Reload this Page >
Jeti DS-24
Jeti DS-24
Old 12-31-2018, 10:34 AM
  #1176
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by sirrom
New to Jeti and wanted to ask how to do something. When I turn on a plane I would like to get a voice announcement when a particular RX binds. I have looked around at different threads but have not found the way to do it. I know how to set the voice announcement, but don't know how to tie it to a particular RX.
Patrick
So you want to know when RX #x is hook up? there only announcement I'm aware is when the receiver(s)......are bind....and if your dual RX's it won't announce or work until both are...
Old 12-31-2018, 06:13 PM
  #1177
sirrom
Dansy,
If I can make it work when both bind I would be ok with that as well.
Patrick
Old 01-01-2019, 04:52 AM
  #1178
Dansy
My Feedback: (53)
Dansy's Avatar
From memory, that’s under system menu system sound.....assigned to receiver bound....
Old 01-02-2019, 04:20 AM
  #1179
Mick Hargreaves
Just following this up. Plugged an Mbar sensor into 15 on Exbus and it works fine which would imply the issue is with JetCat integration on Ext2 / 3. Doesn't solve my problem but at least we know the firmware is fine for Jeti sensors.
Old 01-02-2019, 09:00 AM
  #1180
F1 Rocket
There is a problem when using CB200 fw 1.30 which results in some sensors connected to ext2/ext3 not working after a power reset. Jeti is aware of this and will release an update.
Danny
Old 01-02-2019, 09:34 AM
  #1181
Mick Hargreaves
Danny
Great, thanks Danny. Good to know they are on the case.
Mick
Old 01-02-2019, 10:44 AM
  #1182
HarryC
Danny
It's worse than that Danny, MBAR plugged into the main Ext1 on CB200, and 400 keeps disconnecting. Several of us have the problem. I actually posted my equipment back to Jeti to check but just days before they closed for xmas Jeti sent me a video denying to me that there is any problem.
Old 01-03-2019, 02:08 AM
  #1183
keweiliang
keweiliang's Avatar
Default Final version?
Old 01-03-2019, 07:25 AM
  #1184
wfield0455
My Feedback: (7)
wfield0455's Avatar
As far as I know, even though they added support for 3 receivers, the recommendations for connecting an Assist with a secondary 2.4Ghz receiver to a CB200 hasn't changed and the secondary should be connected through the Primary (Assist) receiver, not directly to the CB200. The way you have things drawn there will be no stabilization when ever the secondary 2.4Ghz receiver is used. If the secondary is connected via the Primary (Assist), even if it switches to and uses the secondary receiver, the Assist will provide a stabilized Ex Bus output to the CB200.
Old 01-03-2019, 07:56 AM
  #1185
keweiliang
keweiliang's Avatar
this will hold the stabilisation from the assist as long as possible. with the new sw 1.30 you can add also the 900mhz rx.
Old 01-03-2019, 10:22 AM
  #1186
wfield0455
My Feedback: (7)
wfield0455's Avatar
I don't understand this configuration.. I don't think the Cb200 will ever use the rx2 ex bus input in that configuration unless there was some sort of hard failure of the Assist. In that case, since the secondary receiver is physically conneceted to the Assist, it would probably take it with it as well.
Old 01-05-2019, 04:03 AM
  #1187
F1 Rocket
FYI
Firmware 1.31 for the CB200 is available on Jeti’s wedsite.
Danny
Old 01-06-2019, 10:15 AM
  #1188
Mick Hargreaves
FYI
Danny
Top marks to Jeti for revising the firmware so quickly. I'd love to report this has fixed my engine telemetry issue on Ext2 / Ext3, however, this is not the case and the problem still persists. Guess for now I will just have to refresh the pin settings in device explorer before engine start.
Old 01-09-2019, 01:13 PM
  #1189
ZB
I would like to let you know that we have decided to add two more receivers and expand our offering.
Next month we will be adding new Jeti REX 7 and REX 7 Assist with 400mm long antennas.
This way we have smaller REX and REX Assist if anybody would like to add them to any of the Central Boxes.
Zb/Jeti USA
I am talking about this type of antenna.
Old 01-29-2019, 05:29 PM
  #1190
nick0231
nick0231's Avatar
Default Mbar Ex bus issue
I am trying to get the Mbar air pressure sensor to lower the gear and this is how I have it physically set up. I am not sure this is correct way but the only way I could get it to register the pressure.
