Reload this Page >
Jeti DS-24
Jeti DS-24
Old 09-08-2018, 03:42 PM
  #1051
leemkl06
Originally Posted by rbgetz
Trying to make sure all my RX's have latest firmware using Jeti Studio. On one of my CB200's when I use the USB cable and plug into the EXT port on the CB200, I can't get it to read anything. no response. However, when i try another another CB200 to check firmware , it immediately connects and shows current version. Does anyone have any thought on why one CB200 has no response? i have all other cabling completely remove and no power to it.
THANKS.....
the CB200 needs to be powered to update (see manual). Just did two of mine today.
Old 09-09-2018, 08:30 AM
  #1052
gooseF22
gooseF22's Avatar
Originally Posted by JohnMac
So you have proved that the 900 mHz system works Paul. Why has someone installed a 2.4mHz jammer in the first place?
John
there is an additional backup tone emitted when it goes to 900 High in addition to signal lost. Look in the config
Old 09-11-2018, 08:10 AM
  #1053
skymaster68
Default New to Jeti
hello guys, i’m new to jeti and i have this quedtion, if anyone knows the answer I’ll really apresiate it...
I’m i stalling an R10 In a Carf Joker using a ds24 transmitter...
But i run out of channels, i cant connect my ecu
I have an R3 on hand...
How can I install the R3 to the R10 or how to bind both of them...
I remember I saw that some were but know I can’t find it...
I could get the channel for the electric gear out of the R3 and the rest from the R10...
Please let me know as soon as posible as I’m at the field trying to maiden my new Ds24
Thxs in advance
Brg
Slds
Cristian
Old 09-11-2018, 08:13 AM
  #1054
digitech
My Feedback: (10)
digitech's Avatar
Thxs in advance
Brg
Slds
Cristian
where are you located?
Aeropanda in the usa sells a sb-exp 4 channel expander that works with jeti.
you connect it to a ex port and you can add more channels.
Old 09-11-2018, 08:27 AM
  #1055
skymaster68
Unfortunatelly not in the US...
Can I use the R3 in clone Mode just for the the gear with a battery just for the R3? If so how to bind it...
Old 09-11-2018, 08:37 AM
  #1056
Dansy
My Feedback: (53)
Dansy's Avatar
Frankly I wouldn’t do that, I used 12 ch’s in my smaller models or the cb200/400......
Old 09-11-2018, 09:50 AM
  #1057
LA jetguy
LA jetguy's Avatar
Thxs in advance
Brg
Slds
Cristian
If you use a "Cortex Pro" and setup the R10 in serial mode you can have the first 6 channels through Cortex Pro and re map others through R10 (in device explorer) to get a total of 16...
David
Old 09-11-2018, 10:09 AM
  #1058
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Default Yes
I think you can run in dual path with both receivers connected to the DS24.
Then just map the channel you need to the R3.
That should work and no need to connect the Rx togheter.
Old 09-11-2018, 10:56 AM
  #1059
skymaster68
Problem solved!!
NO BRAKES FOR TODAY there was a strong head wind so no braking was necesay, I maiden my DS24 on my Joker that had an 18Mz before...
the handling of the 24 is supperb, I’m complity happy with it, now time to start migrating my other jets 😁
The red Joker looks cool aside the Custome Red Ds24!!
Old 09-11-2018, 01:38 PM
  #1060
skymaster68
David
Wow that's a good solution, yes I'm running a CP, will try that during the weekend, thxs for the advice..
Old 09-12-2018, 02:12 AM
  #1061
JoeJr1485
Hey all, so I have a question and I don’t know why I’m just now thinking of this. So I have a few turbines and as always I learn the TX to turbine and etc. but after looking in the TX I was drawing a brain fart, in my servo setup for throttle my max pos and neg limits are the default 125% so I went back and looked at all my turbine models and they are the same I never changed them. When setting up your turbines do you all limit both pos and neg to 100? Also I use a switch to set the trim full and off. The way I set the trim is in the function assignment set the switch used then set the trim-max to 100. Is that how you all do it?
Old 09-12-2018, 04:04 AM
  #1062
wfield0455
My Feedback: (7)
wfield0455's Avatar
There is no benefit to setting them above the default of 100% but as long as your ECU can handle the pulse width range and you have valid fail safe conditions set you can use any value you want . Since all my turbines had been previously setup on Spektrum which uses a throttle pulse width range of 1100us - 1900us, I simply reduced my end points to 80% to get that same range and then I didn't even need to repeat the teach RC process as the ECU had already learned that range. I simply use the Throttle cut and throttle idle functions to select stop/ idle. Since I use +/-80% end points I assign the Cut function to the stop position of my safety switch with a value of -125% and the idle function to the idle position of my 2 position safety switch with a value of 20%.
