screw on the carbon fiber holding cross member. I hate the G-10 color covers so an easy sexy way to bling them out is with a nice decal!!! Cheers
Videos on some work/cutting are uploading Roll Tide!
https://www.youtube.com/playlist?lis...lQOg8hZdfaom2I
ID:	2129513   Click image for larger version
ID:	2129514   Click image for larger version
ID:	2129515   Click image for larger version
ID:	2129516   Click image for larger version
ID:	2129517   Click image for larger version
ID:	2129518   Click image for larger version
ID:	2129520   Click image for larger version
ID:	2129522   Click image for larger version
ID:	2129523   Click image for larger version
ID:	2129525   Click image for larger version
ID:	2129526   Click image for larger version
ID:	2129527   Click image for larger version
ID:	2129528   Click image for larger version
Old 11-07-2015, 04:55 PM
  #45
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
could you cut out gear doors if you wanted?
Old 11-07-2015, 05:09 PM
  #46
FenderBean
FenderBean's Avatar
Yes, before I got the jet I even thought about making a door to cover the wheel but decided to cover the leg instead and leave the wheel open like my Avanti. I am adding a nose gear door instead of just outlining the gear and cutting it out.
Old 11-07-2015, 07:02 PM
  #47
rc4flying
My Feedback: (21)
rc4flying's Avatar
Which Landing gear are you using ? If you are using the Air-Tech Germany gear, than I am pretty sure you are using the wrong pattern for the main retracts.
Old 11-07-2015, 07:25 PM
  #48
rc4flying
My Feedback: (21)
rc4flying's Avatar
I just finished my wings on my project, and I know that you plan on cutting for gear leg covers, but the strut lengths on the Air Tech gear are straighter and longer. It could be how you plan on installing the gear on the gear mounting rails, but notice how close my wheels are to the wing root. I am only 1-1/4" from the root.
Name:	2015-10-29 19.32.45.jpg
ID:	2129549   Click image for larger version
Name:	2015-11-08 00.03.31.jpg
Old 11-07-2015, 07:52 PM
  #49
FenderBean
FenderBean's Avatar
Rc yeah I'm using the same, my pattern is good and since I'm make cover for the strut. I did run into a problem, did the back side of your flex mounts hit the air cylinder? When I put the flex plate down on the ply blocks and insert the retract it will not sit flush since the air cylinder is sitting on the flex plate.
Old 11-07-2015, 08:01 PM
  #50
rc4flying
My Feedback: (21)
rc4flying's Avatar
Yes, that flex plate does hit the air cylinder with the Air Tech gear. I cut the flex plate to make them 2 rail reinforcements. as you may be able to see in the first pic without the gear installed.
