Reload this Page >
Jeti DS-24
Jeti DS-24
Old 02-21-2019, 05:12 PM
  #1201
gooseF22
gooseF22's Avatar
oh my that's Purdy David!
Old 02-21-2019, 05:15 PM
  #1202
LA jetguy
LA jetguy's Avatar
Thank you Goose.... I had switches and springs changed at factory..
Old 03-04-2019, 12:03 PM
  #1203
Halcyon66
Just got a dc-24 and installed 3 position stick switch, was a litle tricky to get in yet all went well. Does not seem to work, when i look at the switch setting it shows up as SK yet does not move. the other stick sl has nothing on it and shows the x?
Any thoughts?
Regards,
Old 03-05-2019, 07:04 AM
  #1204
Custmachr
Any thoughts?
Regards,
The only thought I have at this time is that you possibly installed the ribbon cable backwards. I have not tried switching them but they may only make contact turned one way??
Hope this helps.
Tim
Old 03-05-2019, 07:06 AM
  #1205
digitech
My Feedback: (10)
digitech's Avatar
i agree with tim the DS-24 the cable can NOT be installed backwards , the DC can..
checked it?
Old 03-05-2019, 07:15 AM
  #1206
Dansy
My Feedback: (53)
Dansy's Avatar
There’s no ribbon at all in the DC-24, for the stick switch you need to solder, the connections....and it’s small soldering....
Please take a photo of the back of each sticks to see what is wrong...
Did you go into the advance property, stick/switches setup page? Go to SK and change the type of control to what ever switch you install (button/2 or 3 position, I found that sometime the auto selection doesn’t work....
For SL the wire are not install properly, maybe some solder across ?
I have installed stick switches in 3 DC’s so far on both sticks....and change many many switches
Old 03-05-2019, 10:56 AM
  #1207
ZB
Go to Stick/Switch menu a manually select type of the switch, sometimes system does not recognize type and it needs to be selected manually.
DC does not have ribbon cable, plug & play type.
Zb/Jeti USA
Old 03-05-2019, 11:51 AM
  #1208
Dansy
My Feedback: (53)
Dansy's Avatar
Zb/Jeti USA
Stick switches are not plug and play.....they are solder and play LOL 😝
Old 03-07-2019, 12:38 AM
  #1209
Halcyon66
Thanks guys, have not had another crack at it this week been non stop. Will pull off the back again and get some photos.
Many thanks,
Old 03-08-2019, 09:05 PM
  #1210
Halcyon66
Ok well un-soldered everything redid and still nothing, pulling my hair out ( not much left to pull ) and then finally tried SL and of course there she was. So was trying to get the stick with no switch on it to register?
Little embarrassed yet all working great now, just waiting on another 3 position switch for the other stick, hopefully will go a little smoother this time around.
Thanks for the input,
Regards,
Old 03-10-2019, 01:07 PM
  #1211
c_makhija
Hi Guys, just upgraded the CB200 to firmware 1.31 and it shows up as an error in device select on the DS24
Reloaded firmware 1.27 and all works well. Any thoughts?
Chatty.
Old 03-10-2019, 01:11 PM
  #1212
digitech
My Feedback: (10)
digitech's Avatar
In that zip file was a folder with devices.
in there is a file called cb200.bin
you need to copy that file into your tx in the folder devices.
by not doing so you have a fault in the id.
replace it and it will work.!
Central Box 200 V1.31.zip
Old 03-10-2019, 03:37 PM
  #1213
F1 Rocket
Note that once you update the CB200 device file for FW 1.31 you will need to update all of your CB200’s to 1.31.
Danny
Old 03-10-2019, 04:15 PM
  #1214
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Danny
Danny, what does FW 1.31 do for the CB 200?
Gary
Old 03-10-2019, 05:07 PM
  #1215
causeitflies
causeitflies's Avatar
Gary
Ver. 1.30 was more extensive but from the release notes for ver. 1.31:
Version 1.31 (January 2019)
- Fixed: Telemetry input of the Ext2/Ext3 (telemetry inputs did not work properly) .
Old 03-10-2019, 06:03 PM
  #1216
F1 Rocket
Gary
Primary new feature is support for (3) receiver inputs and a new “Mix” mode where all receiver inputs are mixed into a single output to the servos.