Old 09-12-2018, 05:33 AM
  #1063
JoeJr1485
Thanks for the input. I made some changes to what you brief. I know there is a few ways to skin the cat with this transmitter but want to make sure that my logic and function to end state is as simple and safe as possible 😁
Old 09-12-2018, 07:56 AM
  #1064
causeitflies
causeitflies's Avatar
Thanks for the input. I made some changes to what you brief. I know there is a few ways to skin the cat with this transmitter but want to make sure that my logic and function to end state is as simple and safe as possible ��
I set my kill switch to -100 (learned) and my failsafe to -125. That way if there is a failsafe the turbine ECU will recognize it as a failsafe as it is outside the learned programmed settings.
Old 09-12-2018, 09:07 AM
  #1065
wfield0455
My Feedback: (7)
wfield0455's Avatar
Actually I was incorrect in my previous post. I double checked and I'm also using -100% for kill not -125% as I said earlier.
Old 09-13-2018, 07:57 AM
  #1066
F16Jeff
Originally Posted by gooseF22
Here is a quick video I did for Butterfly on a DS16.. watch it through first because I had to go back and get something I missed..
enjoy..
https://youtu.be/AKRKzGadPe0
https://youtu.be/EKkFwB36AeM
GooseF22,
Thank you for these videos. I was setting up my flaps using the flap switch. Getting them both set to move the same was a real pain. After watching these videos and implementing flaps with Butterfly, what a difference that made.
Again thank you for making flap setup a little easier.
Best regards, ,
Jeff
Old 09-21-2018, 07:11 AM
  #1067
ZB
Something new has been added to the Jeti family. I think the scale jets can mostly benefit from this sensor.
Jeti Telemetry Sensor Hall Effect Magnetic ON/OFF Position
Our new Magnetic ON/OFF Position Sensor will allow you to trigger events based on the True/False signal sent to your Jeti receiver. This is especially important in applications like gear doors, Up and Go systems for sailplanes, and scale features like opening canopies or gear doors. You will install the magnet on the moving side of your opening and the sensor on the fixed side; allowing you to know when it is closed or open. This signal can then be used in logical switching to prevent accidents from occurring. Imagine a safety lockout that prevents your gear from raising/lowering unless the doors are opened first.
Zb/Jeti USA
ID:	2262016Click image for larger version
Old 09-21-2018, 06:42 PM
  #1068
ravill
ravill's Avatar
Ha!! WAY more important would be “3 green” letting us know all 3 gear are down, thus eliminating the “gear pass”!
Now THAT is pretty cool.
Old 09-21-2018, 06:52 PM
  #1069
causeitflies
Gear down and gear up before the doors close. I've been trying to figure out where to put the magnet on the gear, not the door.
Old 09-22-2018, 03:14 AM
  #1070
tp777fo
My Feedback: (28)
tp777fo's Avatar
Gpifp!
Old 09-24-2018, 12:37 PM
  #1071
warbird_1
My Feedback: (61)
warbird_1's Avatar
not to change the subject ,but does anyone know how to set the transmitter to auto off" if it even has that feature" . i left mine on and drained the battery. lost about 2 hours of flying while it charged up. i know it has an alarm but i put the radio back in it's case and didn't hear it. thanks ,WB_1
Old 09-28-2018, 02:20 PM
  #1072
wfield0455
My Feedback: (7)
wfield0455's Avatar
Originally Posted by paulhelis
hi i need help programming ds 24 with magnetic switch, centralbox 200, one 2.4 mhz rx and a 900 mhz rx i did binded both receivers but im not able to see central box and magnetic switch on the radio
i already changed serial link to xbus i cant find a video that shows how to do ir please help
I assume you bound the 2.4Ghz receiver in "default mode" since you are only using one. Connect the 2.4Ghz receiver to Rx1 and the 900Mhz receiver to Rx2 of the central box 200. The CB200 should show up as a subordinate to the 2.4Ghz receiver in Device explorer. The magnetic switch will never show up anywhere, it will simply power the CB200 on / off, nothing more.
Old 10-18-2018, 03:06 AM
  #1073
c_makhija
Hi Guys,
Running the Sbec 30D with the DS24, while the unit performs flawless, it keeps disconnecting and reconnecting every few seconds in device explorer. Any idea what’s wrong?
Chatty.
Old 10-18-2018, 03:14 AM
  #1074
Carsten Groen
Carsten Groen's Avatar
Originally Posted by c_makhija
Hi Guys,
Chatty.
Yes, you need to update the firmware of the receiver to the newest version, well known problem with most of the Jeti receivers.
Old 10-18-2018, 06:26 AM
  #1075
c_makhija
Maybe a stupid question, but the servos can remain connected right? While updating.
If not mistaken had updated the Rex 12 few months ago, unless there is another update.
Chatty.