Here are the instructions I found and programmed it just like this but will not do anything.
Step 1: Create a "Telemetry Control" using the sensor "MBAR: Pressure". Type of control is "Switch". Condition is "X < value" where value is the pressure you consider low (in KiloPascals). Duration is 0. Default is 0%. Switch is none.
Step 2: Create a "Logical Switch". Control 1 is the Telemetry Control you just created above. Condition is "AND". Control 2 is your physical gear switch. When assigning the physical gear switch, start with it in the gear down position. Go to add switch and move the switch to the gear up position. The Control 2 should show a check mark when the gear switch is in the gear up position.
Step 3: Assign the Logical Switch you just created above to the Gear channel in "Functions Assignment."
Any help is appreciated
Nick
Old 01-29-2019, 09:23 PM
  #1191
Bobneal1
My Feedback: (21)
Default Pressure switch
I think you need “or” not “and” . You want the gear to come down when either are in the down position.
Also make sure you smooth the pressure data or your gear will cycle if you lose your telemetry link. Ask me how I know 😎
Bob Neal
Old 01-31-2019, 09:16 PM
  #1192
nick0231
nick0231's Avatar
I tried "or" and every combination would either do nothing or would work the gear until 0 pressure. Does anyone have a Mbar set up to lower the gear differently? maybe I am going at it the wrong way using those instructions I found.
I can see the mbar with displayed pressure in the "device explorer" menu under the RX, but when I create a "displayed telemetry" it will not display the pressure (will display temp in both when I choose that just not pressure shows 2 dashes).
Old 02-01-2019, 05:52 AM
  #1193
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
This is the way I use it:
1) Setup a Telemetry control Mx1 (Low Pressure) : Type=Switch, Condition X < 410 +/- 34 Kpa, Duration = 0.3seconds
2) Setup a logical Switch (Gear Down) : Sa (or whatever is your gear down switch) OR Mx1
3) Assign the logical switch as the Control for the gear down function (Functions Assignment Menu).
Good luck
Old 02-13-2019, 04:27 AM
  #1194
skymaster68
Hi, I was using a powerbox Royal with the PowerBus to Pwm and Futaba...
Since I switched from Futaba to Jeti I want to install a CB400 on that plane with a CortexPro, the question is, can I still run the PwerBus from PwrBox or I'll have to re route all the cables and take that out??
If not I think is better to just add 2 Jetti Rx's to the royal, but in this case can I still install a 900mHz back up??
Old 02-13-2019, 06:55 AM
  #1195
ZB
Stop by to See New Jeti DS-12 Radio System, Elite Motors, and other Exclusive Products at the AMA Expo East (Booth 303-305)!!!
Old 02-16-2019, 10:28 AM
  #1196
marksp
My Feedback: (9)
marksp's Avatar
Is my understanding of this configuration correct?
- RX1 provides RF + stabilization over EX-Bus to CB (Rx1)
- If RF fails, but RX1 still active, then RX2 RF pass through RX1, stabilized signal provided to CB (Rx1)
- If RX1 completely fails, then RX2 provides unstabilized RF over RX1 EX-Bus to CB (Rx2)
- If both RX1 and RX2 fail, then 900mhz RF pass over EX-Bus to CB (Ext1)
Old 02-19-2019, 05:37 PM
  #1197
LA jetguy
LA jetguy's Avatar
Default DS 24 GOLD Limited Edition
Look what just showed up.... DS 24 Gold Limited Edition 01 of 25
Many thanks to Danny M (F1 Rocket) and Jakub M (Jeti Model s.r.o)
Old 02-19-2019, 05:42 PM
  #1198
camss69
My Feedback: (46)
camss69's Avatar
Wow, congrats, one thing for sure you can’t say it doesn’t have some bling to it!
Old 02-20-2019, 05:52 AM
  #1199
skymaster68
Any One??? I'm switching tomorrrow and want to make sure all will work Ok...
Tnks in advance,,,
Old 02-20-2019, 10:23 AM
  #1200
Custmachr
Tnks in advance,,,
i am not familiar with the Powerbox setup but you mentioned using pwn. If you use the Jeti receivers in pwn mode I do not think you will be able to get telemetry feedback. I would just use the CB400.