Danny
Old 03-11-2019, 02:12 AM
  #1217
Halcyon66
Looks like a bit of a gnarly learning curve is coming.................................
Awesome system.
Regards,
Old 03-11-2019, 10:44 AM
  #1218
c_makhija
Attachment 2263624
Tried that today Sandor, still no luck.
shows up as an error in device select.
Regards Chatty
Old 03-11-2019, 08:00 PM
  #1219
jesse2357
Question, So I ran out of channels on my cb200.My setup is a Rex 7 assist into a cb200 with the second receiver being an r3 (yes I found today I don't get any redundancy with the rex assist unless it comes completely unhooked from the cb200) and an r3 for the switch. I just need 2 more channels to run signal inputs to turn my lights on and off lights. I was trying to use the outputs from my rex 7 assist (I k now I have to power it separate of the receiver port of the cb200) Problem is when I change a output channel on the rex7 it changes the corresponding channel on the cb200 to what ever I set on the rex channel, It even says the correct channel in the cb200 menu but outputs what ever the rex is set to. is there a way to fix this? I don't have the room for a cb400 nor do I feel like it's necessary since I only have 10 servos hooked the rest are things like throttle for the ecu and brake gear inputs and light inputs (doesn't power the lights). any way to use one of the 3 receivers I have?
Old 03-12-2019, 03:12 AM
  #1220
Dansy
My Feedback: (53)
Dansy's Avatar
Aeropanda....help me before so, I have done that before, are you going into devices receiver output....as long as you are on ExBus you have 24 channels possible channels, and have a secondary power your should be good to go.
Old 03-12-2019, 04:43 AM
  #1221
wfield0455
My Feedback: (7)
wfield0455's Avatar
o control your lights in the Assist to be outside the range being used by the CB200. For example if Assist channel 7 has your light control connected to it, then you need to remap channel 7 (in the Assist via device explorer) to be a channel higher than is used by the CB200 such as channel 20 or what3ever you choose. If you leave it as channel 7, then channel 7 will change everywhere, including on the CB200. Still, I'd say don't do this as the power issue is very real and if your extra power connection becomes disconnected it will destroy your CB200. Digitech I think makes an Ex Bus based channel expander that you can plug into one of the CB200 Ext channels that can control up to 4 (I think) servo channels.
Old 03-12-2019, 09:41 AM
  #1222
jesse2357
wfield0455, I wish it was that simple. No matter how I set it up what ever pin 1 on the rex assist receiver is set to is what outputs on pin 1 of the cb200. Even if I set Pin 1 of the rex to ch 20 which is gear lights and the cb200 pin 1 set ch1 which is L. Aileron it still outputs ch 20 on the cb 200. I mean if the cb200 is going to output whatever the input receiver is outputting why even have a setting for it? I feel like there is a setting not correct that's causing this. I have a call into Danny, he was tied up when I called earlier. Hopefully he can help me figure it out. I ordered a Digitech expander but hate to add more electronics to an already electronic full bird. I mean this has a Rex 7a, 2x r3, cb200, cortex pro, gear controller, brake controller, light controller, ECU, dps40 electronic switch (feeds power to the gear light and brake contollers), and a wireless switch expander. Plus 10 actual servos.
Old 03-12-2019, 09:46 AM
  #1223
Dansy
My Feedback: (53)
Dansy's Avatar
With a Cortex Pro if your into it with exbus.....you for sure can reuse
ch 2,3,4,5,6,7
Old 03-12-2019, 12:37 PM
  #1224
jesse2357
I thought about that but that still uses Chanels cause it only works on 1-7. It would have to be above 16 to fix the problem I have.
Old 03-12-2019, 12:43 PM
  #1225
wfield0455
My Feedback: (7)
wfield0455's Avatar
Unless there is a bug in the Assist It really IS that simple. If you reassign channel 1 of the Assist to channel 20 and channel 1 of the CB200 is left mapped to channel 1 then it isn't channel 1 of the Assist will respond to channel 20 and channel 1 of the CB200 will respond channel 1. While I haven't done this with an Assist connected to a CB200 I HAVE done it with regular receivers and other REX receivers so unless there is a bug in the assist then you must be doing something wrong. If yuo suspect there is a bug in the Assist firmware then try assigning your R3 as the primary and connect it to rx1 and try remapping channel 1 of the R3. I know that works as I've done it many times..
