Jeti DS-24
#653
If your concern is flap deployment along with elevator adjustment timing ... you can add delays in the "Butterfly" menu (main screen) where you adjust Flap movement, Crow movement and Elevator movement (item 2 of the menu)
#659
You definitely should use them... the beauty of Jeti program is the flexibility you have using flight modes.. Start with basic flight modes on a three position switch.. Cruise mode (default), Take Off mode and Landing Mode.
David
David
#660
My Feedback: (40)
Hey Rav, I don't use flight modes either but have set up my flaps to slow down using the "Delay positive/negative" value in Servo Setup. Just set each individual flap servo to the speed you want, such as 2.5 in both directions. The slower flap speeds do not affect anything else as far as I can tell.
For mixing in elevator compensation with flaps, I use the "Butterfly" function under the "Fine Tuning" menu. Set it up to activate with your flap switch (sd for me) and under "elevator adjustment", dial in the appropriate amount to get the throw you want. I used the "standard curve" option. You also have the option of slowing down the elevator compensation speed to match the speed of the flap movement.
I'm using this setup on two jets and it works fine.
Craig
Craig
#662
Maybe I need to rethink flight modes now as I'm new to Jeti thinking.
Craig
Craig
I believe this is also the solution Edgar proposed above as well.
And you know there is video for it, I cannot imagine flying without Flight Modes.
Zb/Jeti USA
https://www.youtube.com/watch?v=UZkXwZCN08g
Zb/Jeti USA
#663
The possibilities are almost endless indeed, I just programmed my F-16 so that I have ailevons and flaperons and mixed the slats to the elevator. The way I did this?
1) Go to Fine Tunining --> Flight Modes --> Set up flight modes with delay
2) Go to Fine Tunining --> Function Curve --> Set up flaps speed only
3) Go to Fine Tunining --> Function Curve --> In the 'FM Column --> I deselected channels like gear, throttle, turbine etc changing it from a tick to an X. If you don't then all the channels will be affected by delays when switching flight modes something that may prove fatal.
4) Go to Fine Tunining --> Free mixes --> Set up Ailerons to Flaps (as a flaperon) and another mix Elevator to slats
I did not touch the 'Servo Setup' menu.
But I have one question for you: Maybe I don't understand correctly what you are asking (apologies in advance) but why do you want to delay elevator and aileron movements together with flaps? This can be really dangerous, ie if you flaps have a delay 2-3sec to deploy then the same will be for the elevator. Your pitch authority would be very bad - could lead to disaster. I would never set up the elevator and aileron speed same to the flap speed. But maybe I don't understand your question - apologies again if I missunderstood.
Thanks, Tassos
#664
This is a little off topic.
I thought a lot about add slat and elevator mix to my planes like the full scale. I don't think is a good idea. Not sure which F-16 you have but they usually are not very strong. There are a lot of planes that crashed because of slat structural failure, there is a Skymaster F-104 video on youtube. Plane was own by Ali and he was calling to Sebastiano Silvestre. The slat went off and plane crashed. If this duo wasn't able to fly the plane I think nobody would. Skymaster released a structural upgrade after that.
Franco di Mauro also had a hard time landing a CARF Su-27 with slat problem. People said on facebook that if was other pilot it would have crashed.
Once I asked Bob Violett what was in his opinion the maximum speed I could open the slat on the F-100 and he told me 90 mph. The F-100 slat is 100% laminated in carbon and I believe the BVM F-100 is the strongest scale plane ever built. Bob didn't let me to add this slat elevator mix.
Since then on my planes I set different time for flaps and slat. Like 5 seconds for slat and 3 for flaps so they will make most of the aerodynamic strength decelerating the plane.
Gabriel
#665
Tassos,
Gabriel
Gabriel
I have that mix on a switch - not permanent I can deactivate it whenever I want but works very well for me. I've 37kg (Futaba BLS177SV) servos in each slat.
The slat to elevator mix comes as a recommendation from the manufacturer....Model airplanes Scale-Jets • Scale-Jets.com
Thanks for your feedback.
Tassos
#666
Jeti Studio, New Way of Viewing, Analyzing, Programming, Updating: Telemetry Data Logging & Visualization, Transmitter Data Backup, Transmitter & Receiver Updating
JETI Studio is a cross-platform program for the visualization and analysis of telemetry data received from sensors. The program is available free of charge as a software support to the Duplex product line.
• Graphical visualization of telemetry records produced by the DC/DS and Flight Monitor program
• Direct support for JETIBOX profi – reading log files and real-time telemetry
• Real-time telemetry visualization
• Device updates – you can easily update your receivers, sensors etc.
• EX Bus devices configuration
• Integrated DC/DS-24 transmitter emulator
#668
Thanks, Tassos
Thanks, Tassos
The reason for slowing down elevator and aileron movements with flap deployment is say, if you have crow mixed in or down/up elevator mixed with flaps. You can imagine, if you don't have a matching delay, you hit your flap switch and your airplane dives as the elevator mixes down first and then your flaps "catch up". The same with crow. These are not fun moments!
I haven't had the time to experiment with the other suggestions just yet, but I'll report back how I ultimately solve it.
#669
#670
Tasso, thank you for your suggestions!
All the best, happy flying.
Tassos
#671
#672
https://www.youtube.com/watch?v=qgXq0sDXCV0
#675
